CK30C 3" 60W Coaxial HD In-ceiling Speaker
Sale price$129.00
  • Compact size, 60W big sound.
  • 5" In-ceiling speaker bass level. ( 5" In-ceiling speaker sensitivity level)
  • IP66 protects against dust and water.
  • Easy installation with pre-installed dog leg clamps and press-fit speaker connectors.
  • Spotlight diameter, used as a chandelier or pendant speaker.
⚡Early Black Friday Sale
20% Off Sidewide
Impedance: 4Ω
Quantity: 1
✔Fast & Free Shipping
Advanced acoustic design
More Clear, Transparent, and Big Sound
Featuring a 16-core silk membrane tweeter, this speaker extends the high frequency to 30kHz. It also includes a special customized equalizer that optimizes the high-frequency curve, resulting in brighter treble, excellent resolution, and enhanced vocal detail performance. This makes it a favorite choice among music lovers.
Enhanced sound field
Subwoofer Unit and Vibration Plate
Adopts a passive radiator radiator that conforms to the acoustic volume patent, which enhances the volume of the cabinet and strengthens the low-frequency sink and soundstage
30-60w dynamic power design
Adaptable to A Variety of Amplifiers
Meets IP66 Rating Standard
Suitable for bathroom or outdoor rooftop.(*Waterproof Achieving IP66 Standard from Arylic laboratory test)
Reliable Quality
The fully sealed back cover design ensures optimal resonance for enhanced sound quality. Crafted from ABS material, the shell is both cold and high-temperature resistant, offering protection against dust to prolong the service life of the CK30C speakers.
Application Scenarios
The CK30C in-ceiling speaker is incredibly versatile.
Home Theater
Music Restaurant
Conference Room
3 Mins Easy Installation
Product model
CK30C
Rated power
30W
Maximum power
60W
Frequency response
216-25kHz
Sensitivity 1M/1W
85dB
Which Wireless Amplifier Are Best Match For You?
Arylic wireless amplifier is the best partner for CK30C. We selected our most popular wireless stereo amplifiers. Compare them and choose the perfect match for your needs.
Arylic Recommended Match
H50+CK30C
Best For AirPlay 2
B50+CK30C
Best for TV
A50+ +CK30C
Best For Wireless BGM
WiFi, AirPlay, Spotify Connect, Bluetooth 5.2 aptX HD
Max Power Output
50W x 2
50W x 2
50W x 2
Analog Input
Phono in
Phono in
Analog Output
Sub out
Sub out
Sub out
  • 5 stars: 3 (100%)
  • 4 stars: 0 (0%)
  • 3 stars: 0 (0%)
  • 2 stars: 0 (0%)
  • 1 star: 0 (0%)
R
Renato Habek
Excellent product
Great product with lot's of functions and inputs/outputs. 32V version gives you 2 x 80W power which is more than enough to cover any needs for ambiental music.
A
Amir Revivo
Excellent customer service
Excellent customer service, kind and fast, great company
G
Gopinath Thayyil
Easy to configure and use
I have used few project A30, A50+ , easy to configure, very simple ease to manage single and multi-zone controls also , cost-effective solution as well.
You may also like
