LP20 Music Streamer
Google CastSpotify Lossless
Sale price$199.00
⚡Early Black Friday Sale
20% Off Sidewide
  • Support AirPlay 2, Google Cast, Spotify Connect, Qobuz Connect, and Tidal Connect.
  • Support Spotify Lossless, richer detail and clearer sound from lossless streaming.
  • AKM AK4490EQ DAC for clearer, more detailed high-resolution sound.
  • RCA, Optical, PC DAC, Coax, Sub out and USB input for flexible home audio connections.
  • Supports Siri or Google voice assistant.
Share and Earn
Guaranteed Latest Batch
30-Day Risk-Free Trial
Live Human Support
1 Year Solid Warranty
Better Sound, Instantly Upgraded
Upgrade your existing speakers with wireless streaming and enhanced sound in seconds.
ariplay stremaer
You can stream music directly from your iPhone, iPad, or MacBook, and simultaneously synchronize playback with other AirPlay 2-enabled devices.
The LP20 also supports connecting to a HomePod via the Apple Home app, allowing you to synchronize streamed audio with the HomePod.
Google streamer
Google Cast 96kHz/24bit
You can stream music directly from any Cast-enabled app, with seamless Google Cast support and high-resolution audio playback up to 96 kHz/24-bit.
wireless streamer
Spotify Lossless & Connect
Spotify Connect enables one-tap streaming directly from the Spotify app, while lossless playback delivers clearer, higher-quality sound.
Qobuz connect
Qobuz Connect & Tidal Connect
You can play music directly through the Qobuz and Tidal apps, enjoying your favorite playlists and familiar user interfaces.Tidal Max support 192kHz/24bit
ariplay stremaerGoogle streamerwireless streamerQobuz connect
audio streamer
Clean Signal. Real Music.
The LP20 features a high-quality DAC that delivers cleaner Line-out output, making it ideal for connecting to external amplifiers or active speakers for a more refined listening experience.
192kHz
24bit
2.1 System
With the LP20, you can easily build a powerful 2.1 audio system with rich stereo sound and deep bass for music, movies, and desktop setups.
PC Control
Control playback, volume, and audio settings directly from your PC for a more convenient desktop audio experience.
12V Trigger
Use the 12V trigger to automatically turn connected audio devices on or off together.
SW out
Connect a subwoofer to add deeper, more powerful bass.
Connect your TV or game console for stable digital sound, perfect for movies and gaming.
12 Trigger out
Let devices power on and off together for a smoother, more automated experience.
Coax out
Provide stable digital audio output for high-quality audio systems.
PC Control
Connect directly to your computer for cleaner, more powerful sound for music, gaming, and movies.
Seamless Music in Every Room
Install an LP20 in each room to enjoy perfectly synchronized music throughout your home with AirPlay 2 or Google Cast, and move freely from space to space while your music follows seamlessly, playing in sync across all your speakers.
wifi streamer
Stable WiFi
Dual-band WiFi (2.4GHz & 5GHz) with Ethernet support for flexible connectivity.
Stay connected across rooms with reliable coverage, switch to 5GHz for smoother high-quality streaming, or go wired for consistently stable playback when it matters.
audio streamer
USB Playback
Supports USB drive playback with FAT16, FAT32, and exFAT formats (up to 128GB), plus resume playback.
Just plug in your music and pick up right where you left off — with broad support for formats like MP3, AAC, and FLAC.
  • 5 stars: 3 (60%)
  • 4 stars: 2 (40%)
  • 3 stars: 0 (0%)
  • 2 stars: 0 (0%)
  • 1 star: 0 (0%)
L
Luca
Very good device
Very good device. I Wish also the app Will be come even Better and more complete. Satisfied by the quality and price
J
Jaap Pekelaer
Very nice...
I use the arylic to stream Spotify, radio and my music from NAS. Works great and easy to install.
T
Thomas HUNG
Lp20
聲音可以良好產品
d
daniel filion
i love it wok perfecly esy to use
i love it wok perfecly esy to use.
A
Anonymous
Works great with my little amp and Bose speakers
Works great with my little amp and Bose speakers. It does precisely what it was advertized to do with no surprised + or -.
