A30+ 30W x 2 WiFi Mini Stereo Amplifier
A30+ WiFi mini stereo amplifier perfectly suited for your passive desktop stereo system and smaller space. The compact stereo amplifier and easy to use design makes it easy for everyone to get started quickly.
Play online music service, online radio, local music files to your passive speakers by WiFi, AirPlay, Spotify Connect, anytime in every rooms.
Small But Complete In Every Detail
A30+ mini stereo amplifier packs 30 watts per channel which is perfect to your desktop stereo system.
Enjoy the full functionality with wireless streaming: WiFi, AirPlay, Spotify Connect, Qplay, DLNA, UPnP, Bluetooth 5.0 and full features of our 4STREAM App: Online music, Online Radio, EQ Settings, alarm clock and more.
So does includes the ACPWokbench tuning tool features. The compact stereo amplifier and sliver surface makes your desktop looks more clear and premium.
Amplifier For Desktop
Best For Your First WiFi Stereo Amplifier
Our wireless streaming system is designed to be very simple, even for people who are not familiar with the electronics can quickly get started. There is clear step by step instructions in the app.
After the first setup of A30+ small stereo amplifier, you can stream directly from iPhone, iPad or Mac by Airplay or stream directly from Spotify both without app. The whole family can easily get started.
A30+ is a WiFi and Bluetooth amplifier for wired speakers.
Play High Quality Audio Without The Hassle
Streaming by WiFi has stronger range signal and high quality audio transmission.
With A30+ mini speaker amp, you can stream anytime, anywhere with far distance from the device. Upgrade your listening experience far from Bluetooth streaming before.
Hook Up Whole House Audio
A30+ mini audio amplifier can play a different song in different rooms, or the same track in every room, or play some rocky music for whole house party!
Bring Hi-end music to every rooms and controlled by one single device.
Versatile Playing
Play from Amazon Music, Spotify, TIDAL, Qobuz, iHeartRadio, TuneIn, Napster, phone storage, NAS, USB stick,line in source, bluetooth source and more.
Stream any audio you want all in one A30+ small audio amplifier.
Personalize Your Sounds
A30+ mini stereo amplifier supports ACPWorkbench tuning tool which allows you do specific EQ adjustment, L/R balance, dynamic range and more.
Set your favorite tune with different type of music.
A30+ WiFi Audio Amplifier, User Manual, Remote, 18V 4A DC Power Adapter, External Antennas (Bluetooth & WiFi), 2-1 RCA Cable, Screw Driver, 4 Pin Phoenix Connector (for speakers).
WiFi:
IEEE802.11 b/g/n 2.4G
Bluetooth:
Wired Network:
12V-18V/DC in
Analog:
AUX (1Vrms)
Digital:
Micro USB Input
Analog:
TPA3116
2 x 35W @ 4Ω load at 18V
2 x 18W @ 8Ω load at 18V
4-8Ω
20Hz to 20kHz
<0.03% @ 1kHz/1W/4Ω
Decoding up to 192kHz/24bits
Output up to 44.1kHz/16bits CD quality
Support NAS with DLNA support
Dimensions:
131.8mm*85.5mm*27mm (5.18in*3.37in*1.06in)
Weight:
500g
Working temperature:
Power Supply
Screw Driver
RCA Cable
Remote
4Pin phoenix connector
External Antenna x2
User Manual
Power Button
Device on:
Long press once: Switch off
Short press twice: Disconnect current WiFi connection and enter pairing mode (WiFi mode);
Device off:
Short press: Switch on
⚪White-WiFi & network mode:
Flashing fast- device is booting
Solid- WiFi is connected
🔵Blue- Bluetooth mode:
Solid- Bluetooth is connected
🟢Green- Line in mode
🔴Red- USB mode
🟡Yellow- connect to PC
Not sure which one to choose? We selected our most popular Wifi and Bluetooth amp. Compare them and choose the best version for your needs.
WiFi, AirPlay amplifier, Spotify Connect, Bluetooth 5.0
30W x 2
50W x 2
Line In
RCA In
Micro USB In
Optical In
Micro USB In
44.1kHz/16bits
44.1kHz/16bits
4STREAM
4STREAM
Can you do mono bridge on this amp?
Sorry this is not available, for mono amp you can refer to Up2stream Amp Mono.
Can I connect A30+ to Bluetooth Speaker?
About connect to speakers, you need to wiring to your passive speakers. The Bluetooth chip inside is a receiver not a sender.
Does it supports AirPlay 2 ?
No. You can refer to our H50 AirPlay 2 Amplifier.
How many A30+ I can connect to my network for multiroom at once?
Actually there is no limitation, as long as your WiFi router is strong enough. By normal home use, we suggeat up to 10 unis under a WiFi.
What Speakers I can connect to A30+?
You can connect any kinds of passive speakers to A30+.
Can I connect my computer to speaker amplifier?
If you want to connect A30 speaker amplifier to your computer, you will need to use a 3.5mm audio cable.
First, plug the cable into the headphone jack on your computer.
Next, plug the other end of the cable into the input on your speaker amplifier.
Finally, turn on your speaker amplifier and enjoy the increased sound!
How to connect mac to stereo amplifier?
The easiest way to connect the audio output of your Mac is to use the "line" output of your stereo amplifier.
We recommend a stereo 3.5mm mini phone plug to dual RCA cable or mini plug to dual RCA jack adapter with a RCA jack stereo cable to go to the audio input of your stereo amplifier sound system, such as the "aux" input.
Is A30+ Alexa Capable?
No A30+ is not support Alexa, you can pick our H50 Alexa amplifier.
此产品的评分为 4.8 / 5.0 颗星。
已收到 69 条评价。
