S50 Pro+ stereo preamp is a device that allows you to add streaming capabilities to your existing audio equipment, such as a home theater system or powered speakers. With this preamp, you can easily stream audio via WiFi, Airplay, Spotify Connect, or Bluetooth aptx HD, and enjoy high-quality audio from online services through your audio equipment.
Mix and match any combination of Arylic streaming devices to create a custom multiroom system and play the same music throughout your home, send different sources to each room at the same time, or create your own custom-defined multiroom zones...
All are controlled via our 4stream App.
S50 Pro+ uses the famous ESS Sabre 9023 DAC and supports aptX HD Bluetooth 5.0. Enjoy high quality sound from high performance hardware with your home stereo system.
Spotify, Amazon Music, Tidal, Qobuz, Deezer, Napster, TuneIn, Internet Radio, iHeart Radio, QQ Music, QQ FM.
The S50 Pro+ stereo receiver connects directly to your online streaming providers to play high quality audio, avoiding Bluetooth bottlenecks and compression.
Stereo RCA Line In, Optical In, USB Host, RJ45 Lan Port (Ethernet), Stereo RCA Line Out, Optical Out, Coax Output, 12V Trigger Out, Speaker Out (4-Wire Phoenix connector included), Sub Out, WiFi and Bluetooth 5.0 with aptX HD Support.
Choose your music source and control playback, set EQ, control multiroom/independent playback, manage playlists, control alarm clock, WiFi settings, update firmware and more...
All the useful features you need in our free 4STREAM App for iOS & Android.
S50 Pro+ WiFi Audio Receiver, User Manual, Remote, 12V 1A DC Power Adapter, External Antennas (Bluetooth & WiFi), 2-1 RCA Cable, 2-2 RCA Cable.
Specification |
FAQs
Yes for sure. For iTunes you can use Airplay with our S50 Pro+ wireless preamplifier
Airplay only. We may upgrade the S50 pro+ to a preamp that supports airplay 2 in the future.
For multiroom, you can use our 4stream app to stream Airplay source to other rooms also.
Group the rooms in app first then stream any audio source(WiFi, Airplay, Online music, Bluetooth, analog in, digital in) you want on the master unit.
A preamp, also known as a preamplifier, is an electronic audio preamplifier that converts a weak electrical audio signal into an output signal strong enough to be noise-tolerant and strong enough for further processing, or for sending to a power amplifier and an active speaker.
Without this, the final audio signal would be noisy or distorted.
The preamp is to amplify the audio signal to the input range acceptable to the power amp. It has the characteristics of selecting the required audio source signal and amplifying it to the rated level and beautifying the sound.
The role of the preamp:
Select the required audio source signal and send it to the rear stage, and at the same time close other audio source channels, and amplify the audio source signal to the rated level to achieve high-fidelity sound quality.
The difference between an audio power amplifier and a preamplifier
The preamp is to amplify the audio signal to the input range that the power amplifier can accept, and the audio power amplifier is to generate the maximum power output to drive a certain load amplifier under the specified distortion rate conditions.
The preamp is an audio processing device before the input audio power amplifier; the amp controls the power of the sound, and the preamplifier controls the audio range.
Arylic S50 Pro+ preamp has a built-in high-quality DAC, which can improve the sound quality.
Support Ethernet RJ45 and AirPlay, DLNA, UPnP, Spotify connect, Qplay input, RCA input, RCA output and Optical output. It can turn your traditional old-fashioned wired active speakers into wireless speakers and improve the sound quality.
For more questions you can refer to our FAQ page or mail us at info@arylic.com or use the online chat. We'd like to hear from you!
Airplay не работает! Приложение тоже минус. Покупал для Яндекс музыки через airplay, но ошибся. После нескольких дней понял, что Китай пока не может… кому Airplay не нужен то наверное сойдет.
Easy setup as long as you read instructions correctly.
I bought two Arylic S50 Pro+ streamers --one off Amazon and the second straight from Arylic. Although I like the functionality after connecting through the quirky 4stream app, the one I bought straight from Arylic suffers from constant music losses. It is annoying and frustrating as I don't have any losses or skipping using any of my other streaming services on any other equipment. I bought the second for my study as the first one seemed to function OK. To be fair, I wrote to the company and will give them a week to see what happens. Am considering returning both of them as I had fewer complications and annoyances just streaming from my pc or Bluetooth from my phone.
Yes, I'm quite satisfied with overall quality. First start, was straightforward, easy to connect and configure, to Wi-Fi. The unit is small and compact, but is easy to connet the cables, from behind.
Sound quality is excellent!
Only note is, missing of more granular volume control. Volume control is with step of 5, which makes big increase and decrease of the volume.
Aleksandar
I have two S50Pro+ and a S10 streamer. Deezer is no longer accessible on all of them since April 12, 2023. So think twice if you are making a purchase.
For a few days, you can't access Deezer on 4stream and Wiim Home either. So I can't use it right now. I hope someone has a solution. So far, everyone has only been sent to someone else.
