A whole-house audio system is a way for you to listen to music, podcasts, and other forms of audio entertainment in all the rooms of your house. It is an incredible way for a music streamer or other people to stay connected to their music. The best part is, whole-house audio systems are very easy to control.
Some of them have panels you can attach to your wall, and some can even easily be controlled from your smartphone. You don’t have to listen to the same thing in every room with a whole-house audio system, and having high-quality audio systems in every room makes the audio system sound even better.
The occupants of the home can choose to listen to different things at the same time. That way, multiple listeners can enjoy their favorite audio entertainment without disturbing each other. In this article, we’ll be taking you through the best whole-house audio systems suitable for your home. Let’s take a look at features to consider in a full-house audio system.
Key Features To Consider In A Whole-House Audio System
Many companies produce whole-house audio systems. Some have amazing features like the Arylic amplifier voice assistant-integration system. There are some key features you should consider that are vital when getting a whole-house audio system. They include:
● Audio Quality
The audio quality of any audio speaker system is very essential as it determines the sound the speakers will produce. No one wants to have a whole-house audio system with terrible audio quality, as that would not encourage them to listen to music or other audio entertainment.
Hence, it is important for your full-house audio system to have good sound clarity and depth. The clearer the speaker’s sound, the better the audio quality. If you’re a Spotify streamer that appreciates good music, getting a system with great audio quality is best for you.
● Ease Of Use
Another important thing to look at in a whole-house audio system is how easy it is to use. I’m sure everyone prefers appliances that aren’t complicated to use, as this saves a lot of effort. A stereo amplifier that is easy to use will undoubtedly be more appreciated.
Some whole-house audio systems come with very friendly user-interfaces. This helps you to navigate through your songs or podcasts easily. Some even have their own mobile applications that make controlling the whole-house audio system much easier.
● Compatibility
Most times, your home’s audio system will have to integrate with other devices to get your desired result. This makes it important for your whole-house audio system to have good compatibility with other devices. If not, you might find yourself not completely satisfied.
Audio systems usually have to integrate with existing devices, and if they are not compatible, you will find yourself in a pinch. Hence, when getting an audio system, make sure it is compatible with your existing devices and streaming platform.
● Expandability
Expandability is also a crucial thing to look at when getting an audio system for your whole house. Thinking about the future is always good, and there might be a time when you actually need to add more speakers to your existing system.
If your audio system isn’t expandable, you might have to get a new one later, which will incur additional expenses. Instead of spending more later, why not get an expandable audio system so you don’t have to switch to another one later in the future?
● Budget
Your budget is always something to consider before making any purchase. There are many brands that market whole-house audio systems. However, they do not all have the same features and prices. Before going to get an audio system, define your budget.
If you know your budget once you visit a store, you will know which brand’s products are available to you. Determining your budget will also help you to find the best product for your price range. Once you know the best product you can afford, the rest is easy.
Top Contenders For The Best Whole-House Audio System
Many companies produce whole-house audio systems. Therefore, it might be a little tough to know the best products on the market. However, I’ve got good news for you. We’ve gone through the process of reviewing various products and have come up with the top contenders for whole-house audio systems. They are:
1. Sonos
Sonos is the top contender when it comes to audio systems for your whole house. It supports more music services and streaming platforms than other brands. A total of more than 130. It has its own app that runs on iOS, Android, Windows, and Mac OS. You can easily control the speakers using the application.
The brand also supports a wide variety of voice-control options like Arylic, Google Assistant, or both. Sonos also has its own voice control system that is tailored for whole-house control and music playback. It’s very popular among full-home audio systems.
Pros
- Incredible compatibility
- High-quality audio
- Bluetooth support
Cons
- The app glitches sometimes
2. Bluesound
Bluesound is also another major contender among top audio systems for homes. It is quite luxurious and has a navigable control app that you can use to control it easily. It features proximity sensors and capacitive-touch control that provide playback control.
The sound quality is also good, and it is built into other high-end audio gear. It is mostly used by lovers of high-resolution music due to the high-end components it utilizes. It provides a reasonable amount of streaming services and doesn’t have a built-in microphone to promote privacy.
Pros
- Handy navigation bar
- Good audio quality
Cons
- No global search on app
3. Bose SoundTouch
Bose SoundTouch audio systems for homes come with incredible unique features. Their whole-house audio system features a screen that displays information about what music is playing and the time. It also features 6 preset buttons that are customizable.
You can easily set your favorite playlists to start playing when you touch the button. It also features an app you can use to use the speakers easily. It connects with Bluetooth or WiFi and also has a voice control feature for easy control.
Pros
- Bluetooth and WiFi connectivity
- Preset buttons
Cons
- No touch screen display
Introducing Arylic - A Competitive Option
Arylic is another top competitive brand when it comes to whole-house audio systems. Our products are durable, reliable, and provide exemplary audio quality for your listening ears. One of the major features of Arylic products is that they are 3x smaller than other amplifiers, but deliver the same quality.
Our all-in-one audio systems offer HD music, versatile wireless connection through Bluetooth, WiFi, DLNA, and UPNP, and rich music sources. Arylic audio systems work with your APPLE devices, and can even integrate with Siri via our AirPlay 2 Amplifier and streamer. They also work with Amazon devices using our Airplay Amplifier for Arylic.
Our devices are rich in music sources and provide top notch music and radio services. You can also play music from your Local files, USB, and NAS. Our products have flexible control. You can navigate our systems from our app, web control, or remotely. You can also use our multi-zone receiver to sync music or play different songs at the same time.
In addition, Acrylic amplifiers allow you to personalize your music with our pro tuning tool. Our products also have custom DIY systems, like our DIY Bluetooth Speaker, that allows you to customize your audio system. The best part is our smart home integration feature that allows you to connect with ELAN, API, and Fibaro.
If you are looking for a whole-house audio system that provides you with the most uplifting experience, then Arylic is the brand for you. Whether you want to enjoy your movie time with family, or remain immersed in your music, our audio systems are perfect for you. Just plug, connect and play.
Detailed Comparison Of Features
Here are some detailed comparisons of the features of Arylic whole-house audio systems and other brands.
● Sound Quality
When it comes to sound quality, Arylic doesn’t fall behind the top brands. Sonos and other top brands provide excellent audio performance. However, the same can also be said for Arylic, and considering the smaller size of Arylic products, this is quite a big advantage.
● User Experience
One advantage Arylic products have over most of their competitors is that they are incredibly easy to set up and use. To use an Arylic audio system, you simply need to plug it in, connect to it, and play whatever you want. This is very helpful since there are no complicated commands.
● Device Compatibility
Arylic products are compatible with Android, Windows, Mac OS, and iOS. They integrate seamlessly with popular devices and audio entertainment services. Unlike some other brands that might experience glitches when integrating. Arylic doesn’t offer as many streaming services as Sonos, but they have most of the popular ones.
● Price
When it comes to cost comparison, we can say Arylic products are more cost effective and affordable than most top contenders, like Bluesound, that utilize high-end components to achieve similar results. It is safe to say that compared to many brands, Arylic products are quite affordable.
A whole-house audio system is a method of connecting multiple speakers in different rooms to a central audio source. It allows you to listen to your favorite forms of audio entertainment in multiple rooms. Some top brands like Arylic offer products that allow different house occupants to play different things at the same time.
If you’re looking for a suitable place to get a full-house audio system, Arylic has the best products for you. Our products offer unique features and are very affordable. Visit our website to check out our products and for more information.
