LA50 Streaming Amplifier
ARCGoogle Cast
Sale price$249.00
BLACK FRIDAY SALE
20% OFF Sitewide, 25% OFF Orders $600+
Discount applied automatically at checkout.
00 DAYS
00 HOURS
00 MINUTES
00 SECONDS
  • AirPlay 2, GoogleCast, Spotify Connect, Tidal Connect, Qobuz Connect support.
  • 50W × 2 Drivers Most Speaker with Ease.
  • Add Subwoofer for 2.1 Home Cinema.
  • Auto TV Detection & TV Remote Volume Control.
  • Voice Control with your Siri or Google voice assiatant.
Share and Earn
Guaranteed Latest Batch
30-Day Risk-Free Trial
Live Human Support
1 Year Solid Warranty
Build It Right, Upgrade It Smart
Whether you're starting from scratch or replacing outdated gear, bring stable WiFi streaming and native smart control to the speakers you love.
AirPlay 2 Makes Everything Easier
✔ Certified AirPlay for convenience and stable WiFi streaming.
✔ Play anything from iPhone — Apple Music, YouTube and more.
✔ Control your music hands-free with Siri.
✔ Sync with HomePod, Sonos and other AirPlay 2 speakers.
Hi-Res Audio with Google Cast
✔Chromecast built-in for seamless, stable WiFi streaming.
✔Stream in up to 24-bit / 96kHz high resolution.
✔Cast from YouTube Music, Spotify, TIDAL, Qobuz and more.
✔Control with Google Assistant — hands free.
✔Group with Nest and other Google Cast speakers for multi-room audio.
Spotify Connect Built-In
✔Stream directly from Spotify APP.
✔Music keeps playing even if you take calls.
✔Full-quality streaming over stable WiFi.
Spotify Lossless support coming in a future firmware update (Q2 planned).
Tidal Connect
✔Stream directly from the TIDAL app.
✔High-resolution playback up to 24-bit / 192kHz.
✔Stable, gapless streaming over WiFi.
Qobuz Connect
✔Stream directly from the Qobuz app
✔Enjoy true high-resolution audio up to 24-bit / 192kHz.
✔Stable WiFi streaming without compression.
If It Plays on Your Smart Phone, It Plays Here
Stream everything through AirPlay 2 and Goolge cast.
Play Everywhere, Control with Your Voice
Group with HomePod, Nest, Sonos and other compatible speakers using AirPlay 2 or Chromecast built-in. Play the same music across rooms and control it with Siri or Google Voice Assistant.
Drives Most Speakers with Ease
50W ×2 — more than enough for everyday listening.
Delivers room-filling sound with a single pair of speakers, and supports a second pair for wider coverage when needed.
*For multi-speaker setups, ensure compatible impedance. We recommend connecting up to 4 speakers total.
Build Stereo or 2.1 system
Wider Backgroud Music Coverage
Drag
Transform Your TV into a 2.1 Home Theater
Better sound than built-in TV speakers with automatic TV detection and seamless remote control. Add a subwoofer anytime for deeper, cinematic bass.
Control with Your TV Remote
Adjust volume and power — no extra remote needed.
Build 2.1 Home Theater
Add a sub and transform it into a 2.1 home cinema system.
Upgrade Your TV Sound
More power and clarity than built-in TV speakers.
Compact Design, Big Desktop Upgrade.
Roughly the size of two iPhones, it saves space while delivering powerful audio.
Use it as a USB DAC for your PC and experience a clear upgrade over stock computer sound.
Shake with Bass
Shape the bass, adjust crossover points, and control deep bass in GO CONTROL APP to suit your favorite songs, movies, or games.
APP & Remote Control
Use our intuitive app to manage music, switch sources, and adjust settings — full control wherever you are.
The included remote lets you quickly adjust volume, power, and playback without opening the app — simple, convenient, ready-to-use.
  • 5 stars: 16 (89%)
  • 4 stars: 2 (11%)
  • 3 stars: 0 (0%)
  • 2 stars: 0 (0%)
  • 1 star: 0 (0%)
V
Vytautas Belkevičius
Hello,
My impressions are good; for such a small device, it’s quite powerful and sounds good.
T
Tessa Irwin
Easier to install than Sonos
Easier to install than Sonos. Spent hours getting Sonos to work the. Sent it back as the customer services wasn’t sure what was happening either. Bought this instead. Plugged it all in and it worked without me doing a single thing. And a third of the price. It hides nicely behind my TV too as my speaker wires run up the wall into the loft and into the ceiling speakers and the HDMI connects between this device and the tv.
Matija Oblak
Amazing device
Amazing device. Works as intended. Very small but strong enough that it can drive my 2x 50w speakers. Only reason, why I would give it 4.8 stars is that it takes it around 20 seconds to get from standby to ON via hdmi arc signal.
J
John P. Raphael
Great value, perfect for my use case.
It was a breeze to set up with only a few minor glitches (powered off on its own once for some reason, and added me to Google home which didn’t seem necessary). But for the simple functions I wanted, power garage speakers with airplay or a tv optical input as sources, it knocked it out of the park.
Matthew Turner
AirPlay 2 Makes It Way More Useful Than I Expected
Picked up the LA50 mainly for a simple home setup, but I’ve ended up using AirPlay 2 way more than I thought I would.
