The most powerful Arylic amp ever.
Best SellerTop Sound
促銷價$239.00
  • 100W x 2ch, stereo amplifier to power your passive speakers.
  • WiFi, AirPlay, Spotify Connect, Bluetooth wireless streaming.
  • Listening to local FM radio and customizable preset stations.
  • KTV singing and broadcasting with any audio sources supported.
  • Online music services, NAS, Phono in, optical in and more audio sources support.
Bulk Discount
有庫存
30 days free return
Expert customer support
1 Year warranty
Redefine
All-in-one
Power amplifier + music streamer + FM radio + KTV = A100
AirPlay
Airplay
FM Radio
FM Radio
KTV
KTV
Rich Music Sources
Rich Music Services
HD Music
ESS Sabre 9023P DAC
multiroom
Built-in power supply
APP Control
EQ Control
200W
Get The Most Powerul For 100W Each Channel Than Before
TPA3255 Amp Chip
Mono/Stereo Switcher
Effortless Streaming
Power up the A100 amplifier and connect it to your passive speakers.
Plug in your vinyl player, TV, or CD player with audio cables, or stream your favorite music wirelessly from your phone. Everything is easy to control directly from your smart devices.
Made For Sound
Enjoy the HD sound with the high-quality ESS 9023P DAC. Bring impressive sound experience for movie, music and gaming moments.
Click below to explore more sound features >
Built-in AC Power
The A100's built-in AC power ensures a stable and consistent energy supply, eliminating the need for external adapters.
This design simplifies setup, reduces clutter, enhances dynamic range, and improves the signal-to-noise ratio, delivering smooth and uninterrupted audio playback.
Customizable EQ
For A100, you can customize your favorite audio effect via the display and knob control or from our 4STREAM and GO CONTROL APP.
Not Only An Amplifier, But Also A FM Radio
mic input x 2, support singing with any audio sources.
KTV at Home Anytime
support broadcasting with any audio sources.
Brocasting for Your Shop
Analog input
Line In Input your TV, CD player etc.
Phono In For your turntable, and don't forget connect with the GND.
Digital Input and Analog Output
Line Out Allow you use as preamp, connect to your amplifier.
Coax In Connect from DVD player, Blu-ray player, etc.
OPT-In Connect from TV, gaming console, etc.
Built-in AC Power
Improve the power stability and sound performance.
Banana Connector
Connect to your passive speaker
Lan Port Connect to your WiFi router for better network stability and easy pairing.
USB Back Connect your USB stick, up to 1000 songs.
MO/ST Mono and stereo channel switcher.
Listen To Your Favorites
Explore 15+ music services supported like Spotify, Amazon Music, Tidal, Qobuz, TuneIn, BBC Radio, Internet Radio, NAS, and more.
Whole House Audio System
multiroom audio
Sync Music Across Rooms
You can play the same audio simultaneously in any room equipped with Arylic streaming devices.
Play Different Audio Sources At The Same Time
Multizone Group
Easy And Full Multiroom Control
Multizone Group
multiroom audio
Local Control with OLED Display
Lan
The Lan port of A100 allows you to connect to the network directly by Lan cable. Plug and connect without WiFi pairing and enjoy a stable network.
Based on 31 reviews
68%
(21)
29%
(9)
3%
(1)
A
Augusto Rodrigues Caçao
Estou satisfeito com o som do A100, não imaginei que fosse tão bom, mas precisa de um subwoofer.
O menu de visualização é pequeno tem de dar mais informação. Os conectores das colunas são muito fracos e frágeis, não compatível com o potencial do aparelho.
L
Luc Vandestraten
P
PaBi
A100
Suggestions
FM receiver should be also digital.
Loudness of FM is lower than other.
ON-OFF control in app
Wifi adjust change through the app
Internal components are not properly fixed , when you turn A100 something is moving inside
C
Chackravarthi Balu
Love the product gr8 quality value for Money
MUTHUSAMI SUBRAMANIAN
A100 Stereo Amplifier
Package received in good condition. However, the A100 unit seems to be a open box item as the inner box is not sealed. Usually, all new items comes with a seal.
Sound quality is decent.
B
Burton Bridges
Great amp
Much better amp than I expected. The base boost is great. The remote app could have a better look, but it works.
