BK501/651 2 Way Bookshelf Speakers
-100W, HiFi sound.
- High-end Heil AMT Tweeter.
- Treble up to 40khz, feel detailed treble clarity and brightness.
- 180° Wide soundstage, enjoy high quality pure vocals and instruments in every corner.
-Innovative design of 5"/6.5" Fiber glass Mid-woofer with outstanding heat dissipation and no distortion.
-FSC Environmental Certification
- 15mm (BK501) - 18mm (BK651) super thick MDF cabinet design.
Your Brilliant HiFi Bookshelf Speakers at Home
BK501/651 is a passive speaker that built for HiFi stereo sound system. You can feel the surprising crystal clear and bright treble, full midrange, fantastic deep bass and dynamic sound.
With our sonically engineering construction design, you can hear every details from the original sound.
Enjoy Pure Sound Of Vocals and Instruments
The treble high-frequency can go up to 40Khz, which delivers clean, detailed, and highly dynamic output.
It also can wider treble soundstage to 180°, makes you listening to high quality music in any corner. Enjoy immersive concert in your rooms.
Powerful HiFi Mid-Woofer
The 6.5" mid-woofer of BK501/651 bookshelf speaker uses glass fibre cone, S-type paper cone and air permeability design. Which can enhance the sound transmission much longer, lower the attenuation and have better heat dissipation.
Let you enjoy the full and revealing midrange and powerful bass in your home theater system. No longer have to worry about putting too loud bass will have the problem of distortion.
Scientific Speaker Cabinet Design
BK501/651's cabinet is made of thickened15-18mmMDF and scientific inverted phase tube, which is developed by experienced acoustic engineers after more than 900 days of research and development with professional acoustic tools.
Precisely calculated volume and cabinet design can reduce resonance and slant vibration noise, brings you incredible sound enjoyments.
Perfect Match In Your Rooms
The compact size and design make it easy to drive and perfect to put in any rooms at your home. Like living room, dining room, bedroom, garage etc.
Focus On Every Details
FSC Eco-friendly Certification
Handcrafted eco-friendly wood veneer.
Removable Magnetic Dust Cover
Classic aesthetic look and protective.
Pure Copper Crystal Terminal
Anti-oxidation, easy to install.
Transparent UV paint
Drop-proof, moisture-proof, moth-proof
Strong Protected Package
* Subject to technical change.
BK501
BK651
2 way
2 way
40/80 Watts
50/100 Watts
4 ohms
4 ohms
4-8 ohms
4-8 ohms
54-40000 Hz
42-40000 Hz
>30 W
>30 W
85 dB
86 dB
300×170×253mm
350X204×289mm
Silicone pads & Drying agent
Will the bookshelf speakers fit in my bedroom?
Arylic bookshelf speakers can handle maximum 100W power, which can satisfy a room of 15 square meters. Please use it to meet your needs fully.
What kind of music are the bookshelf speakers suitable for listening to?
The bookshelf speakers have a three-band balance, the treble is transparent and not harsh, the midrange is full, and the bass is deep and powerful. For most music, there are good results. Suitable for the following types of music: Classical, Pop, Jazz, Hip-Hop&Rap, Country, Folk, R&B, Rock, Soul, Gospel, New Age, Electronic Dance, Musical, etc.
Can I use the Arylic bookshelf speakers as an external speakers for my TV and computer?
The Arylic bookshelf speakers can dramatically improve sound quality of your computer and TV. However, these bookshelf speakers are passive and must be used with a separate stereo amplifier. Arylic A30+ and A50+ are good choices.
Which is better, the bookshelf speaker or the sound bar?
Soundbars tend to be more feature-rich than bookshelf speakers, especially regarding connectivity and surround sound capabilities. Bookshelf speakers cost more and sound better than soundbars.
Can this bookshelf speaker connect to Bluetooth and wifi?
This bookshelf speaker is passive; it does not have Bluetooth or wifi functions. However, you can buy a stereo amplifier with Bluetooth and wifi functions to connect via Bluetooth or even SPDIF interface, network cable, and u disk. Arylic A50+ and A30+ stereo amplifiers can fit your needs. And B50 Bluetooth amplifier for wired speakers.
Are bookshelf speakers worth buying?
A great pair of bookshelf speakers is one of the best investments a music lover can make. With proper use and storage, it should last for many years. And it has better performance than the popular all-in-one Bluetooth, wifi speakers, and soundbars.
Do I need to buy an extra subwoofer for the bookshelf speakers?
Arylic's bookshelf speakers include a 6.5-inch mid-wooder with great bass. Which is enough for usuall playing, but if you are looking for a more striking feeling like party music. Buying an additional subwoofer is a option for better entertainment.
Can this bookshelf speaker be used to listen to vocals?
Yes, very suitable. We have made a special optimization for the high frequency of the human voice. The bookshelf speakers use Heil AMT Tweeter. The treble high-frequency can go up to 40Khz, which delivers clean, detailed, and highly dynamic output.
It also can wider treble soundstage to 180°, making you listen to high-quality music in any corner. Enjoy an immersive concert in your rooms.
此產品的評價:5.0 / 5.0 顆星。
已收到 2 則評價。
