ACPWorkbench Tuning Tool
Sale price$20.00
  • License key is provided immediately upon order.
  • License is valid for installation on a single PC and is not transferable to other computers.
  • Once sold, virtual products are not refundable.
  • The product is only compatible with Windows operating systems.
⚡Early Black Friday Sale
20% Off Sidewide
✔Fast & Free Shipping
ACPWorkbench
Customize your Favorite Tune
The ACPWorkbench Audio Effect Tool is a program developed by Arylic for adjusting L/R balance, EQ for each channel, DSP settings, system settings, redefine pin assignments and more.
You can customize multiple music styles for your whole house audio with different configurations for different units. Discover your best sound with easy sliding!
ACPWorkbench tuning tool
Fine Tune Each Channel
Separate EQ, gain and DSP adjustments for each channel allow you to compensate for environmental and hardware factors.
The Parametric EQ allows you to make dramatic adjustments to tone across the full spectrum, while various DSP effects shape the sound to fully meet your taste.
A Tool For Developers And DIY Enthusiasts
Not only for advanced audio adjustment, the ACPWorkbench Tuning Tool is also a powerful tool for the DIY enthusiast, allowing you to redefine pin usage, configure system settings, manually upgrade firmware, and more.
ACPWorkbench
Hear the Dynamic Changes Instantly
Real time adjustments let you immediately hear the difference as you adjust the parameters so you can match your favorite music style with ease.
Get ACPWorkbench Tuning Tool Instantly
DSP
ACPWorkbench Tuning Tool Download File x1, User Manual x1, License Key x1
  • 5 stars: 43 (80%)
  • 4 stars: 10 (19%)
  • 3 stars: 1 (2%)
  • 2 stars: 0 (0%)
  • 1 star: 0 (0%)
Easy use of ACPWorkbench
I like the easy use of ACPWorkbench. Also the user interface itself is decent and well-structured.However, when used with the Up2stream Pro V4, it lacks a dedicated delay function to independently adjust latency for the left and right channels. Additionally, the Up2stream Pro V4 exhibits a noticeable noise floor (background hiss), which is particularly audible through the tweeter via my amplifier board.
Furthermore, the analog input signal level (AUX in) on the Up2stream Pro V4 is relatively low compared to Bluetooth or Wi-Fi playback.
It is also somewhat disappointing that the Up2stream Pro V4 features only a single AUX output, despite the underlying DSP/chipset natively supporting two output channels.
Overall, I am satisfied with the hardware, but I definitely see untapped potential for further improvement.
I had a little issue with the licence but asking the support to reset it it worked now fine!
R
Ristea George
Foarte bun
O aplicație extrem de utilă. Am BP50 care este deasemenea un device foarte versatil. Cu acpw am transformat bassul din subwoofer. Foarte multe opțiuni o aplicație care merită cu siguranță banii
V
Vish
ACPWorkbench with A100 - adds DSP and Works Great!
This tool gives access to loads of internal settings of the connected equipment, however I spent some time using it to use PEQ with Arylic A100.
- I could get 10 band PEQ settings on ACPWorkbench
- Different custom PEQ groups could be saved and changed/applied through this tool
- Connectivity was easy with USB cable
* Best part of it is that you can simply apply PEQ in-time and see the effect live. You can tweak the PEW settings in real-time.
I could verify the effect with REQ real time.
Super easy to add DSP to A100..... simply excellent!
P
Pedro Manuel Godoy Soriano
ACPWorkbench with Up2stream Pro V4
I'm very happy with the Up2stream Pro. I have it connected via line-out and also with a coaxial cable directly to the SPDIF pin on my old Onkyo TX-DS 575 X.
I usually use the digital connection since it gives me better results on my amplifier.
You can do a lot with ACPWorkbench, and I like it. I still have a lot to learn.
I've noticed that when I connect it to my PC via USB to use ACPWorkbench, it actually becomes the PC's default audio output, but on the Up2stream Pro, the SPDIF output stops working; the signal only goes to the amplifier through the line-out.
In the app, the SPDIF tab appears with a yellow lock and a red cross. I assume this is normal. I'll try it via the serial interface.
I've turned my old amplifier into an internet radio and I'm converting my CDs to FLAC to put them on my NAS and listen to them via DLNA with the Up2stream Pro.
I'm very happy with the device
Thanks.
P
Pedro Cuso
customer suport
Great and quick answer to reactivate my ACP workbench, very happy
A
Anonymous
Excellent Customer Support and Fast License Recovery
**Excellent customer support and a great experience!**
I purchased the Arylic ACPWorkbench software some time ago. After experiencing a computer problem, I was unable to activate the software again because my original license key had already been used.
I contacted Arylic customer support and received a quick and helpful response. They provided me with a new activation code, and I was able to get ACPWorkbench running again.
As an electronics enthusiast, I really appreciate companies that continue to support their customers after a purchase.
Thank you, Arylic, for your excellent service and professional support. Keep up the good work!
p
paul van ginneken
tuning works quite
tuning works quite wel
L
Lawrence Smiith
Good product overall once you work out what
Good product overall once you work out what everything does.
