Grappling with the issues of not having different soundscapes in multiple rooms simultaneously? If you are, you will surely love to have a multi zone receiver because it will help you with this task.
Read on to learn all about what a multi zone receiver is, its key features, benefits, and ideal use cases. You will also be introduced to Arylic’s products, which are the best in this field, and you will learn how to set up a multi zone receiver.
Intrigued? Well, read till the end!
Understanding Multi-Zone Receivers
You must know what a single-zone receiver is, right? A single-zone receiver allows you to listen to your favorite audio in your immediate space. While it is great in its own way, it poses problems when you wish to have separate speakers with different audio songs in several areas.
That is where multi-zone receivers come in. They allow you to simultaneously play multiple audios in different places without any issues. With this, you can even have a Spotify streamer play your favorite tune in your bedroom while your sibling can play another song in the living room. Tempting, isn’t it?
Key Features of Multi-Zone Receivers
Having understood the multi-zone receiver’s definition, let’s now take a look at some of its impeccable features.
1. Multiple Audio Zones
What could be more compelling than having a device that can play multiple audios in various zones/rooms without any issues? The different zones could either have the same audio or different ones.
You can choose whichever audio you want for each room, thereby earning you independent control of the different zones. You will also have a whole house audio, whereby you can enjoy a tranquil tune in the kitchen while your kids enjoy jazz music in their bedroom.
You can also connect speakers with an Airplay amplifier or an Airplay 2 amplifier for streaming music in different rooms.
2. Source Flexibility
Tired of audio devices with very specific sources of input? In those cases, you were only able to input soundscape through Wi-Fi or Bluetooth and no other sources.
Well, the multi-zone receiver solves this problem for you as well. Now, you have several input options, such as HDMI, optical, RCA, Bluetooth, and WiFi. On top of that, you can even stream music from various music streamer sources such as Spotify, Pandora, and internet radio. How cool is that!
In addition, connecting a multi zone receiver with a DIY Bluetooth speaker does wonders for you as well. With a Bluetooth amp in it, Bluetooth preamp, or perhaps a Bluetooth amplifier for wired speakers, you will enjoy great sounds.
3. Control Options
Have you found it bothersome when you could only control the audio device through a remote or perhaps only through that device itself? How bothersome it was!
Worry not. A multi-zone receiver offers various control options that will make its usage extremely convenient. For instance, you can control it either through traditional remotes or through smartphone/tablet apps. Besides this, even voice control is possible.
4. Video Distribution
Now you have different audio playing in different rooms. However, you want to go a step further and add video as well. Even this is possible with a multi-zone receiver. You can now play a movie with rich audio and enjoy it.
5. Power Amplification
Do you dislike it when there are separate power amplification systems for all zones? The sheer amount of it confuses you, and it becomes difficult to recognize which amplifier is for what zone. They also take up a lot of space.
The multi zone receiver solves this problem. It has built-in amplifiers for each zone, thereby making it convenient for you. Further, with it, there are even more expandable options for additional amplifiers.
You can also connect with an Alexa amplifier and have it play you a song. Plus, if you have a 4 ohm speaker and you use it with a good amplifier, you will have great sound quality.
Benefits of Using a Multi-Zone Receiver
We have discussed the key features of a multi zone receiver. Now, let’s look at its benefits.
1. Enhanced Audio Experience
Suppose you have a business event, and you require a substantially robust audio system that delivers sound to each part of the room without any problems. Multi zone receiver is your go-to because it provides you with exactly that.
Adding to it, multi zone receiver allows you to have different soundscapes in multiple rooms - thus taking your audio experience to the next level.
2. Convenience and Flexibility
A multi voice receiver allows you to have only one audio system instead of multiple systems in separate rooms. This one system can play different audio in several zones and has various sources of input, including DIY speaker kits.
You can even manage different audio sources from one location. Isn’t multi zone receiver very convenient and flexible?
3. Space-Saving
With multi zone receiver, you need neither multiple audio systems nor different amplifiers for each zone. You can, thus, save space and use that space to store other things.
4. Personalization
Everyone can have their personalized and favorite audio streaming in their room - all from one multi zone receiver. There can be simultaneously a relaxing tune in the kitchen, soft music in the study room, and a thrilling song in the living room.
Ideal Use Cases
While you can use a multi zone receiver whichever way you want, the following are three cases where its usage will benefit you a great deal.
1. Home Entertainment
In one home in one family, there are different people with differing tastes in music. However, it is not possible for everyone’s favorite tune to be played simultaneously.
