B50 SE Bluetooth Stereo Amplifier
- 50W x 2 Powerful Bluetooth Stereo Amplifier for Home
- TPA3116D2 Amplifier Chip with High Efficiency and Low Distortion.
- Bluetooth 5.0, Turn Your Old Speakers into Bluetooth.
- 15M Long Distance Transmittion and Low lantency.
- Free iOS & Android Go CONTROL APP with EQ.
Enjoy Cinema Experience At Home
B50 SE is a Bluetooth stereo amplifier can power your passive speakers, active subwoofers and integrate your existing stereo system with it's rich interfaces. Easy to play with Bluetooth 5.0, and enjoy cinema like sound experience at your home.
B50 SE is a perfert Bluetooth stereo amplifier and bluetooth amplifier for wired speakers to fit any home usage. It can drive 30W x 2(8 ohms), 50W x 2(4 ohms) speakers for best sound performance.
Add Bluetooth Features to Your Speakers.
Make your speakers into Bluetooth-enabled, play any music you like wirelessly from phone, tablet, Laptop/PC and other audio gear.
Smoothly Sound Enjoyments
B50 SE Bluetooth amp delivers nearly imperceptible latency and stable Bluetooth transmission >10 meters in distance.
No matter you are watching movie, listening to music, gaming or wine time, you can have a smoothtly sound enjoyments without stuttering and interrupts with a good mood.
Compatible to Your All Audio Gears
GO CONTROL APP
Personalized EQ
Your can use the default EQ settings or custom your EQ settings with more bass, treble or vocals In Go Control App.
Enhance your listening experience with different music!
Simple To Operate
Easy to pair and manage All Arylic Bluetooth devices in one App. Remotely audio source change, EQ, L/R balance, device info, and more helpful features.
Custom Theme
GO CONTROL APP support to switch the theme between dark mode and light mode. What's more, you can change the theme color based on your flavor!
Tune Your Own Sound
Functionality Remote Control
0051-933309b3
5.0, 10m
AAC, SBC
24V 4Ω 50W x 2
24V 8Ω 30W x 2
4 - 8Ω
20Hz to 20Khz
<0.1% @ 1W 1kHz
>93dB @ Max Power
Analog RCA, Max 2V RMS input
Up to 192kHz/24bit
PCM Only
Support codec: mp3, mp4, wma, mov, m4a, aac, flac(96kHz/24bit), ape
Max 3V RMS output, cutting frequency: 250Hz
50W per channel @ 4Ω
24V/4.16A
185 x 155 x 50mm
750g
Bluetooth 5.0
50W x 2
50W x 2
50W x 2
Phono in
Sub out
Sub out
Sub out
USB Type - C
USB Type - C
Micro USB in
48khz/16bits
48khz/16bits
44.1khz/16bits
GO CONTROL
GO CONTROL
4STREAM
此產品的評價:4.8 / 5.0 顆星。
已收到 20 則評價。
