CK30C 3" 60W Coaxial HD In-ceiling Speaker
- Compact size, 60W big sound.
- 5" In-ceiling speaker bass level. ( 5" In-ceiling speaker sensitivity level)
- IP66 protects against dust and water.
- Easy installation with pre-installed dog leg clamps and press-fit speaker connectors.
- Spotlight diameter, used as a chandelier or pendant speaker.
Advanced acoustic design
More Clear, Transparent, and Big Sound
Featuring a 16-core silk membrane tweeter, this speaker extends the high frequency to 30kHz. It also includes a special customized equalizer that optimizes the high-frequency curve, resulting in brighter treble, excellent resolution, and enhanced vocal detail performance. This makes it a favorite choice among music lovers.
Enhanced sound field
Subwoofer Unit and Vibration Plate
Adopts a passive radiator radiator that conforms to the acoustic volume patent, which enhances the volume of the cabinet and strengthens the low-frequency sink and soundstage
Meets IP66 Rating Standard
Suitable for bathroom or outdoor rooftop.(*Waterproof Achieving IP66 Standard from Arylic laboratory test)
Reliable Quality
The fully sealed back cover design ensures optimal resonance for enhanced sound quality. Crafted from ABS material, the shell is both cold and high-temperature resistant, offering protection against dust to prolong the service life of the CK30C speakers.
Application Scenarios
The CK30C in-ceiling speaker is incredibly versatile.
3 Mins Easy Installation
CK30C
30W
60W
216-25kHz
85dB
96dB
4Ohm/6Ohm
Coaxial treble
Aluminum
180°
Quick installation
ABS plastic
IP66
3 inches
100mm
100mm
0.40 kg
Which Wireless Amplifier Are Best Match For You?
Arylic wireless amplifier is the best partner for CK30C. We selected our most popular wireless stereo amplifiers. Compare them and choose the perfect match for your needs.
H50+CK30C
Best For AirPlay 2
B50+CK30C
Best for TV
A50+ +CK30C
Best For Wireless BGM
WiFi, AirPlay, Spotify Connect, Bluetooth 5.2 aptX HD
50W x 2
50W x 2
50W x 2
Phono in
Phono in
Sub out
Sub out
Sub out
USB Type - C
USB Type - C
Micro USB in
48khz/16bits
48khz/16bits
44.1khz/16bits
GO CONTROL
GO CONTROL
4 STREAM
此產品的評價:5.0 / 5.0 顆星。
已收到 3 則評價。
