If you're looking to buy a new speaker, you've probably been presented with a plethora of options. You will notice there are so many options you can take into consideration, from boom boxes to soundbars, smart speakers to subwoofers!
The bookshelf speaker is a type of speaker that is rarely discussed. However, once you understand what bookshelf speakers are, you'll realize that they're just as powerful as the rest.
Let's look at why you should think about adding bookshelf speakers to your setup.
First: What Are The Bookshelf Speakers?
Bookshelf speakers, as the name implies, are intended to be placed on surfaces such as bookshelves or tables. They improve sound quality in small to medium-sized rooms when elevated from the ground.
Some Significant Specifications of Bookshelf Speakers
If you want to make good use of your bookshelf speaker, the first thing you need to understand is what specifications to look for.
Since most types of speakers have the same specifications, you can check those three main areas that your bookshelf speakers must meet:
Bookshelf speakers have two types of drivers: woofers and tweeters. The woofers produce bass, while the tweeters produce high-frequency sounds. When purchasing a bookshelf speaker for general use, look for one with a third midrange driver.
Watts: The more watts your speaker has, the louder it will be. If you already have a bookshelf speaker, make sure the wattage level of your new one is the same. This makes certain that they transmit a smooth music experience but a distorted one.
Hertz: Hertz is related to the bass. The lower the hertz number, the deeper the bass.
The above specifications will, for the most part, be tailored to a typical listening experience. If you made a decision and have specific preferences, make sure to look into those factors before making a purchase.
Some Popular Usages For The Bookshelf Speakers
Bookshelf speakers are most commonly used indoors for safety and convenience. Let's look at three of the most common applications for bookshelf speakers.
Record Player Configurations
If you've ever looked at some inspiring record player setups, you'll notice that many of them include bookshelf speakers to round out the look. If your bookshelf speakers are connected to a record player, they will send great sound quality. However, they will also have a retro vibe to your room space.
Home Studios
Bookshelf speakers are also frequently used in home studios. This is due to their ability to pack a punch while remaining unobtrusive. To begin with, connect a few speakers to your system simply and place them on a shelf.
Home Theater Equipment
Bookshelf speakers are also useful for home theater systems. The reason is that the bookshelf speakers can blend in with any room without being noticeable.
Many bookshelf speakers are also can be used as multi-room speakers and multi-zone speakers. In this way, you can complete an amazing surround sound system in your own home. The bookshelf speakers can be adjusted to meet your needs, whether you're entertaining guests or watching your favorite movie.
Where to Place Your Bookshelf Speakers
The placement of your bookshelf speakers has a significant impact on their sound quality. While you may believe that putting them on a bookshelf will solve all of your problems, the actual positioning is what you should focus on.
Make Use of Clock Hands
Generally speaking, install your bookshelf speakers at "10 o'clock" and "2 o'clock." This provides optimal sound regardless of where you are in your room. They should also be placed at ear level to improve the quality even more.
Keep An Eye On The Vibrations
Monitoring the vibrations of your bookshelf speaker is another method to determine its position. The final sound will be distorted or muffled if the speaker vibrates excessively when placed on an unstable surface.
To avoid excessive vibrations, you need to move your speaker to a more stable surface or use decoupling pads. You should hear a difference almost immediately.
Allow Them Some Breathing Room
Bookshelves are frequently constrained spaces, as bookshelf speakers are well aware. If there are unwanted rumbles in the sound, maybe the space is not enough for the speaker.
Consider clearing the area around your speaker to help these "rumbles" fade. This enables the lower frequencies to play uninterrupted.
Do I Need A Speaker Stand?
Speaker stands offer an alternative method of positioning your speakers. These freestanding holders are ideal for enhancing your listening experience because they are designed to be placed at ear level, eliminating the need to adjust your bookshelves.
It is totally subjective whether you need a speaker stand or not. If you have a speaker stand, it can improve the sound quality to some degree. Also, it can keep your speaker on a stable and sturdy surface. If you playing music in a large room, we recommend you can use a speaker stand.
Instead of confining the sound to the walls of a bookshelf, this will help to distribute it evenly.
Second: 5 Reasons Why Every Home Needs The Bookshelf Speakers
1. They are portable in size.
Of course, this is the most obvious reason that you can notice. However, the bookshelf speaker name does not mean you can only place it on a shelf. Some models are so small that they can easily fit into the smallest spaces in your room or kitchen.
Because of the portability, you can rearrange your bookshelf speakers frequently and carry them with you simply wherever you go. Some bookshelf speakers also can be powered by batteries and electricity. But if you need more power from your bookshelf speakers, you may choose other models that are also smaller than tower speakers.
2. They can help you finish or improve your home theater system.
Bookshelf speakers are standard in most high-end home theater systems. If purchasing the entire system is out of your price range, you can add a pair of bookshelf speakers to your home theater as a stand-alone addition.
If you make the correct choice, this equipment will upgrade audio reproduction a lot, and give music and movies a boost.
4. They have a wider range of design options.
Certainly, there are many different types of speakers you can choose from. However, bookshelf speakers simply have more variants and you have more options. As a result, you will have a better chance of finding the best model that will match the interior of your room.
If matching designs are not important to you, you can focus your attention on some creative, even custom-made designs. This means that you can choose not only bookshelf speakers of various styles (vintage, futuristic, etc.) but also various shapes.
If you want to look for bookshelf speakers for gaming, you can select a model with a gaming design that can give you some gaming vibes.
5. They can be either active or passive.
Passive floor-standing speakers are almost always used. You can choose between active and passive speakers in the bookshelf models. This means that if you want to use an active model, you have no need to buy and install an extra power amplifier.
If you choose Arylic BK651 bookshelf speaker, then you can also use our A50+ amplifier to drive it.
If you want to improve your home speaker system, bookshelf speakers have all the answers. They are small, convenient for organization, and loud enough to blast your favorite music. You can't go wrong with having bookshelf speakers in the house for whatever reason you want.
