RK30 Wall Mount Cube Speaker
- High Quality Surround Sound: Rk30 is a passive speaker that can deliver the maximum power output to 80 watts with 40 watts RMS at low impedance. Sound is clear and detailed without compromsing on sound quality or performance.
- Easy Installation:The brackets and screws are included, so you just need to find a suitable corner for installation on the wall, or ceiling. Easy steps for mounting: just drilling holes, connecting wires, and turning screws.
- Compatible With Any Indoor & Outdoor Application:Broad application for your personal or commercial use, including office, home, garden, workshop, your boat, garage, gym, museum, shop store, or outside restaurant seating. The RK30 has IP66 water resistance rating, safe for outside installations.
- Upgrade your Lifestyle:The compact cube design frees up your living space and allows for easy system integration. Quality material used on the RK30 such as the ABS platic ball-joint bracket and paper cone of the speaker provide you with premium music entertainment.
- Bring Audio To Your Whole House: RK30 are a great match for our wireless streaming amplifiers so you can easily build your whole house audio system, with music in every corner. Get convenient wireless streaming and clean aesthetics in your house.
Small Speaker, Big Energy
Rk30 is a compact high quality speaker that can deliver 80W x2 power output. Its design is very ingenious, you can install it on the wall, ceiling, or even on the table.
It is very durable and does not take up much space, suitable for various indoor and outdoor scenes. The speakers are cost-effective yet the sound quality is brilliant.
Sound is clear and detailed without compromising on sound quality or performance.
Easy Installation
RK30 x2, User Manual, Ball-joint Bracket x2, Screws (Short) X8, Screws (Long) X8, Phoenix Connectors (For Speaker Wires) X2
40Watts
80 Watts
120-20KHz
88dB
98dB
8
Full Range
Paper
Cloth
180°
Turn/Tilt Bracket
ABS Plastic
66
2.5inch
94mm
108mm
82mm
0.48
Is this wireless speaker?
This is a on wall passive speaker that is great fit for your store, restaurant, villa and more. You can have our wireless amplifier upgrade to wireless streaming system. Such as B50 Bluetooth amplifier for wired speakers.
此产品的评分为 4.5 / 5.0 颗星。
已收到 2 条评价。
