Audio streamer
LP10 Music Streamer
Easy Streaming For Everyone
AirPlay 2NEW
促銷價$99.00
有庫存
Bulk Discount
Share and Earn
Free local shipping in US & EU
30 days free return
Expert customer support
1 Year warranty
So Easy
Google Cast 96kHz/24bit
Multiroom Streaming
Hi-Res Audio
192kHz
24bit
Lan Port
USB Stick
Line In/Line out
Type C Port
For 5V-2A DC power input.
5G High Speed Streaming
Plug And Play
More Ways To Control
Based on 42 reviews
74%
(31)
26%
(11)
R
Ranadewa Fernando
LP10 streamer
i was listening to Apple and Spotify music through my laptop, once i connected the LP10 i could hear a big difference in the quality.
thank you,
cheers
A
Andrius Grudzinskas
Good but not great Arylic LP10
I got Arylic LP10. The transaction was super easy, order wet smooth and delivery was fast. Device itself straight forward and easy to install. Chromecast works good, but can't get sound throug Apple AirPlay 2. Wrote couple times regarding this issue, but no response.
J
Julio
Sounds great
I bought this LP10 to replace my Muzo Cobblestone and it's a surprisingly sophisticated upgrade to that old Linkplay unit. The audio quality is noticeably so much better and the Spotify Connect integration is really nice. The unit looks solid and the display is simple but attractive. It's great to have additional inputs for line-in and USB and the remote control is a useful bonus. I'm really enjoying it.
My only cavil is that the wifi setup process is primitive and it lacks support for WPS. It didn't support emojis in my network ID and the only workaround was to rename my network and change the settings on all my other connected household devices which was painful. (Most people might say I was asking for it).
M AU
Adding auto standby ?
Adding auto standby will be great. Or may be on/off control from google home.
T
Timothy Schoen
Works perfectly!
B
BH
Works great for audio, but could use some QoL upgradea
Everything works great. The only thing I wish it had was smart source switching if it detects an audio source from one of the other inputs. It also would be nice to be able to have a sleep mode where it turns on if you start an audio stream. Other than than, set up and functionality are great.
