BK501/651 2 Way Bookshelf Speakers
促销价格$569.00
-100W, HiFi sound.
- High-end Heil AMT Tweeter.
- Treble up to 40khz, feel detailed treble clarity and brightness.
- 180° Wide soundstage, enjoy high quality pure vocals and instruments in every corner.
-Innovative design of 5"/6.5" Fiber glass Mid-woofer with outstanding heat dissipation and no distortion.
-FSC Environmental Certification
- 15mm (BK501) - 18mm (BK651) super thick MDF cabinet design.
现货
Speaker: BK501 ( 5 inches/1 Pair)
✔Fast & Free Shipping
Bk651 Bookshelf Speakers
best bookshelf speaker
best hifi bookshelf speaker
Your Brilliant HiFi Bookshelf Speakers at Home
BK501/651 is a passive speaker that built for HiFi stereo sound system. You can feel the surprising crystal clear and bright treble, full midrange, fantastic deep bass and dynamic sound.
With our sonically engineering construction design, you can hear every details from the original sound.
Compared to other tweeters, Arylic bookshelf speakers Heil AMT tweeter uses a folded Kapton ribbon diaphragm in addition to a high-grade black diaphragm. Due to the advanced craftsmanship that makes the vibration area is larger, appearance is better and makes the sound clearer and brighter.
Enjoy Pure Sound Of Vocals and Instruments
The treble high-frequency can go up to 40Khz, which delivers clean, detailed, and highly dynamic output.
It also can wider treble soundstage to 180°, makes you listening to high quality music in any corner. Enjoy immersive concert in your rooms.
Rear speakers
Powerful HiFi Mid-Woofer
The 6.5" mid-woofer of BK501/651 bookshelf speaker uses glass fibre cone, S-type paper cone and air permeability design. Which can enhance the sound transmission much longer, lower the attenuation and have better heat dissipation.
Let you enjoy the full and revealing midrange and powerful bass in your home theater system. No longer have to worry about putting too loud bass will have the problem of distortion.
rear speaker
Scientific Speaker Cabinet Design
BK501/651's cabinet is made of thickened15-18mmMDF and scientific inverted phase tube, which is developed by experienced acoustic engineers after more than 900 days of research and development with professional acoustic tools.
Precisely calculated volume and cabinet design can reduce resonance and slant vibration noise, brings you incredible sound enjoyments.
Sonically Engineering Design
Classic Never Goes Out Of Style
Home audio
Perfect Match In Your Rooms
The compact size and design make it easy to drive and perfect to put in any rooms at your home. Like living room, dining room, bedroom, garage etc.
Focus On Every Details
bookshelf speaker sale
FSC Eco-friendly Certification
Handcrafted eco-friendly wood veneer.
Removable magnetic dust cover
Removable Magnetic Dust Cover
Classic aesthetic look and protective.
Pure copper crystal terminal
Pure Copper Crystal Terminal
Anti-oxidation, easy to install.
Stereo Speaker
Transparent UV paint
Drop-proof, moisture-proof, moth-proof
Strong Protected Package
* Subject to technical change.
Model
BK501
BK651
Configuration
2 way
2 way
Nominal/peak power Handling
40/80 Watts
50/100 Watts
Nominal Impedance
4 ohms
4 ohms
Suitable For Amplifiers
4-8 ohms
4-8 ohms
