Up2Stream Plate Amp - Multiroom Wireless Plate Amp
促銷價$119.00 原價$169.00
已售完
  • Super easy to install with plate amp, build your wireless speakers without complicated skills.
  • Maximum 40W x 2 powerful output of stereo mode.
  • ma12070p amplifier chip for better amplification and high sound performance.
✔Fast & Free Shipping
Up2stream Plate Amp
The Up2Stream Plate AMP is an excellent WiFi and Bluetooth 5.0 stereo plate amplifier that enables you to effortlessly incorporate high-quality wireless streaming into your speakers. This Class D plate amplifier is a complete range device that provides 40W L&R channels, a 3.5mm Aux input, a USB input for PC connection, a Speaker out for the Right channel, and a Subwoofer out for an active subwoofer.
Once you connect it to your home network, you can use our 4STREAM APP to play music from your mobile device, NAS, or online streaming services such as Spotify, Deezer, Tidal, Qobuz, and many others. The wireless multiroom audio system can play the same music in sync throughout all rooms with multiple devices, or you can play different music in different rooms.
Overall, the Up2Stream Plate AMP is an excellent addition to your home audio system, providing high-quality wireless streaming capabilities and the convenience of multiroom audio playback.
Features
Wireless Connectivity
Up2stream Plate Amp supports WiFi and Bluetooth 5.0, allowing for easy streaming of music from various sources such as smart phones, tablet, laptop, and computer within your local network. Additionally, the device supports popular protocols such as Airplay, Spotify connect, DLNA, and UPnP, providing seamless wireless music streaming capabilities.
Up2Stream Plate Amp features an RJ45 Ethernet port for a more stable network connection. This allows you to directly stream music from your smart devices without having to go through the WiFi setup process using the app. This feature makes it super easy to get started and enjoy your music quickly and effortlessly.
Easy To Install
The Up2stream Plate Amp is an amplifier board specifically designed for DIY enthusiasts. The board comes equipped with pre-wired connection ports and a power adapter, making it incredibly easy to install onto your speaker cabinet. All you need to do is connect it to your speaker, and you're good to go. This board is exceptionally user-friendly, saving you time and effort compared to other amplifier boards.
Powerful Home Amplifier
The Up2stream Plate Amp delivers an impressive maximum power output of 40Watts for both the left and right channels, making it an excellent choice for your home speaker projects. Whether you're building bookshelf speakers, a center speaker, or customizing your own stereo speakers, this amplifier board provides ample power to drive your speakers with exceptional performance.
High-performance Plate Amp
The Up2stream Plate Amp is equipped with the advanced ma12070p amplifier chip, which delivers outstanding amplification and superior sound performance. With this cutting-edge technology, you can enjoy high-quality audio output with exceptional clarity and precision.
Lossless Audio
The Up2stream Plate Amp is designed to support a broad range of lossless audio formats, including FLAC, MP3, AAC, AAC+, ALAC, APE, and WAV. Furthermore, the board can decoding up to 192kHz/24bits, and providing high-quality audio output with a resolution of 44.1kHz/16bits CD quality.
Music Services Support
Versatile Music Sources
The Up2stream Plate Amp offers versatile streaming options, allowing you to easily stream music from various sources such as music services, NAS, phone storage, SD card, and other 3rd-party apps that support Airplay, DLNA, and UPnP protocols.
This provides you with a wide range of choices when it comes to selecting your preferred music source. Additionally, the device comes with Bluetooth 5.0, enabling you to stream audio from your smart devices seamlessly. This means you can enjoy your favorite music on the go, without the need for any additional cables or devices. With its multiple streaming options, the Up2stream Plate Amp makes it easy to enjoy high-quality sound from a variety of sources.
Multiple Interfaces
The Up2stream Plate Amp comes with a range of ready-to-use interfaces, including a 3.5mm line in, USB A audio input, speaker output and extension plug for SPDIF in, Button Board, and IR receiver. Which enables you to create a flexible system according to your specific needs. With these features, you can easily connect your audio devices and enjoy high-quality sound without any complicated setup.
Multiroom/ Multizone
This means you don't need to install any app or software to access the device's settings. Using this feature, you can easily set your preset content, EQ controls, playback options, and even update the device's firmware. With this feature, you can quickly access and control your Arylic streaming devices, making it easy to enjoy high-quality audio with minimal setup time.
Enhanced Up2stream
The Up2stream Plate Amp offers several optional expansion boards that can be used to enhance its functionality and performance. These expansion boards include the Up2stream SPDIF board, Up2stream button board and Up2stream IR extension board.
