Up2Stream Amp Sub - Multiroom Wireless Subwoofer Amplifier Board
- Turn your passive subwoofer into a wireless subwoofer,get deep bass without wires.
- Powerful, Booming 100W Bass, adjustable crossover frequency range of 10Hz - 300Hz.
- Position your Subwoofer Anywhere.
- Group multiple Subs in One System.
- Turn your existing stereo system into a 2.1 channel system.
Up2stream AMP Sub
The Up2stream Amp Sub is designed to seamlessly integrate with other Up2Stream audio boards, this powerful subwoofer amplifier board can deliver a maximum output of 100W to your passive subwoofer, bringing deep and immersive bass to your music and movies.
With the Up2Stream AMP SUB board, you have complete control over your sound settings. Simply adjust the crossover frequency and maximum volume level using the convenient rotary knobs. Tailor the audio output to suit your preferences and create the perfect balance between low-frequency power and overall room-filling sound.
But that's not all! If you're craving even more bass power, you can expand your audio system by adding multiple subwoofer boards. Imagine the exhilarating effect of multiple subwoofers working together to produce a booming sound that shakes the very foundations of your room!
Upgrade your audio setup and unlock a new level of immersive sound with the Up2Stream AMP SUB board. Whether you're a music lover or a movie enthusiast, this subwoofer amplifier is the perfect addition to enhance your listening experience and bring your entertainment to life. Don't settle for ordinary sound – immerse yourself in the rich, deep tones that only a quality subwoofer amplifier can provide.
Features
Get Deep Bass Without Wires
Up2Stream Amp Sub allows you to turn your passive subwoofer into a wireless subwoofer. Pair with any other Arylic stereo system and you can pass the deep bass wirelessly. Enjoy the powerful bass anywhere you want!
Hear and feel powerful 100 Watts of booming bass with an adjustable crossover frequency range of 10Hz - 300Hz.
You can place your subwoofer anywhere in your house and wirelessly stream deep bass throughout the house.
With the ready-to-use interfaces, streaming music is as simple as plugging in the power and connecting to a passive subwoofer. Unlike other audio boards, there's no need for soldering of pins before you can get started. This makes it incredibly easy and user-friendly for anyone to use.
Multiple Interfaces
The Up2stream Amp Sub comes with a range of ready-to-use interfaces, including a Aux in audio input, switch jumper, subwoofer output and a plug for power input. Which enables you to create a flexible system according to your specific needs. With these features, you can easily connect your audio devices and enjoy high-quality sound without any complicated setup.
Multiple Subs in One System
There is no limit on how many subwoofers you can add to the system. Wirelessly group multiple Up2Stream Amp Sub units with any Arylic stereo device when you need exceptional bass, or just use one when you listen to relaxing music. You have the control.
Upgrade your Stereo System to 2.1 Channel
Get a passive subwoofer and you can easily turn your existing stereo system into a 2.1 channel system to enjoy music with powerful booming bass.
DIY Subwoofer Accessory Kit
For DIY lovers, we offer a metal front plate and a collection of useful components in our DIY Subwoofer Accessory Kit.This kit will makes it convenient to either integrate an Up2Stream Amp Sub with your current passive subwoofer or build one from scratch. You also can find the other good DIY Bluetooth amp kit in accessories.
Functional Knob Control
The Up2stream AMP Sub features 2 rotary knobs that enable effortless adjustment of treble, and bass. However, these knobs also facilitate adjustments to the crossover frequency. In addition to controlling sound characteristics, the Up2stream AMP Sub provides versatile functionality for a customized listening experience.
WiFi:
IEEE802.11 b/g/n 2.4G
12V-24V/DC in
12V-24V 2 Pin Connector
Analog:
3.5mm Line Input (1 Vrms)
Analog:
Subwoofer Out
Power switch jumper
100W @ 2Qlad at 24V
60W @ 4Qload at 24V
30W @ 8Qload at 24V
2-8Ω
10Hz to 300Hz
0.1%@100Hz1W
Decoding up to 192khz/24bits
84x84x17.5mm
Knob Cover x2
Internal WiFi Antenna
Screw Driver
User Manual
Power Button
Device on:
Long press once: Switch off
Device off:
Short press: Switch on
Bass Knob
(Crossover frequency range from 10-300Hz, default 110hz)
⚪White-WiFi & network mode:
Solid- WiFi is connected
🟢Green-Line in mode
②Up2stream Amp2.1 need ACPWorkbench tuning tool to switch the spdif configuration from spdif in to spdif out.
Sub
2.1(L+R+Sub)
100W
2 x 50W + 100W
Aux In(3.5mm Jack & Pin)
Spdif In(Pin)
Subwoofer Out
TPA3116
TPA3116D2*2
44.1khz/16bits(CD)
44.1khz/16bits(CD)
Optional
Yes(Volume, Bass)
Yes(Volume, Treble, Bass)
Spdif In Board
*②Spdif Out Board
Button Board
IR Sensor Board
For Wireless Subwoofer
For Boombox
How can I add Up2stream Amp Sub to other Arylic devices?
Your can wireless connect the subwoofer amplifier to other Arylic stereo by WiFi. Pair to the same network with 4STREAM APP and group them use multiroom features to build a wireless 2.1 system.
How many wireless subs can I connect at once?
No limitation actually, this is based on your WiFi router is stronger or not. Usually we suggest maximum 5 at once for better streaming experience,
Does this subwoofer board have an auto-standby function sensing the audio input?
Yes, it will switch to line in when detected input plugged .
此產品的評價:4.8 / 5.0 顆星。
已收到 12 則評價。
