BR10 Bluetooth Audio Receiver
- Add Bluetooth receiver capability to your vintage stereo.
- Play HD music wirelessly with aptx, aptX HD and aptX Adaptive.
- Rich Interfaces: Optical Out, Line In/Out, Type-C DAC input, USB Host.
- Sync Playback: Supports simultaneous output via line out and optical out connectors.
- Easy to use: Free iOS & Android APP, easy and convenient to use for everyone.
BR10 x1, User's Manual x1, Aux 3.5mm Cable x1, 2-1 RCA Cable x1, Power Adapter x1, USB Type-C Cble x1, Remote Control x1
Upgrade Your Vintage Stereo To Bluetooth
Play any music from your smartphone wirelessly to your vintage stereo.
Small But Powerful
Plug And Play
Once you've connected your amplifier, AV receiver, or active speaker to the BR10 and powered on the device, simply pair via Bluetooth to start enjoying wireless music playback.
HD Music
Equipped with the advanced Qualcomm QCC3040 Bluetooth chip, the BR10 supports high-quality codecs including aptX, aptX HD, aptX Adaptive, and AAC. Immerse yourself in your favorite music with minimal distortion and CD-level sound quality.
*To use aptX formats, make sure your devices are supported.
Smooth and Stable Connection
BR10 supports true 15-meter long-range wireless transmission. Enjoy an uninterrupted, smooth listening experience all day.
Compatible To Your Bluetooth Deivces
Able to connect with Bluetooth 5.4, 5.3, 5.2, 5.0, and 4.0. The BR10 can easily pair with most of your Bluetooth devices.
Bluetooth Receiver For Your Sound System
Enable your vintage audio gears with wireless Bluetooth playback.
Play HQ digital music from via Type-C port.
Play your favorite song playlists from your USB stick.
Watch movie, sport games, or talk shows wirelessly from your smart TV and connect optical to your soundbar.
Use BR10 as an analog and digital audio converter.
Sync Playback
BR10 supports simultaneous output via line out and optical out connectors. Enjoy a more immersive listening experience with sync playback.
Multiple Ways To Control
Personalize Your Music Style
Custom EQ
Tune Like A Pro
Compact And Save Your Space
5.2, 15m
2x Bluetooth RX, able to connect up to 2 Bluetooth transmitter devices.
aptX HD, aptX, aptX AD, AAC, SBC
0004-ef336b27
20Hz to 20Khz
3.5mm analog earphone jack, Max 2V RMS input
3.5mm analog earphone jack, Max 2V RMS Output
Up to 192kHz/24bit PCM only
Support codec: mp3, mp4, wma, mov, m4a, aac, flac(96kHz/24bit), ape
5V/1A Type-C
108 x 72 x 26.6mm
89g
Which Wireless Audio receiver Are Made For You ?
Not sure which one to choose? We selected our most popular wireless audio receivers. Compare them and choose the best version for your needs.
Click Learn More Below To Check All Products Comparison Table.
Bluetooth 5.0
Bluetooth 5.0
aptX, aptX HD, aptX adaptive, SBC, AAC
SBC, AAC
5V/1A Type-C
12V/1A DC Input
5V/1A Type-C
Aux In
Aux In
Type-C DAC
Opt In
Type-C DAC
Type-C DAC
Aux Out
DAC: Integrated
DAC: ESS 9023P
Aux Out
DAC: Integrated
Opt Out
Opt Out
Coax Out
Opt Out
Decode up to 192khz/24bits
Output 44.1khz/16bits(CD)
What is the maximum range of this Bluetooth receiver?
It is 15m.
What Bluetooth codes does BR10 support?
It support SBC, AAC, aptX, aptX HD and aptX adaptive.
Does BR10 support USB playlist?
Yes. You can use our GO CONTROL app to play with your USB and check the playlist and songs.
此產品的評價:5.0 / 5.0 顆星。
已收到 4 則評價。
