AirPlay 2 music streamer
LP10 Music Streamer
Easy Streaming For Everyone
AirPlay 2Google Cast
Sale price$99.00
Bulk Discount
Share and Earn
30 dyas free return
Expert customer support
1 Year warranty
So Easy
Google Cast 96kHz/24bit
Multiroom Streaming
*Audio Receiver Only: Adds wireless streaming to wired speakers. Cannot transmit Vinyl andf other audio sources to Bluetooth Headphone/HomePods.
Hi-Res Audio
192kHz
24bit
Lan Port
USB Stick
Line In/Line out
Type C Port
For 5V-2A DC power input.
wireless streamer
Seamless Playback from Spotify
One tap inside your official Spotify app streams bit-perfect, lossless audio straight from the cloud to your amplifier.
Your phone acts purely as a remote—meaning maximum sound quality, zero battery drain, and absolutely no interruptions from incoming calls or texts.
Qobuz connect
Tidal Connect & Qobuz Connect
Stream high-resolution music directly from the apps you already use — simple, seamless, and lossless.
wireless streamerQobuz connect
Custom EQ in GO CONTROL App
Personalize the sound to match your space, speakers, or preferences.
*Available on analog output only.
5G High Speed Streaming
Plug And Play
More Ways To Control
  • 5 stars: 56 (75%)
  • 4 stars: 18 (24%)
  • 3 stars: 1 (1%)
  • 2 stars: 0 (0%)
  • 1 star: 0 (0%)
M Lange
Excellent compatibility
Excellent compatibility with various streaming services. Easy to update and setup. Small and easy to place with existing equipment. A great value for the price.
A
Alex
This little box is amazing, get one
This little box is amazing. Plug it in. Plug in your ethernet cable. Authorise tidal, turn on your amp and boom there you go. The entire world of music in your room in amazing quality. Highly recommended product.
T
Tobias
Great little device
Great little device. Works flawless and brings digital life to my B&O Beocenter 9500 setup
A
Anonymous
They are a really good streamer who does high-quality work. I use their stream purely as background content, connected to my DAC via an optical cable. It works great with Tidal and Foobar
L
Lenny P
Love the WiFi capability
I have this in a portable 6-space rack with a Behringer X-32 and Sennheiser wireless mics. I installed a WiFi router to use as an access point so I can control the mixer and stream Spotify from the same tablet over WiFi with more range than Bluetooth. AirPlay works seamlessly with iPads, and AirMusic allows my Samsung tablets to use AirPlay, too.
S
Sergio Bandera
Lp10 for Qobuz connect
After a firmware update, the streaming with Qobuz Connect is working fine . Nice little box.
G
GLR
Lovable streamer
It is a very good streamer, but the poor new remote control does not permit full potentiality. The slider of deep bass on GoControl app is set too high for its maximum, this is dangerous for several motivations, given the very high energy at low frequency that can reach amplifier with only 20% of that deep-bass slider position
T
T.K.
Arylic LP10 in use
After the order the LP10 reached me in short time. Paket was in goog shape.
I use the LP10 as a pure streamer in my home WLAN between my music home server (Jellyfin and/or DNLA) and my preamp. Mainly the Optical Out is in use in my system. For music selection I use the Android app Hifi Cast.
I had some difficulties to put in my WLAN network credentials. It was not possible via Go Control. I managed to do that after some problems via an Android WLAN menue item.
The Go Control equalizer for the LP10 does not effect the optical output (different from Arylic S10+). So I introduced an additional hardware equalizer between preamp and amp to adjust the sound to my amp/speaker combination.
I can use Chromecast on the LP10 only when the LP10 is allowed to reach the open internet. With that considered, it works. Airplay is working well.
With my kind of use I am very happy with the performance of the LP10. The remote is working well. After I got used to how the device reacts, it is working reliably.
Sound and soundstage are great. I identify new features in the music I play and it is real fun to focus on the music again with the help of this little but capable device.
K
Kenneth
Just bought arylic LP10
I bought the arylic LP10 for a couple of months ago, mostly because I use tidal streaming and wanted a product that had TIDAL connect. I came across this little box (LP10). It’s a great little product that serves my DALI active speaker fantastic. Now I stream directly from tidal cloud to the arylic lp10 and it sounds amazing
A
Anonymous
My second one
Easy setup, I use it for Qobuz connect into an avr setup for 2.2 music only. Seamless connection. I bought this second one for some studio monitors. Highly recommend for any music system without network capabilities.
r
roberto castagna
a small box with big performance
Excellent musical quality and easy to interface even for an older person like me
D
Dinos A.
