- Easy switch between stereo and mono mode.
- Maximum 50W x 2 powerful output of stereo mode and 100W powerful output of mono mode.
Up2stream AMP
Up2Stream AMP is an amplifier board equipped with both WiFi, Airplay, Spotify Connect and Bluetooth 5.0, designed to enable your existing audio system with wireless capabilities. It offers a comprehensive solution for DIY enthusiasts who want to create a personalized wireless audio system.
The Up2Stream AMP has the ability to switch between stereo and mono mode. In stereo mode, it delivers up to 50W of power for both left and right channels, while in mono mode, it can provide a maximum of 100W for a single channel by mixing the left and right channels.
Features
Wireless Connectivity
Up2stream AMP supports WiFi and Bluetooth 5.0, allowing for easy streaming of music from various sources such as smart phones, tablet, laptop, and computer within your local network. Additionally, the device supports popular protocols such as Airplay, Spotify connect, DLNA, and UPnP, providing seamless wireless music streaming capabilities.
Up2Stream AMP features an RJ45 Ethernet port for a more stable network connection. This allows you to directly stream music from your smart devices without having to go through the WiFi setup process using the app. This feature makes it super easy to get started and enjoy your music quickly and effortlessly.
Mono/Stereo Mode
The Up2stream AMP is a versatile amplifier board that can function as both a stereo and mono amplifier. You can easily toggle between these modes using the jumper located on the board. This means you have the flexibility to use the board in either stereo or mono configurations depending on your needs.
Powerful Home Amplifier Board/Bluetooth Amplifier Board
Under stereo mode, the Up2stream AMP, a Bluetooth amplifier board, is capable of delivering a maximum power output of 50W x 2 at 4ohm and 24V. However, when switched to mono mode, it can deliver up to 100W of maximum power output at 4ohm and 24V. This means that the board can provide a higher power output when used in mono mode compared to stereo mode. The Bluetooth capability allows for convenient wireless streaming, enhancing its versatility and usability in various audio setups.
Lossless Audio
The Up2stream AMP is designed to support a broad range of lossless audio formats, including FLAC, MP3, AAC, AAC+, ALAC, APE, and WAV. Furthermore, the board can decoding up to 192kHz/24bits, and providing high-quality audio output with a resolution of 44.1kHz/16bits CD quality. The Up2stream AMP also delivers impressive sound with the TPA3116D2 amplifier chip used in its design. This chip provides powerful amplification to bring out the best in your audio.
Music Services Support
Versatile Music Sources
The Up2stream AMP offers versatile streaming options, allowing you to easily stream music from various sources such as music services, NAS, USB, phone storage, SD card, and other 3rd-party apps that support Airplay, DLNA, and UPnP protocols. This provides you with a wide range of choices when it comes to selecting your preferred music source. Additionally, the device comes with Bluetooth 5.0, enabling you to stream audio from your smart devices seamlessly. This means you can enjoy your favorite music on the go, without the need for any additional cables or devices. With its multiple streaming options, the Up2stream AMP makes it easy to enjoy high-quality sound from a variety of sources.
Multiple Interfaces
The Up2stream AMP comes with a range of ready-to-use interfaces, including a 3.5mm line in, micro USB audio input, speker output and a plug for SPDIF in, Line in, Line out,Mono out, LED indicator, IR extention, and ADC-key. Which enables you to create a flexible system according to your specific needs. With these features, you can easily connect your audio devices and enjoy high-quality sound without any complicated setup.
Multiroom/ Multizone
Enhanced Up2stream
The Up2stream AMP offers several optional expansion boards that can be used to enhance its functionality and performance. These expansion boards include the Up2stream SPDIF board, Up2stream button board,, Up2stream IR extension board, and Up2stream volume knob board. Each of these expansion boards provides unique features and capabilities that can be used to customize and improve the performance of your Up2stream AMP device. You can find all the boards in Accessories.
USB Sound Card for PC
Once you connect the Up2stream AMP to your PC, it will be detected as a USB sound card. This allows you to stream audio from your PC directly to other devices connected to the Up2stream AMP. This feature provides a convenient way to extend your audio playback capabilities beyond your PC. Support both Windows & Mac PC.
ACPWorkbench Tuning Tool
The Up2stream AMP offers a range of communication options, including HTTP API, UART, and TCP commands, providing flexibility for users to integrate the device into their existing smart home systems or to develop custom applications. Get API files below in the download portion and check the cases in our forum.
Optional Remote Control
the optional remote control is a useful addition to the Up2stream AMP, providing an easy and convenient way to control your music playback from a distance. Like play/pause, deep bass, adjust volume, and quick switch preset content from a distance.Whether you're listening to music in your living room or in another part of your home, the remote control makes it easy to adjust your settings and enjoy your music to the fullest.
WiFi:
IEEE802.11 b/g/n 2.4G
Bluetooth:
Wired Network:
12V-24V/DC in
12V-24V 2Pin Connector
Analog:
3.5mm Line Input (1 Vrms)
Digital:
Micro USB Input
*SPDIF In pin connector
Analog:
LED pin connector
IR pin connector
Button pin connector
Rotary encoder pin connector
GPIO pin connector
Mono Out pin connector
TPA3116D2
Stereo:
2x50W @ 4ohm load at 21V
2x30W @ 8ohm load at 24V
2x15W @ 8ohm load at 15V
Mono:
100W @ 2ohm load at 24V
60W @ 4ohm load at 21V
30W @ 8ohm load at 18V
4-8Ω
20Hz to 20kHz
91dB/0.03%, @1kHz 50W+50W 24V-4Ω
Support NAS with DLNA support
Dimensions:
110*80*22mm
Weight:
300g
Working temperature:
220mm Internal WiFi Antenna x2
4Pin Phoenix Connector
Screw Driver
User Manual
Device on:
Long press once: Switch off
Device off:
Short press: Switch on
⚪White-WiFi & network mode:
Solid- WiFi is connected
🔵Blue-Bluetooth mode:
Solid- Bluetooth is connected
🟢Green-Line in mode
🔴Red-USB mode
🟡Yellow-connect to PC
🟣Purple-Spdif in mode
Mono
2.1(L+R+Sub)
100W(Mono)
2 x 50W(Stereo)
2 x 50W + 100W
2 x 40W
Aux In(3.5mm Jack & Pin)
Aux In(3.5mm Jack)
Spdif In(Pin)
Spdif In(Pin)
Spdif In(Pin)
Stereo-Aux Out(Pin)
Mono out(Pin)
I2S Out(Pin)
TPA3116D2
TPA3116D2*2
ma12070p
44.1khz/16bits(CD)
44.1khz/16bits(CD)
44.1khz/16bits(CD)
Optional
Optional
*①Optional
Yes(Volume, Treble, Bass)
Spdif In Board
*②Spdif Out Board
Button Board
Volume Knob Board
IR Sensor Board
Spdif In Board
*②Spdif Out Board
Button Board
IR Sensor Board
Spdif In Board
*②Spdif Out Board
Button Board
*③IR Sensor Board
For Boombox
Build Your Wireless Projects
Wireless Mono Speaker
Shared by Janosch Petry
DIY Artist Wireless Speaker
Shared by Christoph Klecker
Build Multiroom Amplifier
Shared by Martijn Koopman
Shared by Alexis
What is the different between Up2stream Amp Board and Up2stream Amp Mono Board?
Actually they are same board. For customers can easily find their needs, we design for different pages for better nevigation.
Yes, that is available.
此產品的評價:4.9 / 5.0 顆星。
已收到 210 則評價。
