LP100 HiFi Music Streamer
Free & Fast Delivery
- Free shipping.
30-days Free Return
30-Day Worry Free Guarantee✨
Hassle-Free Warranty
Warranty Made Simple
Get 20% off with code LP100
Pre-order now shipping starts December 30th.
- Support AirPlay 2, GoogleCast, Spotify Connect, Tidal Connect.
(*Roon Ready coming soon with OTA update) - Bluetooth V5.4, support SBC, AAC, aptX, aptX HD, aptX LL, aptX AD, LDAC, LC3, Auracast and transmit and receive audio by Bluetooth with QCC3083 chip.
- 192kHz/24bit music streaming and playback.
- HDMI eARC(CEC support), Phono input, USB stick input, Sub out and more interfaces.
- AKM AK4493EQ DAC, CT5302SL SRC, AKM7735 ADC, AK7735 DSP all for sound.
Play What You Love Right Away
Bring your audio amplifier or speakers into the streaming era.
With AirPlay 2, Google Cast, Spotify Connect, TIDAL Connect.
LP100 lets you enjoy your favorite content quickly and effortlessly.
*Roon Ready coming soon with OTA update.
Stream music directly from your iPhone, iPad, or MacBook, and play it together with other AirPlay 2-enabled devices.
You can also add LP100 to the Apple Home app and control it effortlessly with your voice through HomePod.
Cast music directly from your Android device, YouTube, or any Cast-enabled app.
LP100 works seamlessly with other Google Cast speakers for multi-room playback, voice control with Google assistant and supports high-resolution streaming up to 96 kHz/24-bit via Google Cast.
Play directly from the Spotify app with your playlists and collections.
With Spotify Connect, LP100 streams your music over Wi-Fi for higher quality and stable playback — even free accounts can enjoy it, with no interruptions from phone calls.
Spotify lossless streaming will be supported via OTA update in Q4 2025.
Stream high-resolution music directly from the TIDAL app to LP100 over Wi-Fi.
Enjoy your curated playlists and lossless sound in full clarity, and keep the music playing even when calls come in.
192kHz
24bit
One More Step, Fine Tune Your Perfect Sound
Customize the EQ on LP100 to match your listening habits, your mood, and your space.
EQ settings can be applied to all audio inputs for a consistent sound experience across every source.
Unlock Freedom of Bluetooth
With Bluetooth 5.4, LP100 supports both receiving and transmitting modes, giving you the freedom to stream wirelessly in any setup.
Enjoy high-quality audio with SBC, AAC, aptX, aptX HD, aptX LL, aptX AD, LDAC, and LC3 codecs, or share music effortlessly through Auracast and LE Audio broadcasting.
Control In Your Way
GO CONTROl APP
Take full control and customize for personal settings.
BLE Remote Control
Quick playback, EQ, preset content access.
Voice Control
Convenient voice control with Siri and Google assistant.
Lifestyle Remote Control
Optional remote control for quick access to your music — and to elevate your space with style and convenience.
HDMI CEC
Control By Your TV Remote
With HDMI CEC, LP100 integrates seamlessly with your TV.
Turn on your TV, and LP100 powers up automatically — volume and playback can be controlled with your TV remote.
Detailed Design for Everyday Convenience
Every detail crafted for beauty, function, and feel.
Wireless
IEEE802.11 b/g/n 2.4GHz, 5GHz
LAN
10/100M RJ45
V5.4, 15m
Bluetooth Transmit
Codec: SBC, AAC, aptX, aptX HD, aptX LL, aptX AD, LDAC, LC3
1x Bluetooth TX, able to connect up to 1 Bluetooth speaker or headphones
Bluetooth Receive
Codec: SBC, AAC, aptX, aptX HD, aptX AD, LDAC, LC3
2x Bluetooth RX, able to connect up to 2 smartphones
Broadcast
Auracast, 10m
Streaming Protocol
WiFi, AirPlay 2, Google Cast, Spotify Connect, Tidal Connect, Roon Ready, DLNA, UPnP
Sound
Frequency Response
20Hz-20kHz±1 dB
THD+N/SNR
≤0.001 %/≥80 dB
Crosstalk
≥80 dB
DAC
AKM AK4493SEQ
ADC
AKM7735
SRC
CT7302SL
Audio Sources
Audio Input
RCA Input x1
2 Vrms
Phono Input x1
MM / MC, RIAA EQ Built in
Optical Input x1
PCM only, up to 192kHz/24bit
Coaxial In x1
Up to 192kHz/24bit
HDMI eARC Input x1
PCM only, CEC function supported
USB Host x1
USB disk drive playback, support resume playback Storage format: Fat16, Fat32, exFAT, up to 128GB Support codec: mp3, wma, m4a, aac, flac
USB-B DAC x1
For PC connection, Sample rate: 44.1~192kHz
Local Msuic
Audio Output
Speaker Out x1
Banana Plug
Line Out x1
RCA, Max 2 Vrms output
Optical Output x1
Up to 192kHz/24bit output
Subwoofer Out x1
Max 3 Vrms output, Crossover frequency: 250Hz
*Support simultaneously audio output.
Control
Buttons
Rotary Knob
Switch between modes, volume, and power.
Touch Buttons
Play/pause, skip tracks, Auracast.
Reset Button
Repair WiFi/Bluetooth, restore to factory settings.
APP
GO CONTROL APP
Voice Control
Siri, Google Assistant
Remote Controller
BLE remote control
Lifestyle knob control(optional)
Gerneral
Power Input
USB Type-C Port 5V/2A
Size
167x167x43.5 mm
Weight
550g
Trigger Out
12V
LP100 x1
BLE Remote Controller x1
Manual x1
5V/2A Power Adaptor x1
2-2 RCA Cable x1
USB Type-C Power Cable x1
USB Type-B Data Cable x1
Manual
Does LP100 support multi-room playback?
Absolutely. You can group LP100 with other devices through AirPlay 2, Google Cast, or Roon to enjoy synchronized music throughout your home.
Can I control LP100 without using the app?
Yes. You can control playback, volume, and source using the BLE remote or the physical knob with touch controls — and LP100 also supports CEC TV remote control via HDMI.
Can I customize the sound to my preference?
Yes. LP100 includes built-in EQ adjustment, so you can fine-tune your sound to match your listening habits, music style, or room acoustics by GO CONTROL APP
How many Bluetooth headphones I can connect with at once?
LP100 can connect to one Bluetooth headphone or speaker at a time.