I can just stream audio straight from my iPhone to the system without messing with inputs or apps, and it shows up instantly every time. For me that’s been the biggest convenience—no setup friction at all.
I also like that once it’s on the network, it basically becomes part of the whole house audio setup. I can start something in one room and move it around without having to think about it too much.
Everything has been stable so far, no dropouts or reconnect issues, which was something I was a bit worried about before using it.
Overall I waited a bit before buying because I wasn’t sure how much I’d actually use AirPlay 2, but it turns out it’s one of the features I rely on the most now.
L
Luigi
Excellent product
Excellent product with an excellent quality/price ratio. Compared to more well-known products, it has nothing to envy. The amplifier's audio quality is excellent, as is the integrated streamer. The DAC also works perfectly when connected via HDMI ARC.
Highly recommended
D
Darek Krysmann
A Great Step Up From the A50 Model
Fast delivery and great product overall. Upgraded from the older A50 model to the LA50 for its hardware and software improvements. The multifunctional volume knob is a great addition, and the full-sized speaker binding posts are a big upgrade. Most importantly, there’s zero hiss or noise floor at high volumes when no audio is playing. Highly recommended!
A
Anonymous
Works
Works great
A
Anonymous
Very Happy!
I have been looking for a replacement for my Crestron system which died so tested a single zone with the LA50. Set up was easy and airplay works perfectly. Will add a few more and replicate a multizone system for a fraction of the cost.
A
Anonymous
Great product
Great product and easy to use
S
Sylvain Bergeron
Excellent product
My Arylic LA50 is an excellent product. It fits very well with my Bose Acoustidmass
T
Thomas Reed
Perfect Upgrade for Our Gym Sound System
We installed this in our commercial gym after our old system started skipping and constantly giving us issues.
This completely solved all the problems we were having, and it gets seriously loud without any distortion.
Also our clients have noticed the difference and they are really happy about the new setup and overall sound quality.
E
Eric Lawson
Great Office Setup with Easy Control
We installed the LA50 in our office a few weeks ago and it’s been working really well for us.
Sound quality is noticeably better than the old setup we had before, and it’s easy for everyone to play music from Spotify, iPhone, or other devices without needing to explain how everything works. Most of the time we just control it from our phones or laptops during the day.
Only small thing is you still need to be on the office Wi-Fi to control it, so remote access outside the building would be nice. Besides that, no complaints so far.
B
Brian Mitchell
Smooth Delivery and Helpful Support
The LA50 arrived faster than I thought it would. The delivery process was simple and no problems.
I had a few set up questions and customer support answered them promptly and clearly which made the whole experience that much better.
Overall, everything from shipping to after-sales support has been pretty smooth.
A
Andrew Scott
Simple Streaming That Just Works
I replaced my old patio receiver with the LA50 mainly to clean up the whole setup and make it easier to use day to day.
So far it’s been great. Setup was simple, the connection has been stable, and I don’t really have to mess with it once everything is running. It powers my outdoor speakers without any problem and the sound is much cleaner than my old receiver.
What I like most is that the whole system just feels more modern and convenient now without taking up a bunch of space.
E
Ethan Miller
Great Sound and Super Easy to Use
I wasn't expecting much when I bought the LA50, but this thing honestly surprised me.
First off, it does basically everything I need in one box. HDMI ARC for the TV, AirPlay 2, Google Cast, Spotify Connect, Bluetooth, USB, optical, RCA... I stopped needing half the extra gear I had before. TV remote volume control through ARC also worked immediately which was a nice surprise.
Sound-wise, it's way cleaner than I expected at this price. No hiss, no weird noise, just a pretty neutral sound overall. I've been using it with bookshelf speakers and it has more than enough power for normal listening. Adding a subwoofer made the setup even better.
The streaming aspect is probably my favorite part. Being able to play music directly from streaming apps like Spotify, Qobuz, and Tidal, rather than relying on Bluetooth all the time, feels smoother. The multi-room effect is better than I thought too.
Setup was easy too — I had everything running in maybe 10 minutes.
Honestly, the LA50 feels like one of those products that's hard to go back from once you use it. It just makes daily listening really convenient without sacrificing sound quality.
a
alex
Great balance between functionality and audio quality.
I’ve been really impressed with this audio amplifier. It offers a very complete set of features, making it versatile enough for a wide range of setups and listening preferences. The overall sound quality very good—clear, well-balanced, and powerful without distortion, even at higher volumes.
One feature I particularly appreciated is the dedicated subwoofer output.
Overall, this amplifier strikes a great balance between functionality and audio quality.
S
Stuart Buchanan
Great combined Streamer and Amplifier
This product is excellent and competes with others like Wiim at a cheaper price. It really is a 5 stars from me, with the exception of a more confusing setup. I already have other acrylic product. And it was not obvious that you have switched this to a new go control app for this amplifier. I was trying to use the same app I already have which wasted lots of time. I do think this should change should have been made clearer in the manual and now is just awkward remembering which application is needed for which amp.... Would it have been too hard to expand the functionality of the existing app?
A
Alro
What about Spotify Lossless?
Arylic
Yes LA50 supported with latest firmware
