H400 4-Zone Multiroom Streaming Preamplifier
- Stream To 4 Zones - Independently, Or in Sync: Add network streaming, AirPlay, and Spotify Connect capability to your existing active wired speakers, amplifiers, preamps and receivers. Stream and control 4 different audio outputs at once, control all music wirelessly via our 4STREAM App.
- Multiroom Audio System: Mix and match any combination of Arylic Streamers to create a custom multiroom system and play the same music throughout your home, send different sources to each room at the same time, or create your own custom-defined multiroom zones... All controlled via our 4STREAM App.
- Brilliant Sound Streamed Directly From Your Favorite Providers: Spotify, Amazon Music, Tidal, Qobuz, Napster, TuneIn, Internet Radio, iHeart Radio, QQ Music, QQ FM. The H400 connects directly to your online streaming providers to play high quality audio, avoiding Bluetooth bottlenecks and compression.
- Stream Any Kind of Audio On One Device: In addition to Direct Streaming from Online Streaming Services, AirPlay, and Spotify Connect, there are multiple digital and analog input and output ports allowing you to connect most of the audio devices in your home.
- Plug and Play: Power up the device and connect to your WiFi router with the Lan cable and it is ready to use.
The M400 is a networked 4-zone streaming preamplifier that allows you to directly stream up to 4 audio devices at the same time, per M400 unit.
The M400 supports the most popular smart home systems, Fibaro and Elan, and will be integrated with more smart home brands in the future.
Stream To 4 Zones - Independently, Or In Sync
Add Direct Streaming, AirPlay 2, and Spotify Connect capability to your existing active wired speakers, amplifiers, preamps and receivers.
Stream and control 4 different audio outputs at once, controlled wirelessly via our 4STREAM App.
In addition to direct streaming from online streaming services, AirPlay 2, and Spotify Connect, there are multiple digital and analog input and output ports allowing you to connect most of the audio devices in your home.
The H400 comes with optional mounting brackets for installation in standard 19" racks (1U height).
H400 comes ready to integrate with Fibaro and ELAN Smart Home installations, with an RS-232 port to connect to your smart home control unit.
Integrate and control your H400 with your smart home programs.
M400, User Manual, Ethernet Cable, 12V 2A DC Power Adapter, Rack Mount Brackets x2.
WiFi:
IEEE802.11 b/g/n 2.4G
Bluetooth:
Wired Network:
Ethernet Single 10/100M RJ45 In
Ethernet RJ46 Out
(Output to other device to share the network)
AirPlay 2, DLNA, UPnP, Spotify connect, Qplay
FLAC/MP3/AAC/AAC+
ALAC/APE/WAV
Decoding up to 192khz/24bits
20Hz-20kHz
12V/2A
4 Zone InterfacesAnalog
RCA In(Max 2V RMS input)
Master InterfacesAnalog
Digital
Optical Input
Coaxial Input
RCA Out(Max 2V RMS Output)
Digital
Coaxial Output
4 Zone Interfaces
Trigger Output(12V)
Master Interfaces
Trigger Output x1(12V)
Dual-way RS232
3kg
43x20x4.5(5.3 with footer) cm
⚪White-WiFi & network mode:
Solid- WiFi is connected
🟢Green-Line in 1 (Zone Line in)
🔴Red-USB mode
🟡Yellow-Yellow for Line in 2 (Master Line in)
🟣Magenta-Master Optical in
Cyan-Master Coaxial in
Does this preamp support Airplay 2 or only Airplay?
H400 is available to support AirPlay 2.
It has received 1 review.
