Up2Stream HD DAC lets you stream audio throughout your house via Apple Airplay 2. Using Airplay 2 from your iOS device, you can easily stream music to multiple Apple audio devices at the same time.
Up2stream HD DAC supports 1:1 high-fidelity lossless 192khz/24bits audio output. What's more, the high-performance ESS 9038Q2M plays a big role for sound quality. Enjoy high quality sound from high performance hardware with your stereo system.
With Spotify connect and Tidal connect compatibility, you can stream music directly from Spotify or Tidal without using our 4Stream app.
Our wide range of Up2Stream boards are small enough to fit in all kinds of audio projects. Add an amplified streamer inside speaker boxes, or tiny receiver boards inside home theater amps.
Their size and powerful connectivity brings new life to vintage gear and new ideas for your next DIY build. *All Arylic products are compatible with each other for multiroom installations.
Up2Stream HD DAC is able to stream with Qobuz HD and Tidal HiFi to give you the true high resolution audio experience. More HD music will be update and support in the future.
Along with this HD music, it also support Spotify, Amazon Music, Deezer, Internet Radio, iHeartRadio, Napster and more.
The Up2Stream HD DAC is easily expandable, you can add new features to better fit your project. For example, you can add a display panel to add visual of the system, acrylic case for protection, you can also add button board, volume knob, IR receiver and more. You can find all these expansion board in our Accessories section.
Up2Stream HD DAC, Internal Antenna (WiFi & Bluetooth), User Manual, PH2.0 Aux Cable(3 Pin).
Specification |
I'm an happy user of an Arylic S50 Pro that I used to play Hi-Res contents from Amazon Music Unlimited with Android smartphones.
Used in BT mode 'cause I'ld use original Amazon App and above all , Poweramp Equalizer that allowed me a perfect frequencies setup.
Attracted by the new Up2Steam HD DAC , which promised better sound performance with a new ESS DAC and moreover "No Downsampling".. 1: 1 reproduction.
After some time I broke the delay and took it, completed with its beautiful case and replaced the S50 Pro .
Wooahhww ... !!! never purchase has proved more appropriate ...!
Used in Wi-Fi mode (here the difference with BT is noticeable), the effect does not resemble a Streamer replacement. Much more .. as if I had changed the whole HI-FI composition from good but basic brands to HI-END McKintosh compositions or similar ... !!!
My old Pioneer 6500 Mk.II Amp connected to a basic EQ Beringher FQB 800 and to KEF Q55 Mk.II standfloor speakers, with new Up2Stream HD DAC are able to give "Best of Themselves" with a Quality never heard before, turning into a New Life.
With Volume knob at 1 1/2 my Old Hi-Fi reproduces a real "Wall of Sound". Impressive power and clarity of sound, perfect channel separation, accurate balancing of output for different Instruments and Voices, details and clarity never heard before.
Creation of a Powerful and Detailed Soundstage with Voices & Instruments emissions perfectly distinguishable & integrated with each others .. !!!
Well .. listen Freddy Mercury singing "Love of my Life" closing my eyes... gives the impression of having "now" Queen in Concert directly in my living room .. !!!
Wouwhh .. Really Awesome ... !!!
My sincere congratulations to Fran who studied and implemented the creation of this "Jewel" and to Joy who, as always, took care of the order & delivery phases in an impeccable way.
If someone want to play his Old Hi-Fi with an unsuspected quality, never heard before...purchase of Up2Stream HD DAC Card is a real blessing, the most well-spent money with truly effective and detectable effects at first listening of any Know Song.
Only a prayer to Fran..add the direct access to Amazon Music App, as is for Spotify and Tidal yet.
Up2Stream HD DAC .... try it and .. you won't be able to do without it anymore . A True (Good) Addiction .. !!!!
Nice product but it's not quite finished yet.
I use this dac in combination with Apple music and Apple TV.
While starting a music track, I regularly hear that the track is briefly restarted for the 2nd time. This is very short. I tested this over WiFi as well as over a wired one.
Another problem I regularly experience is that the sound during a feature film sometimes just stops for 30 seconds for no apparent reason. Then the sound will simply play again. This also happens over WiFi as well as with a wired connection.
My internet connection has been tested and is in excellent condition.
What works well is the combination with Up2Stream Amp Sub - Multiroom Wireless Subwoofer Amplifier Board the synchronization works really well. What I think could be improved is the volume control. It would be nice if the ratio that can be set via the app between the different nodes in terms of sound pressure increases evenly. Now it is the case that when sending open everything is opened to the maximum and the ratio you set is lost.
Trebble and Bas do nothing in the app my firmware version: 4.6.414645.35
What could be a nice addition is that you can see which audio resolution is being played. (I also have the display)
The sound quality is really good, the ease of use is also great in my opinion, definitely recommended.
Hopefully everyone can benefit from this information
This board works brilliantly
The sabre 9038 dac chip gives a sound with excellent clarity.all the ins an out give anyone a vast option to use
This little device works perfectly with Apple music. No need to use the 4Stream App other than to connect. Fidelity of the music is great for streaming. Would highly recommend!
I wish have more ph2 cable within the package, but otherwise it’s a good product !
Up2Stream HD DAC - Airplay 2 High-Res Wireless Aptx HD Audio Streaming Board(No Amp)
