Up2Stream Amp Mono - Multiroom Wireless Streaming Mono Amplifier Board
Sale price$89.00
  • Easy switch between mono and stereo mode.
  • Maximum 100W powerful output of mono mode and 50W x 2 powerful output of stereo mode.
Support Together
mono amplifier review
Up2stream AMP Mono
Up2Stream AMP Mono is an amplifier board equipped with both WiFi, Airplay, Spotify Connect and Bluetooth 5.0, designed to enable your existing audio system with wireless capabilities. It offers a comprehensive solution for DIY enthusiasts who want to create a personalized wireless audio system.
The Up2Stream AMP Mono has the ability to switch between stereo and mono mode. In stereo mode, it delivers up to 50W of power for both left and right channels, while in mono mode, it can provide a maximum of 100W for a single channel by mixing the left and right channels.
Features
Wireless Connectivity
Up2stream AMP Mono supports WiFi and Bluetooth 5.0, allowing for easy streaming of music from various sources such as smart phones, tablet, laptop, and computer within your local network. Additionally, the device supports popular protocols such as Airplay, Spotify connect, DLNA, and UPnP, providing seamless wireless music streaming capabilities.
Up2Stream AMP Mono features an RJ45 Ethernet port for a more stable network connection. This allows you to directly stream music from your smart devices without having to go through the WiFi setup process using the app. This feature makes it super easy to get started and enjoy your music quickly and effortlessly.
Mono/Stereo Mode
The Up2stream AMP Mono is a versatile mono amplifier board that can function as both a stereo and mono amplifier. You can easily toggle between these modes using the jumper located on the board. This means you have the flexibility to use the board in either stereo or mono configurations depending on your needs.
Powerful Home Amplifier Board
Under stereo mode, the Up2stream AMP Mono is capable of delivering a maximum power output of 50W x 2 at 4ohm and 24V. However, when switched to mono mode, it can deliver up to 100W of maximum power output at 4ohm and 24V. This means that the board can provide a higher power output when used in mono mode compared to stereo mode.
Lossless Audio
The Up2stream AMP Mono is designed to support a broad range of lossless audio formats, including FLAC, MP3, AAC, AAC+, ALAC, APE, and WAV. Furthermore, the board can decoding up to 192kHz/24bits, and providing high-quality audio output with a resolution of 44.1kHz/16bits CD quality. The Up2stream AMP Mono also delivers impressive sound with the TPA3116D2 amplifier chip used in its design. This chip provides powerful amplification to bring out the best in your audio.
Music Services Support
Versatile Music Sources
The Up2stream AMP Mono offers versatile streaming options, allowing you to easily stream music from various sources such as music services, NAS, USB, phone storage, SD card, and other 3rd-party apps that support Airplay, DLNA, and UPnP protocols. This provides you with a wide range of choices when it comes to selecting your preferred music source. Additionally, the device comes with Bluetooth 5.0, enabling you to stream audio from your smart devices seamlessly. This means you can enjoy your favorite music on the go, without the need for any additional cables or devices. With its multiple streaming options, the Up2stream AMP Mono makes it easy to enjoy high-quality sound from a variety of sources.
Multiple Interfaces
The Up2stream AMP Mono comes with a range of ready-to-use interfaces, including a 3.5mm line in, micro USB audio input, speker output and a plug for SPDIF in, Line in, Line out,Mono out, LED indicator, IR extention, and ADC-key. Which enables you to create a flexible system according to your specific needs. With these features, you can easily connect your audio devices and enjoy high-quality sound without any complicated setup.
Multiroom/ Multizone
Enhanced Up2stream
The Up2stream AMP Mono offers several optional expansion boards that can be used to enhance its functionality and performance. These expansion boards include the Up2stream SPDIF board, Up2stream button board,, Up2stream IR extension board, and Up2stream volume knob board. Each of these expansion boards provides unique features and capabilities that can be used to customize and improve the performance of your Up2stream AMP Mono device. You can find all the boards in Accessories.
USB Sound Card for PC
Once you connect the Up2stream AMP Mono to your PC, it will be detected as a USB sound card. This allows you to stream audio from your PC directly to other devices connected to the Up2stream AMP Mono. This feature provides a convenient way to extend your audio playback capabilities beyond your PC. Support both Windows & Mac PC.
ACPWorkbench Tuning Tool
The Up2stream AMP Mono offers a range of communication options, including HTTP API, UART, and TCP commands, providing flexibility for users to integrate the device into their existing smart home systems or to develop custom applications. Get API files below in the download portion and check the cases in our forum.
Optional Remote Control
the optional remote control is a useful addition to the Up2stream AMP Mono, providing an easy and convenient way to control your music playback from a distance. Like play/pause, deep bass, adjust volume, and quick switch preset content from a distance. Whether you're listening to music in your living room or in another part of your home, the remote control makes it easy to adjust your settings and enjoy your music to the fullest.