Each of these expansion boards provides unique features and capabilities that can be used to customize and improve the performance of your Up2stream Plate Amp device. You can find all the boards in Accessories.*Installation requires wiring on demand
USB Sound Card for PC
Once you connect the Up2stream Plate Amp to your PC, it will be detected as a USB sound card. This allows you to stream audio from your PC directly to other devices connected to the Up2stream Plate Amp. This feature provides a convenient way to extend your audio playback capabilities beyond your PC. Support both Windows & Mac PC.
ACPWorkbench Tuning Tool
Our proprietary ACPWorkbench software provides a powerful tool to customize and optimize the DSP settings of each unit of the Arylic streaming devices.
This software allows you to adjust a range of settings, including L/R balance, frequency of every channel, pregain, and more. By fine-tuning these settings, you can achieve optimal audio performance and tailor the sound to your preferences.In addition to DSP settings customization, the ACPWorkbench software also supports local firmware updates, define pins and configure other settings.
The Up2stream Plate Amp offers a range of communication options, including HTTP API, UART, and TCP commands, providing flexibility for users to integrate the device into their existing smart home systems or to develop custom applications. Get API files below in the download portion and check the cases in our forum.
Optional Remote Control
the optional remote control is a useful addition to the Up2stream Plate Amp, providing an easy and convenient way to control your music playback from a distance. Like play/pause, deep bass, adjust volume, and quick switch preset content from a distance.Whether you're listening to music in your living room or in another part of your home, the remote control makes it easy to adjust your settings and enjoy your music to the fullest.
*There is no IR sensor on Up2stream Plate Amp, you may need to add IR sensor board if you want to use remote control.
*Up2stream Plate Amp need ACPWorkbench tuning tool to switch the spdif configuration from spdif in to spdif out.
Latest Firmware Version
Connectivity
WiFi:
IEEE802.11 b/g/n 2.4G
Bluetooth:
Wired Network:
Power Supply
AC100-240V 50/60Hz 1A
Audio Input
Analog:
3.5mm Line Input (1 Vrms)
Digital:
USB A Input
SPDIF In pin connector
Audio output
Analog:
Subwoofer Output (20-300Hz Max 2V RMS)
Left Channel Speaker Out
Right Channel Speaker Pin Out
Other I/O Interface
LED pin connector
IR pin connector
Button pin connector
Amplifier Chip
ma12070p
Speaker Power
40W x2 @4Ω
20W x2 @8Ω
Speaker Impedance
4-8Ω
Frequency response
20Hz to 20kHz
Audio Channel
Mono
2.1(L+R+Sub)
Music Service
2 x 40W
100W(Mono)
2 x 50W(Stereo)
2 x 50W + 100W
Analog Audio Input
Aux In(3.5mm Jack)
Aux In(3.5mm Jack & Pin)
Digital Audio Input
Spdif In(Pin)
Spdif In(Pin)
Spdif In(Pin)
Analog Audio Output
Stereo-Aux Out(Pin)
Mono out(Pin)
Digital Audio Output
I2S Out(Pin)
Amplifier Chip
ma12070p
TPA3116D2
TPA3116D2*2
Audio Format(Up To)
44.1khz/16bits(CD)
44.1khz/16bits(CD)
44.1khz/16bits(CD)
USB Playback
ACPWorkbench
Remote
*①Optional
Optional
Optional
Knob Control
Yes(Volume, Treble, Bass)
Expansion Boards
Spdif In Board
*②Spdif Out Board
Button Board
*③IR Sensor Board
Spdif In Board
*②Spdif Out Board
Button Board
Volume Knob Board
IR Sensor Board
Spdif In Board
*②Spdif Out Board
Button Board
IR Sensor Board
Suggestion
For Satellite Speaker,Bookshelf Speaker, Center Speaker, Bluetooth amp, Easier Intallation
For Boombox
Build Your Wireless Projects
wireless stereo speaker
Wireless Stereo Speaker
Shared by Vincenzo Caputo
https://youtu.be/Fhu5Sjdn7UQ
Wireless Satellite Speaker
Shared by DIY Lady
plate amp
Renovate Your Retro Speakers
Shared by DrCassette
DIY wireless speaker
DIY Your Wireless Desktop System
Shared by Alfred C.G.
Compatible Accessories
已售完
ESS9023 DAC boardbutton board
促銷價$10.00
ACPWorkbenchDSP tool
remote controlremote control for DIY boards
促銷價$10.00