Great but needs some improvements
I received it yesterday, here is my review:
Setup:
Device was connected via Wi-Fi at first. Go control app connected via Bluetooth, but did not find Wi-Fi networks. I connected via ethernet, found out through my router the assigned IP via DHCP and surprise, the LP10 has a web interface!
From the web interface all Wi-Fi networks were discovered, I set up my password, changed the device name, restarted and then voiala! it was connected to my 5G Wi-Fi and immediately detected by the Go Control App. Never had any disconnection problems.
So the setting up was not very straightforward - at least in my case (Samsung phone with Android 15).
I would have preferred if the web gui could be password protected however.
- Installation:
Very discreet unit, integrates fine with any setup.
I would like to have an option to dim or turn of the display.
Use - the Good:
-Bluetooth- works fine, and connects automatically to the paired device when bluetooth input is selected (via the remote control, LP10, or Go Control app
- Google Cast. You have to enable it through the Go Control app (and accept Google terms), then it immediately showed up in the google home app. Works fin as a single g.cast endpoint or added in a group with other g. caste enabled devices. No delays or sync issues in group play.
Use- items that need improvement:
- Radio stations. This needs work since some stations do not work, the selection is limited. Arylic should find a way to let you create a custom station list and add your own stations.
- Spotify Connect. The LP10 shows up only as a Google Cast device, meaning you get the relevant restrictions (no gapless playback, and no lossless audio support). I tried disabling Google cast via the LP10 web interface to see if there was a conflict, also unlinked Spotify from Google Home. Then the LP10 did not appear at all as a target device on the Spotify mobile app. I checked with another Android device, same issue.
- NAS Play. I have a plex server that advertises itself as a UPnP device. It was not detected in the Go Control app, and since I could not find any documentation on NasPlay I am not sure if it is supposed to.
Use- Remote Control
-Very wide IR range, very responsive.
-Still haven's figured out what the "heart" or "1" and "2" buttons do.
Items not yet tested (not currently needed in my setup - but very good to have):
-Airplay
-Aux input
-Optical output
-USB
-Sound
Even though there isn't any published information on the internal DAC / OpAmps, the volume level is great, and the sound quality is excellent (better than Chromecast Audio).
The bass-trebble and EQ in the GoControl app works just fine and allows fine tuning.
Conclusion:
Great device to make your HiFi smart in an affordable manner (half the price from the relevant WiiM that supports both G. Cast and Airplay 2), very flexible, great sound, but the app and firmware need some improvements. I am confident that Arylic will improve this with OTA updates!
J
Julian
Sounds great
I bought this LP10 to replace my Muzo Cobblestone and it's a surprisingly sophisticated upgrade to that old Linkplay unit. The audio quality is noticeably so much better and the Spotify Connect integration is really nice. The unit looks solid and the display is simple but attractive. It's great to have additional inputs for line-in and USB and the remote control is a useful bonus. I'm really enjoying it.
My only cavil is that the wifi setup process is primitive and it lacks support for WPS. It didn't support emojis in my network ID and the only workaround was to rename my network and change the settings on all my other connected household devices which was painful. (Most people might say I was asking for it).
E
Edwin Heredia
LP10 Works Well
Excellent streamer. Did it right of choosing LP10 for my favorite music.
J
Jose Angel Torregrosa Ubetagoyena
Arylic LP10
He tenido un problema con el con la APK GoControl y lo han solucionado. Por lo demás el equipo funciona muy bien.
T
Timothy Jeves
Great product.
I’d say great for the price…but no need to qualify that it’s great for price. Just flat out great.
R
Richard Nassiff
Great product, incredible sound
I ordered the LP 10 and it immediately improve the quality of my sound. I did have some problems with the go control app, but consistently had response from customer support and led me to an updated version of the app that solved the problem. The support was wonderful, the product is wonderful.
K
Kateryna
Perfect for me
N
Napat Ch.
One step back but huge step forward!
Among all the budget streamers I've used so far, LP10 is the easiest to set up and the most reliable. I've never experienced any pauses while playing due to a bad network. And its output sample rate is now more than 44.1kHz! It's nearly perfect for my Topping D50 III.
The setback is that my old favorite Arylic web interface is gone, and I mainly use only the optical out interface, so I cannot use any EQ feature.
b
babatope
How many maximum units can be connected for a residential MultiRoom system on same network
Arylic
Actually there is no limitation, which is based on your home router.
Usually can be very stable for 5-10 units for normal home router. If you use some strong commercial router 50-100 units no problem.
And you can use Lan connection for better stability.
