BP50 Bluetooth Preamplifier With ESS ES9023P DAC
- ESS ES9023P DAC 192kHz/24bits.
- Bluetooth 5.2, aptX HD, aptX LL, aptX Adaptive, AAC, SBC.
- Transmit and receive music with aptX HD.
- Transmit to 2 Bluetooth headphones simultaneously.
- HDMI ARC in, Phono in, Optical in, RCA in, Sub out, Optical Out, Coax Out, RCA Out and more.
- Free APP and Remote Control
Support Together
Stream TV Sound to Your Speakers
BP50 is a preamplifier with HDMI ARC and CEC features. It can decode up to 192kHz/24-bit TV Audio with PCM format.
*CEC supports TV and the BP50 sync power on/off and volume control.
ESS Sabre ES9023P DAC
The BP50 utilizes the ESS Sabre ES9023P DAC, the DAC supports decoding up to 192kHz/24bits, and offers a dynamic range of 112db.
By high resolution and high dynamics, the BP50 can reproduce more music details and bring better sound performance with your audio gears.
Upgrade Your Sound System to Wireless
You can use your phone to connect the BP50 wirelessly and play music through it to speakers.
You only need to use your phone to control it and get a wireless home audio system.
Smoothly and Stable Listening Experience
Supported by Bluetooth 5.2, and low latency when you are playing music, audiobooks, and radio stations.
Within a 10-meter range, you can connect to the BP50 preamplifier via Bluetooth easily and enjoy music.
HD Bluetooth Audio
Built-in ESS ES9023P DAC and QCC3040 Bluetooth chip, BP50 supports aptx HD, aptX LL, aptX Adaptive, and AAC high-quality Bluetooth codec.
You can use the BP50 to transmit and receive HD music audio with your audio gears.
Transmit to 2 Bluetooth Headphones Simultaneously
You can switch the BP50 to Bluetooth transmitter mode, and connect 2 sets of Bluetooth headphones at the same time.
After that, both of them will play the same sound from TV, Turntable, and other input sources Simultaneously.
Enjoy high-quality movies, music, and gaming sessions without disturbing your family's peace.
All-in-one Preamplifier
BP50 has various interfaces with Bluetooth transmitter and receiver features.
5 inputs and 4 outputs: HDMI ARC Input, Phono Input, RCA Input, Optical Input, USB input, Sub Output, Type-c DAC Output, Optical Output, Coax Output.
GO CONTROL APP
Convenient wireless control and custom settings
Customized EQ with ACPWorkbench
BP50 is compatible with the ACPWorkbench software, and you can adjust the EQ settings.
You can adjust the frequency of each channel, balanced sound, and more configurations.
With this ACPWorkbench tunning tool, you can adjust different EQ details and meet your music listening habits.
Small, But Handles All Your Needs
5.2, 15m
0051-ba37596b
20Hz to 20Khz
0.05%/>95db
Analog RCA, Max 2V RMS input
Analog RCA, support MM/MC
Up to 192kHz/24bit PCM only
PCM only, CEC function supported
Support codec: mp3, mp4, wma, mov, m4a, aac, flac(96kHz/24bit), ape
Max 3V RMS output, Cutting frequency: 250Hz
Max 2Vrms output
48kHz/16bit output
48kHz/16bit output
12V/1A
185 x 155 x 50mm
750g
Which Wireless Preamp Are Made For You ?
Not sure which one to choose? We selected our most popular wireless stereo receiver. Compare them and choose the best version for your needs.
Learn MoreBluetooth 5.2 aptX HD, aptX, aptX LL, aptX AD, AAC, SBC
Bluetooth 5.2 aptX HD, aptX, aptX LL, aptX AD, AAC, SBC,Bluetooth transmitter and receiver
WiFi, AirPlay, Bluetooth 5.2 aptX HD, aptX AD, AAC, SBC
Phono in
Phono in
RCA Out
Sub out
Sub out
RCA Out
USB Type - C
USB Type - C
Coaxial Out
Optical Out
Coaxial Out
Optical Out
48khz/16bits
48khz/16bits
44.1khz/16bits
GO CONTROL
GO CONTROL
4STREAM
Does BP50 Support CEC control?
How far is the BP50 receive and transmit distance?
Both receive and transit distance is about 15m. When transmit to 2 Bluetooth devices at the same time, it is 10m from BP50 Bluetooth stereo receiver to other Bluetooth devices.
What is the difference Between B50 and BP50?
B50 is a Bluetooth amp, and BP50 is a Bluetooth preamp. The role in sound system are total different, if you already had active speaker or amplifier you can choose BP50. If not, you can choose B50 Bluetooth amplifier for wired speakers.
此产品的评分为 4.7 / 5.0 颗星。
已收到 121 条评价。
