The best home wireless stereo amplifier for passive speakers to power your bookshelf speakers and ceiling speakers with Wi-Fi, AirPlay, or Bluetooth 5.0 to any room for multiroom listening.
- Support Spotify, Amazon Music, and Apple Music via Airplay, Tidal, and more.
- Multiroom streaming with versatile sources : WiFi, Bluetooth 5.0, NAS, USB disk, Micro USB DAC and Optical in.
- 2.0 CH stereo class-D audio amplifier designed for home speaker systems applications.
- 2x50W ultra power amplifier, HD audio quality, especially for bookshelf speakers and ceiling speakers.
- Gapless Playback, and lossless music with FLAC / MP3 / AAC / AAC+ / ALAC / APE / WAV.
Free Shipping .
Standard Shipping - 7-15 Days
Small but Complete
Small≠Simple
Wireless and Wired Connection
Versatile Music Sources
Smart Features
Listening Wherever You Like
Kitchen
Bedroom
Balcony
Living room
Meet Your Professional Needs
Easy to Set Up and Use
Step 1
Step 2
Step 3
Is there a standby mode on this stereo amplifier to save power consumption?
Yes, without use within 10 mins the wireless stereo amplifier will take a rest automatically. Wake it up by any operation.
How many A50+ stereo amplifier I can connect to my network for multiroom at once?
Actually there is no limitation, as long as your WiFi router is strong enough. By normal home use, we suggest up to 10 stereo amplifiers under a WiFi.
In a multi-room setup, can you play different sources to different rooms at the same time?
Yes, that is available. Switch the input source on the master amplifier then restream to other devices in our 4stream App.
How many speakers I can hook up to A50 wireless setereo?
We suggest you connect a pair of speaker (L+R) to A50 wireless setereo.
Can I connect A50+ to my stereo amplifier as a streamer?
Sorry there is no correspond output to your amplifier, you can consider S50 Pro+ or S10+.
DC 12V-24V
2×50-W into a 4-Ω BTL Load at 24 V
2×30-W into a 8-Ω BTL Load at 24 V
Analog
RCA x1 / 2Vrms
Digital
Micro USB Input x1, Optical Input x 1
Analog
Sub Out x1 / 2Vrms, Speaker Out
Decoding
Up to 24bit/192kHz
Output
44.1khz/16bits, CD quality
20Hz-20kHz
0.03% / 91dB
TPA3116
0.2kg(0.44lb)
2 x 50W
50W *2 (24V 4ohm)
30W *2 (24V 8ohm)
2x50W (4ohm 24V)
2x30W (8ohm 24V)
2x50W (8ohm 24V(Boost))
DC in 12V-24V
DC in 24V/4.16A, 32V(optional)
DC in 24V/4.16A
Sub(Optional)
Sub(Optional)
Sub(Optional)
Phono in
RCA Input (2 Vrms)
Phono Input (MM/MC)
Opt In
USB Type - C
Optical Input(PCM)
HDMI ARC(PCM ONLY)
USB Type C (USB DAC for PC)
Speaker output
Decode up to 192khz/24bits
Output 44.1khz/16bits(CD)
Output 48khz/16bits(CD)
Go Control App
A50+ WiFi Stereo Amplifier,
User Manual, Remote,
24V 4.16A DC Power Adapter,
2-1 RCA Cable,
2-2 RCA Cable, Screw Driver,
