5.25 inches in-ceiling speaker with pivotaing and rotating woofer and tweeter(each) - arylic
5.25 inches In-ceiling Speaker RK525
Regular price $129.00
-39 in stock
📦Asia Stock Available Now
Due to exiting from the EU event, our EU warehouse is not support for shipping to UK and Northern IE. Will ship from Asia directly.
  • 1 Year Warranty
  • 14 Days Return
  • Free Shipping
  • EU/US/RU Warehouse
  • 24/7 Online Chat Support
Payment Method
  • DESCRIPTION
  • SPEC
  • Q & A
  • REVIEWS
In-ceiling Speaker With Pivoting And Rotating Woofer And Tweeter For Each
In-Celing Speaker RK525
RK525 in-ceiling speakers were designed with the TOP professional acoustic designer, which feature an aimable woofer/tweeter module that aims the sound in any direction you choose. No longer are you bound by the design of your room. Just mount the speakers wherever it’s convenient and point them wherever you want sound.
General
Woofer Size : 5.25 inches
Woofer : Pivoting and Rotating 5.25 inches Kevlar cone with rubber surround
Tweeter : Pivoting 24mm aluminum diaphragm with silk,NE magnet
Frequency Response : 50Hz - 20kHz
Impedance : 8 (Ohms)
Switches : Front-Mounted Bass & Treble Equalization Switches
Crossover : 2.8kHZs
Dimensions : 20.5 x 11cm
Hole Cutout Dimensions : 17.5cm
Other Specifications
Flangeless Appearance
Pivoting and Rotating 5 1/4" Aluminum Cone Woofer
Pivoting 3/4" Aluminum Dome Tweeter
WavePlane Technology
Why Choose Us
QUESTIONS & ANSWERS
Ask a Question
  • Do any wires need to be run to the speaker? Power or speaker cable?
    Yes, just speaker cable required .
Software Comparison
Accessories Compatible
