Wireless Mini Stereo Multi-room Amplifier A30+
18 reviews
Regular price $159.00 Sale price $139.00
-84 in stock
Delivers worldwide from Asia, US, EU, & RU *A30 delivers to US & EU ONLY 📢This product is not available ship to UKraine, please contact UKraine distributor: Avero
📦A30(old version) available in US/EU/RU warehouse
See shipping options for details
  • 1 Year Warranty
  • 14 Days Return
  • Free Shipping
  • US/EU/RU Warehouse
  • 24/7 Online Chat Support
paymentmethods
  • DESCRIPTION
  • SPEC
  • Q & A
  • REVIEWS
Wireless your Vintage Hifi-system
wireless preamplifier
Upgrade Your Home Stereo Wirelessly
A30 + is an amplifier with wireless streaming capability of WiFi, Airplay, Bluetooth 5.0 and Spotify Connect. By connecting to your home stereo system, you can stream online music, online radio, audiobook or other audio source wirelessly.
  • PCB of wirless preamplifier
    Small but Meet your needs
    The compact design of A30 + won't take up too much space in your home. Even with the mini size , A30+ can meet your daily usage, like play in your bedroom, bathroom and workshop. It is designed to output 35W*2 to your stereo speakers.
  • interface of wireless preamp
    Stream your Favorite Tune
    No matter you like pop, jazz or electronic music with heavy bass, A30+ amplifier support our DSP tuning tool ACPWorkbench which allows you to setup different EQ for left and right channel and other audio effect features.
  • multiroom preamplifier
  • Wireless Multiroom Control
    Just by sliding, you can easily control your whole house stereos with our 4stream App. Control all your units to sync the same audio or play different audio sources at the same time.
  • Compatible to your Home Stereos
    A30+ amplifier is capable to connect to commonly used stereos in your house. Like celing speakers, bookshelf speakers, in-wall speakers and on-wall speakers.
  • digital amplifier
    Friendly User Experience
    Simple setup with BLE WiFi cofiguration that only takes 30 secs to finish the first time network connection. Able to control by App or remote, even wireless audio rookie can setup without a problem.
    More Stable and Reliable
    Compare to the old A30, A30+ add wifi and bluetooth external antennas that improves the signal range and strengh.
Stream All Music you Like
Huge music resources supported like Spotify, Amazon Music, Tidal, Deezer, Qobuz, Internet Radio, iheart Radio, Napster etc. Other than online music, you also can play local music by NAS, USB storage where you have collected your favorite song for years.
wireless preamplifier with Spotify connect
What's More
wireless preamplifier with digital output
Package
USER INTERFACE & CONTROLS
LED indicators
White-WiFi & network mode:
Solid- WiFi is connected
Blue-Bluetooth mode:
Solid- Bluetooth is connected
Green-Line in mode
Red-USB mode
Power Button
Device on:
Long press once: Switch off
Short press twice: Disconnect current WiFi connection and enter paring mode (WiFi mode); Disconnect current connected Bluetooth device (Bluetooth mode)
Device off:
Short press: Switch on
PC
iTunes/Musicbee/Foobar 2000
Remote
Remote Control Available
4stream App
Free iOS and Android App
AUDIO
Music Format
FLAC/MP3/AAC/AAC+
ALAC/APE/WAV
Audio Decode
Up to 24bit/192kHz
Audio Output
44.1khz/16bits, CD quality
Frequency Response
20Hz-20kHz
THD+N
0.03% @1kHz
Speaker Impedance
4-8Ω
SNR
91dB
Speaker Power
2x35W@4Ω load at 18V
2x18W@8Ω load at 18V
Online Music Service
Check here
Local Storage
GENERAL
Weight
0.35kg(0.77lb)
Dimensions
131.8mm*85.5mm*27mm (5.18in*3.37in*1.06in)
Working temperature
Package Included
Main unit x1
Antenna x2
User's manual x1
2-1RCA cables x1
2-2RCA cables x1
Remote cotrol x1
Screw Driver x1
Phoenix Connector x1
18V/4A DC Power adapter x1
CONNECTIVITY
Wifi
5.0 SBC/AAC, 10M
Wired Connection
Streaming Protocols
AirPlay, DLNA, UPnP, Spotify connect, Qplay
INTERFACES
DC Input
12V-18V
3.5mm Jack Analog Input
1Vrms
Micro USB Input
For PC audio output
Speaker output
Pin space 5.0mm
USB Host
Antennas
WiFi/Bluetooth Signal
USER INTERFACE& CONTROLS
LED indicators
Green-Line in mode
Red-USB mode
Power Button
Device on:
Device off:
PC
Remote
4stream App
AUDIO
Music Format
FLAC/MP3/AAC/AAC+
ALAC/APE/WAV
Audio Decode
Up to 24bit/192kHz
Audio Output
Frequency Response
20Hz-20kHz
THD+N
0.03% @1kHz
Speaker Impedance
4-8Ω
SNR
91dB
Speaker Power
Check here
Local Storage
GENERAL
Weight
0.35kg(0.77lb)
Dimensions
Working temperature
Package Included
Main unit x1
Antenna x2
User's manual x1
2-1RCA cables x1
2-2RCA cables x1
Remote cotrol x1
Screw Driver x1
CONNECTIVITY
Wifi
5.0 SBC/AAC, 10M
Wired Connection
Streaming Protocols
INTERFACES
DC Input
12V-18V
1Vrms
Micro USB Input
For PC audio output
Speaker output
Pin space 5.0mm
USB Host
Antennas
Want to get a 30 to 50% discount on this item?