Newest Firmware Version
Connectivity
WiFi:
IEEE802.11 b/g/n 2.4G
Bluetooth:
Wired Network:
Power Input
12V-24V/DC in
12V-24V 2Pin Connector
Audio Input
Analog:
3.5mm Line Input (1 Vrms)
Digital:
Micro USB Input
*SPDIF In pin connector
Audio output
Analog:
Other I/O Interface
LED pin connector
IR pin connector
Button pin connector
Rotary encoder pin connector
GPIO pin connector
Mono Out pin connector
Amplifier Chip
TPA3116D2
Speaker Power
Stereo:
2x50W @ 4ohm load at 21V
2x30W @ 8ohm load at 24V
2x15W @ 8ohm load at 15V
Mono:
100W @ 2ohm load at 24V
60W @ 4ohm load at 21V
30W @ 8ohm load at 18V
Speaker Impedance
4-8Ω
USB Host
Audio Channel
Mono
2.1(L+R+Sub)
Music Service
100W(Mono)
2 x 50W(Stereo)
2 x 50W + 100W
2 x 40W
Analog Audio Input
Aux In(3.5mm Jack & Pin)
Aux In(3.5mm Jack)
Digital Audio Input
Spdif In(Pin)
Spdif In(Pin)
Spdif In(Pin)
Analog Audio Output
Stereo-Aux Out(Pin)
Mono out(Pin)
Digital Audio Output
I2S Out(Pin)
Amplifier Chip
TPA3116D2
TPA3116D2*2
ma12070p
Audio Format(Up To)
44.1khz/16bits(CD)
44.1khz/16bits(CD)
44.1khz/16bits(CD)
USB Playback
ACPWorkbench
Remote
Optional
Optional
*①Optional
Knob Control
Yes(Volume, Treble, Bass)
Expansion Boards
Spdif In Board
*②Spdif Out Board
Button Board
Volume Knob Board
IR Sensor Board
Spdif In Board
*②Spdif Out Board
Button Board
IR Sensor Board
Spdif In Board
*②Spdif Out Board
Button Board
*③IR Sensor Board
Suggestion
For Boombox
Build Your Wireless Projects
Wireless Mono Speaker
Shared by Janosch Petry
DIY Artist Wireless Speaker
Shared by Christoph Klecker
Build Multiroom Amplifier
Shared by Martijn Koopman
Shared by Alexis
Compatible Accessories
Sale priceFrom $7.90
ESS9023 DAC boardbutton board
Sale priceFrom $10.00
ACPWorkbenchDSP tool
Based on 9 reviews
89%
(8)
11%
(1)
S
Sven Schlicher
Great streaming amp with multiple functions
It's the sixth amp I bought and used for homemade premium Boomboxes. Sounds quality ist very good. The possibility to squeeze the speaker's frequency response with the software used great. For the first time I used it to programme a 2 way crossover.
f
felix giffuni
Up2Stream Amp Mono
Very good product. Software is based on a solid LinkPLay API. It take a very short time, few minutes, to configure and play music.
Marcel
Great DIY solution
Building a multiroom solution with central audio source. The Up2Stream amp is a perfect solution. Note that the mono and stereo amps are identical: a jumper block is used to select in which mode to operate.
G
Good Dad
Underwhelmed
I bought this to simplify a wireless speaker build, however, I found it lacking power and a few items weirdly placed. All of the external connections are on side, which is good. They are offset which allows the creation of cover plate to expose the connections and hide the electronics, but the speaker connection is pin connector, not an external connector like an RCA or Banana Jack. And if you're using as part of a powered, stand alone speaker, you have to run the wires out the back and then back into the speaker. I simply desoldered it and directly connected the speaker wire internally. The other item is that the LED light AND the infrared receiver are mounted on the other end of the circuit board. So, you can either desolder them and run an extension to make them accessible and visible, OR, you have to purchase another receiver and finagle an RGB LED using the onboard pin connector. Alternatively, you can wire separate colored LEDs to indicate the status using onboard connector. However, I love rest of it. The software seems to be as good as the HEOS software, plus, if you want to customize it using the workbench, you have that ability too.
Z
Zoran Vitas
DIY Wifi Speakers
I have purchased these amps in order to turn my old passive Pioneer speakers into Wifi speakers. With on-off-on switch I managed to create double input on speakers so now they can be used as before connected to my old amp or as a Wifi speakers connected to Up2Stream amp.
I have also added battery power and turned them to completely wireless speakers when used with Up2Stream amps.
D
D***e
Ordered 3 amplifiers, one of them came with a defect, did not work the power button. The seller sent a similar amplifier at his own expense. I checked everything, everything works well! Seller recommend! The only nuance, this is a large power supply, twice as much as the amplifier itself.
You May Also like
