BT10 Bluetooth Audio Transmitter
-Transmit Audio to 2 Bluetooth Headphones or Bluetooth Speakers via Bluetooth.
-Tramsit via aptx, aptX HD, aptX LL and aptX Adaptive.
- Rich Interfaces: Optical In, Line in/out, Type-C DAC input, USB Host.
- Transmit to 2 Bluetooth devices and a line output simultaneously.
- Easy to use: Free iOS & Android APP, easy and convenient to use for everyone.
BT10 x1, User's Manual x1, Aux 3.5mm Cable x1, 2-1 RCA Cable x1, Power Adapter x1, USB Type-C Cble x1, Remote Control x1
Free shipping in US & EU regions.
Transmit Music To Your Headphone
Transmit sounds wirelessly to your Bluetooth headphones or Bluetooth Devices.
Small But Powerful
Easy Transmitter Pairing
Once you've connected from your TV, PC, or CD player wire to BT10, press and hold the touch button or use the GO Control APP for easy and quick click pairing.
HD Music
Enjoy high-quality codecs, including aptX, aptX HD, aptX Adaptive, SBC, and AAC.
*To use aptX formats, make sure your devices are supported.
aptX Low Latency
Play video games, PC games with micro <40ms latency. Experience real-time gaming and wireless convenience.
Smooth and Stable Connection
BT10 supports TRUE 15-meter long-range wireless transmission. Enjoy an uninterrupted, smooth listening experience all day.
Compatible To Your Bluetooth Deivces
Able to connect with Bluetooth 5.4, 5.3, 5.2, 5.0, and 4.0. The BT10 can easily pair with most of your Bluetooth devices.
Upgrade Your listening Enjoyments
Experience versatile and high-quality music enjoyment without disturbing others.
Feel every real-time footstep and explosion with high-quality sound, making it a truly immersive gaming journey.
Your can input your TV sound via optical in and transmit wirelessly to your Alexa or Google speaker via Bluetooth.
BT10 supports transmitting to 2 Bluetooth devices simultanously, so you can connect to 2 Bluetooth speaker build a stereo sound system.
Connect to your hearing aids or earbuds to add and control volume.
Triple Link: Enjoy Room-filling Sound
Tranmit To Smart Speakers by Bluetooth
Transmit to your Alexa, Sonos, or Google speakers via Bluetooth. Use them as Bluetooth speakers to upgrade the TV experience.
Line Output to Your Active Speaker
BT10 supports transmitting to 2 Bluetooth devices and one line output at the same time. Save your space and play together with one device.
*There must have delay between 3 devices.
Transmit To Your Bluetooth Speaker
BT10 Support Transmit up to 2 Bluetooth speaker via Bluetooth.
Enable Wireless Connectivity for Your Devices without Built-in Bluetooth
Transform your old TV with the BT10 Bluetooth transmitter, and give your vintage active speaker new life with the BR10 Bluetooth receiver. Enjoy invisible cables and seamless Bluetooth wireless connection between your classic devices.
BR10 Bluetooth Audio Receiver
Control In Your Favorite Ways
Personalize Your Music Style
Custom EQ
Tune Like A Pro
Compact And Save Your Space
5.2, 15m
2x Bluetooth TX, able to connect up to 2 Bluetooth speaker or earphones.
aptX, aptX HD, aptX LL, aptX AD, AAC, SBC
0004-660b7485-9
20Hz to 20Khz
3.5mm analog earphone jack, Max 2V RMS input
3.5mm analog earphone jack, Max 2V RMS Output
Up to 192kHz/24bit PCM only
Sample rate: 48kHz
Support codec: mp3, mp4, wma, mov, m4a, aac, flac (96kHz/24bit), ape
5V/1A Type-C
108 x 72 x 26.6mm
89g
Which Wireless Audio Streamer Are Made For You ?
Not sure which one to choose? We selected our most popular wireless audio streamers. Compare them and choose the best version for your needs.
Click Learn More Below To Check All Products Comparison Table.
Bluetooth 5.2
Bluetooth Receiver
Bluetooth 5.0
Bluetooth Transmitter + Bluetooth Receiver
Bluetooth 5.2
aptX, aptX HD, aptX adaptive, SBC, AAC
aptX, aptX HD, AptX LL, aptX AD, SBC, AAC
5V/1A Type-C
12V/1A DC Input
5V/1A Type-C
Aux In
Aux In
Type-C DAC
Opt In
Type-C DAC
Optical In
Type-C DAC
Aux Out
DAC: Integrated
DAC: ESS 9023P
Aux Out
DAC: Integrated
Opt Out
Opt Out
Coax Out
Decode up to 192khz/24bits
Output 44.1khz/16bits(CD)
What is the range when transmit to 2 Bluetooth Devices?
When connect to 2 Bluetooth devices, place the devices under 10 meter range for better stability.
How do you set up BT10 Bluetooth audio transmitter?
- Power on the devices and input the audio source you want to transmit. Like TV, PC, etc.
- Set your Bluetooth headphone or Bluetooth speaker into pairing mode.
- Press and hold the play/pause touch button until the Bluetooth LED blinks fast. Or open GO CONTROL APP, choose BT10, and click "click to pair."
- When the Bluetooth LED be solid, The devices are connected, you can start to transmit.
Does BR10 support USB playlist?
Yes. You can use our GO CONTROL app to play with your USB and check the playlist and songs.
When transmitting to 2 Bluetooth devices, do they both support aptx HD?
When you transmit to 2 Bluetooth devices at the same time, only the first one connected supports the aptx, aptX HD, aptX LL or aptX Adaptive codec.
此产品的评分为 5.0 / 5.0 颗星。
已收到 1 条评价。