Some settings don't persist on reboot, but nothing too serious.
N
Norman
Works great
P
Peter Mauri
Super Produkt, leider Schaltnetzteile führen zu Störungen
Ich baue die Geräte gerne in grössere Audio-Anlagen. Dabei verwende ich z.b.
zentral ein Traco 12V Netzteil für mehrere Geräe anstelle von mehreren Stecknetzteilen. Jedoch das Arylic BP50 hat Tonstörungen mit einem solchen Netzteil. Vieleicht könnte das verbessert werden?
K
Konstantin Babylov
Great produkt and service
Made mistake when i was ordering Amp plate. Support solved problem in half day, got my plate in couple of days, sounds great, a lot of features, would buy again.
V
Vuki
Great support
Several years after purchasing ACPWorkbench app I upgraded my PC and app didn't work anymore. I contacted customer support and everything was solved with one email. Perfect!
G
Gunar Hambrecht
F
F NOGOCEKI DE BRITO
t
tonio
Good product
The product allows you to fine-tune the parameters of Linkplay compatible products. However, the license is only valid on one version of Windows installed, if you reinstall Windows on the same machine, the license is lost, it's too bad, IMHO
V
Ventsislav Gyondrov
Up2Stream Amp 2.1 and H50
I have two items from Arylic and I love them both!!! Soon there will be third.
J
J. A.
great quality
support is great and the hardware is very well implemented, I did obtain a good result. It will be better , still , if one could edit /add the web radios.
L
Léo Débois
Markus Blas
Super 👍🏻
Super klang.
Super Funtionalität. Spotify, Amazon music, Bluetooth etc funktioniert super.
Mit ACPWorkbench hat man alles was man braucht um die Anlage perfekt einzustellen (Vorausgesetzt man weiß, was man tut)
Habe 3 verschiedene Geräte im Einsatz
Ein Stern Abzug, weil die Lautstärke Abstufung für mich zu groß sind. Wäre schön, wenn man die Abstufung einstellen könnte.
Bei einer Gartenparty hat ich ein paar Aussetzer beim Multiroom. Kann natürlich an einer schlechteren WLAN Verbindung liegen. Ich teste weiter.
Matthew Jabloner
Such a handy Amp
I know this amp is designed for the back of a boombox but i am using it in an standard 2.1 system. Mounted it in the subwoofer box. Works good and overall super handy with the two apps and the tuning software. I would like some indicator lights showing power and source but that is specific for my application. I am putting together source lights but rather it be built in. Anyway a really nice and flexible amp. And having WiFi is so much better then Bluetooth. Worth it just for that.
e
eric Portal
Your reactivity
Thks for your installing MCP software
D
Darko Vekic
Darko Vekic Dacco doo
I am very satisfied with sound, quality of complete product. Not have any problems with use, and no reclamation from customers!
T
Timo Jaeger
Ein (fast) perfekter Allrounder
Dieses Modul kommt bei mir in einem großen 2.2 (zwei Subwoofer parallel auf 2 Ohm verschaltet) Lautsprecher zum Einsatz, der meine Scheune/Werkstatt beschallt - und das macht der Amp absolut hervorragend auch bis in wirklich unangenehm hohe Pegel. Die Funktionvielfalt in Kombination mit der ACPWorkbench-Software ist gigantisch. Das Feintuning ist zwar nicht mal eben in ein paar Minuten gemacht, das Ergebnis entschädigt am Ende aber definitiv für den Aufwand. Zwei kleine Verbesserungsvorschläge: Ein integrierter Netzschalter mit Kontrollleuchte wäre wünschenswert. Ebenso ist es leider echt mühsam, direkt auf dem Board Kabel zur Spannungsversorgung anzubringen. Die externe DC-Buchse macht in vielen Anwendungsfällen leider keinen Sinn, so dass man gezwungen ist, auf dem Board zu löten. Hier wären ein paar Print-Schraubterminals ein echter Segen. Ansonsten: Respekt für die Entwicklung dieses tollen Moduls. Genau das, was ich gesucht habe!
J
Jon Richings
Up2Stream Amp and ACP Workbench
Very pleased with both. The quality of the streaming and amp are clearly beyond average bluetooth standards, and the workbench makes it possible to tune it to your drivers and environment. My only criticism is that the ACPWorkbench could use better documentation. You can find most of the answers you need on various forums, but it takes some digging.
J
Joerg Schwirz
Up2Stream Plate Amp 2.1 - Multiroom Wireless 2.1 Plate Amp
easy to install and setup - the only point we miss: on/off switch
I
Iordache George
Mick
Bonjour j'ai vu que le logiciel apc était compatible avec le pré amplificateur BP 50 j'aimerais savoir s'il est possible de régler la sortie subwoofer avec le logiciel (coupure de fréquence, gain ...)
Arylic
Oui, vous pouvez utiliser ACPWorkbench pour régler le filtre du subwoofer et le gain de sortie.
(Yes you can use ACPWorkbench to adjust the subwoofer crossover and output gain.)
