What Is Bose SoundTouch?
Background of SoundTouch cloud service suspension
Features no longer available:
- Streaming via apps like Spotify, TuneIn, and Pandora is no longer possible.
- Controls via the Bose SoundTouch mobile app will no longer be available.
- Multi-room streaming and preset features will no longer be supported.
Still available features:
- AUX/line input
- Bluetooth or optical input (for models equipped with this feature)
- Playback of local audio from connected devices
The most suitable upgrade solution – Arylic wireless preamplifier
What can Arylic offer:
- Restore Bose speaker access to services such as Spotify, Tidal, Qobuz, and TuneIn.
- Restore Wi-Fi, AirPlay, DLNA, UPnP, and Bluetooth support for your existing Bose speakers.
- Controll via the 4STREAM app and Go Control app for Android and iOS.
- Support Multiroom streaming and is compatible with most Arylic devices.
Simply add an Arylic device to your system, and Arylic can instantly restore the lost cloud service functionality of SoundTouch to your speakers, allowing you to stream music directly from Spotify, Tidal, Qobuz, TuneIn, or your own NAS server via Wi-Fi, AirPlay, or Bluetooth.
From Entry to Excellence: Find Your Perfect Arylic Music Streamer
LP100($399) — True Audiophiles’ Ultimate Preamplifier
- The LP100 features an HDMI eARC interface, phono input/output, and a powerful subwoofer output, filling the entire room with powerful bass. But that's just the beginning – it also offers multiple connectivity options and extensive streaming capabilities, creating a fully functional audio system. In addition, it supports Spotify Lossless and Qobuz Connect.(*Roon Ready coming soon with OTA update)
- Allows for diverse connectivity, giving your Bose SoundTouch speaker different functions.
- Click the link to see more:https://www.arylic.com/products/lp100-music-streamer
Want a direct comparison between the LP10 and S10+?
LP10($99) — Deeper Sound and Smarter Streaming
- LP10 features AirPlay2, Google Cast, Spotify Connect, and Tidal Connect, and can output up to 192kHz/24bit (Hi-Res).If you're looking for a device that's easy to use and delivers high-quality music, choose the LP10!(*Roon Ready coming soon with OTA update)
- Connecting the LP10's Line out or SPDIF out to the Bose SoundTouch's Line in or SPDIF out, the cloud service function can be restored.
- Click the link to see more:https://www.arylic.com/products/lp10-music-streamer
S10+($69) — First Step into Wireless Hi-Fi Streaming
- S10+ can output 44.1kHz/16bit (CD quality) and supports streaming services such as Spotify, Amazon Music, iTunes, Tidal, and Qobuz.It uses Arylic’s own ecosystem to set up effortless multi-room audio.If you want an easy, convenient, and intuitive user experience, then the S10+ is the perfect choice for you.
- Connecting the S10+'s Line out or SPDIF out to the Bose SoundTouch's Line in or SPDIF out, the cloud service function can be restored.
- Click the link to see more:https://www.arylic.com/products/s10-wireless-preamplifier
What are the differences between the LP100, LP10 and S10+?
LP100
LP10
S10+
WiFi(2.4GHz, 5GHz),Google Cast, AirPlay, Tidal Connect, Spotify Connect, Bluetooth V5.4 (support SBC, AAC, aptX, aptX HD, aptX LL, aptX AD, LDAC, LC3), Roon Ready(*Roon Ready coming soon with OTA update), Auracast
WiFi(2.4GHz, 5GHz), AirPlay , Google Cast, Spotify Connect,Tidal Connect, BT V5.2, UPnP, DLNA
WiFi, Airplay, Spotify Connect, Qplay, BT V5.0, UPnP, DLNA
AirPlay, Google Cast, Roon Ready(*Roon Ready coming soon with OTA update), Auracast
Music Service
Play through AirPlay, Google Cast, Spotify Connect or Tidal Connect.
Spotify, Amazon Music, TuneIn, Tidal, Qobuz, Napster, Internet Radio, BBC Radio. iHeartRadio, QQ Music, QQFM.
Power Input
5V/2A Type-C DC Input
5V/1A Type-C DC Input
Analog Audio Input
Line in, Phono in
Line In
Line In
Digital Audio Input
Coax in
PC DAC(Type-c)
eARC
No
No
Audio Format (Up To)
192kHz/24bits (Hi-res)
44.1kHz/16bits(CD)
Control
GO CONTROL APP, Touch Button, Remote
4STREAM APP, GO CONTROL APP, Touch Button, Web, Remote
Remote
How to Connect Bose with Arylic
Option 1: Analog Connection
- Connecting the Arylic's line output to the SoundTouch's AUX input requires only one AUX cable.
- Play music via the Arylic 4STREAM App or through Spotify Connect.
- Recommended devices: LP10 or S10+.
Option 2: Digital Connection
- You can also connect the Arylic LP10/LP100 and SoundTouch models of Bose devices via optical fiber mode for even better sound quality.
- Set the SoundTouch input mode to "Optical" input and control playback via Arylic.
- Recommended devices: LP100 or LP10.
Why Arylic Makes Sense as a SoundTouch Companion
- Arylic can restore streaming playback from SoundTouch: restore Spotify, Tidal, TuneIn, and network NAS playback capabilities to your Bose system.
- No need to replace expensive Bose speakers—just add Arylic.
- Simple installation: Suitable for both modern smart homes and traditional systems, keeping your SoundTouch system working perfectly.
Conclusion — Keep Your Bose SoundTouch Alive
- Regain access to modern streaming platforms
- Enjoy high-quality wireless music again
- Control everything easily from your phone
