Up2Stream Amp 2.1 - Multiroom Wireless 2.1 Amplifier Board
- Maximum 50W x 2 +100W powerful output for your 2.1 projects and audio system.
Up2stream AMP 2.1
The Up2Stream AMP 2.1 is a versatile WiFi and Bluetooth 5.0 2.1 stereo amplifier board designed to upgrade your existing audio system to a wireless-enabled setup.
It also serves as an all-in-one solution for DIY enthusiasts who want to create their own customized wireless audio system.
Once connected to your home network, the device can be controlled using our 4STREAM app, allowing you to stream music from various sources such as your home NAS, USB drive, or mobile phone memory.
You can also access popular online music streaming services like Spotify, Deezer, Tidal, Qobuz, and more. With its wireless multiroom audio feature, you can play the same music in sync across all rooms or choose to play different music in each room.
Overall, the Up2Stream AMP2.1 is an excellent solution for music enthusiasts who want to enjoy high-quality wireless audio at home.
Features
Wireless Connectivity
Up2stream AMP 2.1 supports WiFi and Bluetooth 5.0, allowing for easy streaming of music from various sources such as smart phones, tablet, laptop, and computer within your local network.
Additionally, the device supports popular protocols such as Airplay, Spotify connect, DLNA, and UPnP, providing seamless wireless music streaming capabilities.
Up2Stream AMP 2.1 features an RJ45 Ethernet port for a more stable network connection.
This allows you to directly stream music from your smart devices without having to go through the WiFi setup process using the app. This feature makes it super easy to get started and enjoy your music quickly and effortlessly.
Powerful 2.1 Amplifier Board
With a peak power output of 50 watts per channel for two channels and an additional 100 watts, the Up2stream AMP 2.1 has the ability to provide a impressive 2.1 home theater experience with powerful deep bass.
With the ready-to-use interfaces, streaming music is as simple as plugging in the power and connecting to a passive speaker and subwoofer.
Unlike other Bluetooth amplifier board, there's no need for soldering of pins before you can get started. This makes it incredibly easy and user-friendly for anyone to use.
Lossless Audio
The Up2stream AMP 2.1 is designed to support a broad range of lossless audio formats, including FLAC, MP3, AAC, AAC+, ALAC, APE, and WAV.
Furthermore, the board can decoding up to 192kHz/24bits, and providing high-quality audio output with a resolution of 44.1kHz/16bits CD quality.
The Up2stream AMP also delivers impressive sound with the TPA3116D2*2 amplifier chip used in its design. This chip provides powerful amplification to bring out the best in your audio.
Music Services Support
Versatile Music Source
The Up2stream AMP 2.1 offers versatile streaming options, allowing you to easily stream music from various sources such as music services, NAS, USB, phone storage, SD card, and other 3rd-party apps that support Airplay, DLNA, and UPnP protocols.
This provides you with a wide range of choices when it comes to selecting your preferred music source.
Additionally, the device comes with Bluetooth 5.0, enabling you to stream audio from your smart devices seamlessly. This means you can enjoy your favorite music on the go, without the need for any additional cables or devices.
With its multiple streaming options, the Up2stream AMP 2.1 makes it easy to enjoy high-quality sound from a variety of sources.
Multiple Interfaces
The Up2stream AMP 2.1 comes with a range of ready-to-use interfaces, including a 3.5mm line in, micro USB audio input, speaker output and a plug for SPDIF in, Line in, LED indicator, IR extension, and ADC-key. Which enables you to create a flexible system according to your specific needs. With these features, you can easily connect your audio devices and enjoy high-quality sound without any complicated setup.
Multiroom/ Multizone
The Arylic streaming devices come with a unique feature that allows you to quickly access them by inputting the device's IP address into your browser. This means you don't need to install any app or software to access the device's settings.
Using this feature, you can easily set your preset content, EQ controls, playback options, and even update the device's firmware. With this feature, you can quickly access and control your Arylic streaming devices, making it easy to enjoy high-quality audio with minimal setup time.
Enhanced Up2stream
The Up2stream AMP 2.1 offers several optional expansion boards that can be used to enhance its functionality and performance. These expansion boards include the Up2stream SPDIF board, Up2stream button board, and Up2stream IR extension board. Each of these expansion boards provides unique features and capabilities that can be used to customize and improve the performance of your Up2stream AMP 2.1 device. You can find all the boards in Accessories.
