Expansion Boards
促销价格$25.00
已售罄
Up2Stream DAC Board
Upgrade the sound quality of your Up2Stream board with the famous ESS 9023 Sabre chip found in the Up2Stream DAC Board.
Compatible Products: Up2Stream Mini, Up2Stream Pro
Up2Stream Button Board
This Button board is an external board that contains multiple control buttons including play/pause, volume up, volume down, previous song, next song, standby and switch mode, plus an on board IR receiver, connector for IR Extension Board and 4 mode indicator LED including WiFi, BT, AUX and USB.
It is perfect to use as the control panel for your DIY device.
Compatible Products: Up2Stream Mini, Up2Stream Pro, Up2Stream Amp, Up2Stream Amp Mono, Up2Stream Amp 2.1
*Up2stream Plate Amp, Up2stream Plate Amp 2.1, Up2stream HD DAC need to wiring yourself.
Up2Stream S/PDIF In Board
Lacking a digital input for your DIY board but want an easy solution?
The S/PDIF input board lets you easily add S/PDIF input to your device. It contains both an Optical input and Coaxial input jack. With this board, you can connect any device with S/PDIF output as a digital audio input source.
*Up2stream Plate Amp need to wiring yourself.
Up2Stream S/PDIF Out Board
This SPDIF output board can add digital output to your device, which contains an optical output and coaxial output jack. With this board, you can output digital audio data to other devices like a DAC or digital amplifier.
Up2Stream IR Extension Board
Does the onboard IR receiver not fit your DIY case? Do you need to position it somewhere else?
This IR extension board lets you connect an external IR receiver and position it to fit your DIY needs.
*Requires Up2Stream Button Board or Up2stream Pro, Up2stream Amp, Stereo, Up2stream Amp Mono, Up2stream Plate Amp, Up2stream Plate Amp 2.1, Up2stream HD DAC need to wiring yourself.
*Up2stream Mini requires Up2stream Button board.
Up2Stream Volume Knob Board
Need a volume knob on your DIY project? Then this is perfect for you! U
se this Volume Knob Board to add a volume knob to your device. It is a combined rotary encoder and momentary switch you can use it to turn volume up or down, and for Up2stream Mini, switch input mode with a press.
Compatible Products: Up2Stream Mini, Up2Stream Pro, Up2Stream Amp stereo, Up2Stream Amp Mono.
Model
Up2stream DAC Board
Up2stream Button Board
Up2stream SPDIF In Board
Size
40x38mm
68x64mm
52x24mm
Sample Rate
up to 24bit/192KHz
up to 16bit/176.4MHz
Audio Output
44.1khz/16bits, CD quality
Dynamic Range
112dB
Interchannel Isolation
100dB
THD+N
0dB FS 0.002%
Power supply
3.3V ± 5%, 23mA 5.0V ± 5%, 31 mA
Model
Up2stream SPDIF Out Board
Up2stream Volume Knob Board
Up2stream IR Extension Board
Size
52x24mm
22x17mm
18x10mm
Sample Rate
Sample Rate is same as the connected board
Audio Output