With a multi zone receiver, though, this is a possibility. Whole house audio can be easily set up, and you can enjoy different audio in multiple rooms. Even a Bluetooth speaker kit can be connected and make things easy for you.
2. Commercial Spaces
Different spaces in one commercial building require different audio depending on their ambiance and you achieve this purpose through a multi zone receiver. For instance, in a restaurant, you can play soft music in the dining area, whereas you can play a calming tune in the rest area.
Similarly, in a retail shop, children-loving songs can be played in the children’s section, while shopping areas can have other types of music. Targeted announcements in the lobby can be made at the same time.
Integrating ceiling speakers with a multi zone receiver will serve you well for this purpose. You can even use wireless ceiling speakers if you have them.
3. Event Hosting
Whether you are hosting a family gathering, a business seminar, or a wedding, you require different audio in the various parts of a venue. Lively music can be played in one area, while tranquil music can be set up in another simultaneously.
Arylic: Enhancing Your Multi-Zone Audio Experience
Having understood the features and benefits you can have with a multi zone receiver, aren’t you now tempted to get one for yourself and home? If you are, don’t look for other options; go directly to Arylic’s products.
Arylic is the leading brand in the field of multi zone receivers. It offers the best listening experience to everyone. Below are some of their most remarkable products that you would want to have for a rich audio experience.
1. Arylic S50 Pro+ Wireless Stereo Preamplifier
The Arylic S50 Pro+ Wireless Stereo Preamplifier guarantees you excellent sound quality and smooth integration with various audio sources. Wi-Fi, Bluetooth, AirPlay, and Spotify Connect - you name it. Whichever input source you can think of, it will connect with it and offer you the best experince.
2. Arylic A50+ Wireless Stereo Amplifier
Another wonderful Arylic product is the Arylic A50+ Wireless Stereo Amplifier. You will definitely love it because it combines amplification with modern streaming capabilities.
Not only that, it even has the capability to support high-resolution audio and multi-room audio systems without any issues. With this, you have the freedom to control your audio from anywhere in the house.
Or, if you think these are too expensive for you, you can simply create a complete DIY Bluetooth speaker kit (with a Bluetooth amplifier board) for yourself. Convenient, isn’t it?
How to Set Up a Multi-Zone Receiver with Arylic Products
The following is a step-by-step guide for you on how to set up an Arylic multi zone receiver.
1. Choosing the Right Spot
First of all, you need to choose the right spot to place your Arylic multi zone receiver. So, what is the right spot? The answer is simple: place it in the central location of your whole listening area.
This way, your multi zone receiver will encounter minimal interference and wil have the best signal reception. The sound distribution will also be even throughout the venue. Thus, it is extremely important to first position your receiver in the right location.
2. Connecting to Your Stereo
Your next step is to get great stereo sound for a top-notch experience. For this step, you can connect speakers to the audio system.
You can also use Arylic amplifiers and preamplifiers; they will integrate seamlessly with your existing speakers. You can even use stereo amplifiers to achieve your purpose. Nevertheless, this step is necessary to attain great sound quality.
Talking about getting high sound quality, you can also achieve that either with a DIY subwoofer kit or a 2.1 amplifier (it adds a subwoofer in its components). It is yet another way of boosting the lowest frequencies in your soundscapes.
3. Setting Up the Antenna
Now that you have come this far, you need to properly set the antenna, or else you will not get a clear reception.
Arylic products have user-friendly interfaces and give very clear instructions on how to set the antennas for good reception. Once you have set up the antenna the right way, you will have the best reception.
4. Programming Stations
Last but not least, you need to set up your programming stations. It means that you need to save your favorite radio stations for a personalized listening experience. After all, what is the use of going through all the effort and setting things up when you can’t even listen to your favorite songs.
You can easily use Arylic’s interface to not only search but also save your favorite radio stations. How cool is that!
In conclusion, we now know that a multi zone receiver allows you to simultaneously play different audios in multiple zones. In addition to this, a multi zone receiver offers source flexibility, control options, video distribution, and power amplification.
You can have innumerable benefits with it, such as enhanced audio experience, convenience and flexibility, space-saving, and personalization. You can use it either for home entertainment, commercial spaces, and even event hosting.
Arylic is the leading brand for multi zone receivers and you should definitely check out its amazing products, such as the Arylic S50 Pro+ Wireless Stereo Preamplifier and the Arylic A50+ Wireless Stereo Amplifier.
Lastly, in order to set up a multi zone receiver, first place it in the right spot, then connect speakers to audio systems, set up the antenna, program stations, and enjoy.