To Know More here.
QUESTIONS & ANSWERS
Ask a Question
  • How can I connect other speakers? Which is the procedure?
    You can refer to this video:
    https://youtu.be/Yz3djqbcYiw
    And use our 4stream App for streaming.
  • Will it get the YouTube music support?
    Will support in future higher spec model.
  • Is the A30+ ROON Ready?
    Sorry, We don't support Roon currently.
  • is the Bluetooth for Input (so i can stream music from my phone to the unit (and other multi room units) like it was a stand alone bluetooth speaker, or is the bluetooth output - so i could connect this unit to a bluetooth speaker (IE wireless speakers) and not use the wired speaker output on the unit?
    Our bluetooth is a receiver not a sender, so you can't connect to output to your bluetooth speaker directly.
    You need to wire to your speaker for output the source.
    But you can stream bluetooth audio to other speaker with Arylic units under the multiroom mode.
    Like use the bluetooth audio source on the master unit then stream to other slave unit.
  • I want to know if bose speaker DS 16F compitable with Amplifier A30+? And if compitable can i install 4 speakers ( 2 in left and 2 in right )
    Yes, you can use this speaker to connect to A30+.
    If you want to connect 4 speakers, you should connect them in parallel, so each side will have an impedance of 4ohm.
  • Is it necessary to use the App to control the device or is there an open protocol via Ethernet which can be used to control the device via own scripts?
    yes, you can get a http API documents through our customer service colleague, or you can make use of TCP protocol
  • Hello, Are you going to support the Airplay 2 protocol? Thank you. Regards,
    we don't support airplay2 currently, but our app 4STREAM can provide with the same functions as airplay2
  • How can I connect to internet. Do I need lan wire or wifi?
    you only need to plug the Ethernet into the lan port , or you can choose connect the device to wifi by pairing via wifi or ble
  • Hi. Is it possible to use A30 as a alarm clock that plays internet radio? Also does it start playing after power loss or i need to turn it on again?
    yes ,you can select TUNE in as alarm clock music,you can setup in 4stream app -> alarm clock
    sorry, it is no possible,
  • If a laptop is connected to the USB port, does the A30 amplifier act as a sound card?
    A30 use amp 2.0 board inside, which will be upgraded to V3 version soon ,its micro usb support USB sound card function .
  • Does the A30 and A50 support pandora?
    All models from us support Pandora.
  • For multi-room setup, can I use the A30 in one room and the A50 in another - is that possible and will the music be synced?
    All models from us can group together and play music in Sync .
  • If I have 3 zones and 3 pair of speakers, do I need 3 of this A30.
    Yes, it's a wireless stereo amplifier ,one unit for one zone or one room
  • What is the difference between the A30 and the A50? Have you ever seen a product similar to the A30/50 but uses only Ethernet for passive speakers? I have an application where I do not need the wireless/Bluetooth to connect to some outdoor bose/wired speakers and I have an Ethernet connection.
    The main difference bewteen A30 and A50 are as below.
    - A50 is 50Wx2CH with 24V power , A30 is 30Wx2CH with 18V power .
    - A50 is full digital amplifier IC from ST , A30 is analog amplifer IC from TI.
    - A50 have RCA out .
  • Good day. Tell me, the total number of online services (Pandora, Spotify, Deezer, Tidal, Qobuz, iHeartRadio, TuneIn, Napster ...) in the A30 model is the same as in the A50 / S50 or less ??
    all software features is same on A50 and A30 .just smaller power output than A50.
Software Comparison
Accessories Compatible
4.8 Based on 18 Reviews
Write a Review
Thank you for submitting a review!
Your input is very much appreciated. Share it with your friends so they can enjoy it too!
Filter Reviews:
A
07/18/2021
AMZKMA
Good sound quality
I am using this in my garage, and have this amplifier connect to the outdoor speakers in the back yard. Now I have music in the backup and I can control the music with my phone. The audio is pretty good for the price. Now I don't have to spend hundreds of dollar on the Sons system that I am pretty to get for the outdoor area.
RD
07/03/2021
Ronnie D.
Great for wireless music in the garage!
This was a great amp for some speakers I had in my garage. Now I can listen to music from my phone while I’m working on woodworking projects. I just use the remote for volume control and it works just fine. Connected to my iPhone without issues as well.
TS
07/01/2021
Thomas S.
Denmark Denmark
Simple and works out of the box
Easy to set up and use. Sound quality is as you pay for, but for small ceiling speakers OK.
RP
06/30/2021
Rushi P.
Great for Streaming!
I don’t have cable, so this product was so helpful in connecting my streaming services to my TV. I was able to AirPlay my favorite shows onto my TV with the help of this device. I would definitely recommend this to those with outdated televisions!
W
05/10/2021
W***o
BR BR
All perfect
Arylic Wireless Mini Stereo Multi-room Amplifier A30+ Review
B
04/03/2021
B***r
BE BE
conform to description, good product.
U
04/02/2021
U***r
UA UA
Arylic Wireless Mini Stereo Multi-room Amplifier A30+ ReviewArylic Wireless Mini Stereo Multi-room Amplifier A30+ Review
X
03/23/2021
X***n
LU LU
Does perfectly the job we ask him like the other amp or amp of the brand :) great for the multiroom
I
03/16/2021
I***h
RU RU
Delivery in three days by courier, the amplifier is small, made very neatly, sounds great, for the kitchen is it. Good equipment.
I
10/28/2020
isolis1980
excelente
excelente articulo
