RK525 5.25" 2 Way 60W Full Range In-Ceiling Speaker
- Powerful Premium Sound: RK525 has powerful 60W output at 8Ω and high sensitivity at 89db. It also has front-mounted Bass & Treble equalization switches to work well with any music style and audio preference.
- Perfect to Fit your Rooms:The compact 5.25 inches design can fit more places with no visible wires for an installation that keep the aesthetic view in your house. What's more, the pivoting woofer and rotating tweeter allow you to adjust the sound for a high-fidelity hearing experience. Adjust the audible angle to perfect fit your home's accoustics.
- Easy Installation: Easy setup in minutes with only a 175mm hole saw, a drill and a screwdriver. Strong magnets hold the clean looking protective metal grill in place making it convient to remove and replace for cleaning, adjusting the independent woofer and tweeter angles, or adjusting the bass and treble gain switches.
- High Quality Material:The 5.25 inches woofer utilize glass-fiber cones that have outstanding responsiveness and extraordinary dynamic carrying capacity, while the 0.75 inches tweeter adopts silk aluminum diaphragm which has broader sound range and higher penetration, with both offering resistance to indirect weather for years of high clarity enjoyment.
- Tweeter and Woofer Combination: The combination of both a woofer for bass and midrange and a tweeter for treble offer a more powerful, thick and well-rounded sound throughout the range, while the human voice comes through with definition and clarity.
- Best Match for Your Whole Home System: Rk525 is a very suitable in-celing speaker option for our wireless streaming amplifiers. Pairing with our A50+ Amplifier offers the best sound performance and control your whole house audio.
High-Fidelity In-Ceiling Speaker
RK525 is a 5.5" ceiling speaker with high quality tweeter and woofer.
RK525 offers excellent sound quality with transparent treble, clear and clean vocals and deep bass. It is also very easy to install, ideal for commercial use and home theater systems.
Easy Installation
Strong magnets hold the clean looking protective metal grill in place making it convenient to remove and replace for cleaning, adjusting the independent woofer and tweeter angles, or adjusting the bass and treble gain switches.
The 5.25 inches woofer utilize glass-fiber cones that have outstanding responsiveness and extraordinary dynamic carrying capacity.
While the 0.75 inches tweeter adopts silk aluminum diaphragm which has broader sound range and higher penetration, with both offering resistance to indirect weather for years of high clarity enjoyment.
Rk525 ceiling speaker is a very suitable in-celing speaker option for our wireless streaming amplifiers. Pairing with our A50+ Amplifier offers the best sound performance and control your whole house audio.
RK525, User Manual, Mounting Template, White Metal Grill.
Pivoting and Rotating 5.25 inches Kevlar cone with rubber surround
Pivoting 24mm aluminum diaphragm with silk,NE magnet
50Hz - 20kHz
8 Ohms
2.8kHZs
Treble Adjustment
Bass Adjustment
5.25 inches
20.5 x 11cm
17.5cm
Pivoting and Rotating 5 1/4" Aluminum Cone Woofer
Pivoting 3/4" Aluminum Dome Tweeter
WavePlane Technology
Front-Mounted Bass & Treble Equalization Switches
Is this wireless ceiling speaker?
This is a passive speaker that is great fit for your store, restaurant, villa and more. You can have our wireless amplifier upgrade to wireless streaming system. or check WBC65 wireless ceiling speakers.
此产品的评分为 5.0 / 5.0 颗星。
已收到 3 条评价。
