Amazing Sound, Connect Everything.
- ESS9023 Sabre DAC Hi-res music.
- 6 Wireless Streaming Supported: WiFi, AirPlay, Spotify Connect, Bluetooth 5.0 aptX HD, DLNA, UPnP.
- 3 Audio Input+ 5 Audio Output : includes optical input/output and sub out.
- 15+ Music Services Supported: Spotify, Apple music, Amazon Music, Tidal, Internet radio, NAS and more.
- Multiroom Streaming Supported
Elevate Your Whole House Audio Experience
Convenient, smart, effortlessly control your audio systems and enjoy high quality audio in any rooms by Arylic wireless streaming system.
Streaming Directly From Your Smart Devices
12 Ports
For Whole House Audio
Connect your all audio equipments at once. From powered speakers, to audio amplifier, TV, vinyl, subwoofer, AV receiver and CD players, then use 4STREAM app to manage whole house audio system conveniently.
Audio Amplifier
Turn your sound system into smart.
Powered Speaker
Immersive with stereo sound.
Active Subwoofer
Start your house party tonight!
Vinyl
Play with your HiFi system
TV
Enjoy your movie time.
Music Everywhere Is So Easy
Mix and match any combination of Arylic streaming devices to create a custom multiroom system and play the same music throughout your home, send different sources to each room at the same time, or create your own custom-defined multiroom zones.
Sync Audio
*Support sync from all music sources.
Play Different Songs At the Same Time
Multizone Group
Easy and Full Control
Spotify, Apple Music, Amazon Music, Tidal, Internet Radio, TuneIn, NAS, USB Stick,
Just 3 Steps, Stream With WiFi !
Plug power and connect to amplifier or powered speakers.
*Connect by Lan for instant use.
Turn on the device and go to WiFi settings > connect S50 Pro+ SSID, then open 4STREAM app
Pairing with your home WiFi , then you are done.
Full wireless control with 4STREAM APP, like audio sources collection, play from local files, mode switching, multiroom control, EQ control, alarm clock and more features with future update.
Directly control from your iOS system.
Easy and quick access with playback, EQ, web radio and more features with future update.
Easy mode switching, playback, deep bass and preset content.
Perfect Match To Your System
The compact size and easy design makes S50 Pro+ seamlessly integrates into your existing home system. Does not take up too many space, but deliver impressive sound for you.
OLED Display
Easy to get into know the device status, easier to use.
Compact Design
Sleek and minimalist design makes S50 Pro+ seamlessly integrate with your home theater.
Solid Quality
Aluminum alloy housing with CNC integrated molding, extended product service life.
5.0 aptX/aptX HD/SBC/AAC, 15M, BT Receiver
AirPlay, DLNA, UPnP, Spotify connect, Qplay
12V/1A DC Input
Analog
RCA Input x 1
Digital
Optical Input x 1
Analog
RCA Output x 1
Subwoofer Output x 1
Digital
Optical Output x 1
Coax Output x 1
Decoding
Up to 24bit/192kHz
Output
44.1khz/16bits, CD quality
20Hz-20kHz
0.03%
110dB
0.4kg(0.88lb)
12x11.3x3.7CM(4.72x4.45x1.46in)
Not sure which one to choose? We selected our most popular wireless music streamers. Compare them and choose the best version for your needs.
5V/1A Type-C Input
12V/1A DC Input
Spotify, Amazon Music, TuneIn, Tidal, Qobuz, Napster, Internet Radio, iHeartRadio, QQ Music, QQFM
Aux In
Opt In
Aux Out
DAC: Integrated
DAC: ESS 9023
Opt Out
Coax Out
Decode up to 192khz/24bits
Output 44.1khz/16bits(CD)192 kHz/24 bits
Can I stream music from my computer using itunes via wi-fi to my stereo amplifier?
Yes for sure. For iTunes you can use Airplay with our S50 Pro+ wireless preamplifier.
Does this preamp support AirPlay or only AirPlay?
AirPlay 1 only.
For multiroom, you can use our 4stream app to stream AirPlay source to other rooms also.
Group the rooms in app first then stream any audio source(WiFi, Airplay, Online music, Bluetooth, analog in, digital in) you want on the master unit.
What is the S50 Pro+ preamp used for?
A preamp, also known as a preamplifier, is an electronic audio preamplifier that converts a weak electrical audio signal into an output signal strong enough to be noise-tolerant and strong enough for further processing, or for sending to a power amplifier and an active speaker.
Without this, the final audio signal would be noisy or distorted.
What is a preamp vs amp?
The preamp is to amplify the audio signal to the input range acceptable to the power amp. It has the characteristics of selecting the required audio source signal and amplifying it to the rated level and beautifying the sound.
The role of the preamp:
Select the required audio source signal and send it to the rear stage, and at the same time close other audio source channels, and amplify the audio source signal to the rated level to achieve high-fidelity sound quality.
The difference between an audio power amplifier and a preamplifier
The Bluetooth preamp is to amplify the audio signal to the input range that the power amplifier can accept, and the audio power amplifier is to generate the maximum power output to drive a certain load amplifier under the specified distortion rate conditions.
The preamp is an audio processing device before the input audio power amplifier; the amp controls the power of the sound, and the preamplifier controls the audio range.
How necessary is a preamp?
Arylic S50 Pro+ preamp has a built-in high-quality DAC, which can improve the sound quality.
Support Ethernet RJ45 and AirPlay, DLNA, UPnP, Spotify connect, Qplay input, RCA input, RCA output and Optical output. It can turn your traditional old-fashioned wired active speakers into wireless speakers and wireless ceiling speakers and improve the sound quality.
Is there an amplifier board inside?
No S50 Pro+ is a preamp, not an amplifier. No Bluetooth amplifier board inside.
此产品的评分为 4.7 / 5.0 颗星。
已收到 178 条评价。