USB Sound Card for PC
Once you connect the Up2stream AMP 2.1 to your PC, it will be detected as a USB sound card. This allows you to stream audio from your PC directly to other devices connected to the Up2stream AMP 2.1. This feature provides a convenient way to extend your audio playback capabilities beyond your PC. Support both Windows & Mac PC.
ACPWorkbench Tuning Tool
The Up2stream AMP 2.1 offers a range of communication options, including HTTP API, UART, and TCP commands, providing flexibility for users to integrate the device into their existing smart home systems or to develop custom applications. Get API files below in the download portion and check the cases in our forum.
Functional Knob Control
The Up2stream AMP 2.1 features 3 rotary knobs that enable effortless adjustment of volume, treble, and bass. However, these knobs also facilitate adjustments to the crossover frequency and mode switching. In addition to controlling sound characteristics, the Up2stream AMP 2.1 provides versatile functionality for a customized listening experience.
Optional Remote Control
The optional remote control is a useful addition to the Up2stream AMP, providing an easy and convenient way to control your music playback from a distance. Like play/pause, deep bass, adjust volume, and quick switch preset content from a distance.
*Up2stream AMP 2.1 need ACPWorkbench tuning tool to switch the spdif configuration from spdif in to spdif out.
WiFi:
IEEE802.11 b/g/n 2.4G
Bluetooth:
Wired Network:
12V-24V/DC in
Analog:
3.5mm Line Input (1 Vrms)
Digital:
Micro USB Input
*SPDIF In pin connector
Analog:
Speaker Out and Subwoofer Out
LED pin connector
IR pin connector
Button pin connector
GPIO pin connector
TPA3116D2*2
2x50W@4Ω + 100W@2Ω BTL load at 24V
2x30W@8Ω + 75W@4Ω BTL load at 24V
2x22W@8Ω + 48W@4Ω BTL load at 19V
2x15W@8Ω + 30W@4Ω m BLT load at 15V
4-8Ω (Stereo)/2-4Ω(Sub)
20Hz to 20kHz
<0.03%, @1kHz/1W/24V/4Ω
Support NAS with DLNA support
Dimensions:
124*100*25mm
Weight:
500g
Working temperature:
220mm Internal WiFi Antenna x2
Knob Cover x3
6Pin Phoenix Connector
Screw Driver
User Manual
Power Button
Device on:
Long press once: Switch off
Device off:
Short press: Switch on
Volume Knob
Treble Knob
(Crossover frequency range from 80-200Hz, default 110hz)
Bass Knob
⚪White-WiFi & network mode:
Solid- WiFi is connected
🔵Blue-Bluetooth mode:
Solid- Bluetooth is connected
🟢Green-Line in mode
🔴Red-USB mode
🟡Yellow-connect to PC
2.1(L+R+Sub)
2.1(L+R+Sub)
Mono
2 x 50W + 100W
2 x 50W + 100W
100W(Mono)
2 x 50W(Stereo)
Aux In(3.5mm Jack & Pin)
Aux In(3.5mm Jack)
Spdif In(Pin)
Optical In
Spdif In(Pin)
Subwoofer Out
Stereo-Aux Out(Pin)
Mono out(Pin)
I2S Out(Pin)
TPA3116D2*2
TPA3116D2*2
TPA3116D2
44.1khz/16bits(CD)
44.1khz/16bits(CD)
44.1khz/16bits(CD)
Optional
*①Optional
Optional
Yes(Volume, Treble, Bass)
Spdif In Board
*②Spdif Out Board
Button Board
IR Sensor Board
ADC-KEY Board
Button Board
*③IR Sensor Board
Spdif In Board
*②Spdif Out Board
Button Board
Volume Knob Board
IR Sensor Board
For Boombox
For Boombox
Build Your Wireless Projects
Wireless Boombox
Shared by Gene Giesbrecht
Power Your Subwoofer
Shared by Jaime Mota
DIY 2.1 Amplifier
Shared by Oscar Wenstedt
Build 2.1 Multiroom System
Shared by Justin Murphy
Yes, that is available.
此產品的評價:4.9 / 5.0 顆星。
已收到 76 則評價。
