Most outdoor speakers require a separate receiver or amplifier to function. Not sure if you require one? Or what exactly should I get? Let’s read this article. We will tell you what you need and want to know, and also some product recommendations.
What Is The Amplifier or Receiver For Outdoor Speakers?
As we know, most good outdoor speakers are passive, so they cannot generate enough power to drive themselves. The major function of an amplifier is to generate this kind of power. After that, it will move the components of the speakers to produce sound waves.
A receiver, on the other hand, is a device that includes an amplifier. It is typically used and may require in sound/home theater system setup. However, a simple amplifier also can power speakers too.
Do You Need The Amplifier/Receiver For Your Outdoor Speakers?
Many of us prefer passive speakers, such as in-ceiling speakers. We will use them to set up a sound system in our home. There will be no electrical plugs, audio jacks, or power adapter cables in the speaker box. You need to be aware of this.
Compared with the passive speaker, active or self-powered outdoor speakers may be convenient for you. Because you have no need to prepare additional accessories. If you do not want to equip those accessories, then the wireless/portable outdoor speakers may become your other option. So that you have no need to use another amplifier/receiver.
How Much Extra Cost Will An Amp/Receiver For Outdoor Speakers Take?
It will not cost you much to purchase an amplifier. On Arylic website, you can get an amplifier board below $100, and purchase a finished amplifier below $200. The decent price for a good budget amplifier/receiver may be between $150 to $200. It depends on what you need to complete your home audio setup.
Does An Amp/ Receiver For Outdoor Speakers Need to be Weatherproof Too?
In fact, it doesn’t. Also, it makes no sense with the weatherproof function. Receivers in the market and modern budget amplifiers often include Bluetooth. This feature enables you to control music from your device while outside.
But the significant factor you need to pay attention to is the use of wires to connect your speakers. You need to make sure the wire is graded for outdoor runs, through-wall runs, or underground runs.
Okay, now that you hopefully understand and know whether you need or do not need an amplifier/receiver. Let's talk about how to choose the right product based on a few key factors:
First Consideration: How Many Speakers Will There Be?
Most people prefer a simple 2.0 audio setup. Such as two speakers on the deck and any other standard two-channel receiver or amplifier. If you need more speakers, then you need amplifiers/receivers with more channels.
In the audio product market, we can find various amplifiers/receivers with different channels. Such as two, five, or seven speaker channels, and one or two subwoofer channels.
Please remember: most outdoor subwoofers are passive, but most home theater system subwoofers are active.
Most receivers with sub-out connections are not amplified, then this device cannot be compatible with a passive outdoor speaker directly. In this situation, we need an additional amplifier between the receiver and the outdoor subwoofer.
Second Consideration: You Need Enough Power
The metric that can tell the quality of an all-weather loudspeaker system is power handling. Especially in an outdoor setting where sound cannot travel nearly as well.
Certainly, the amplifier/receiver must supply power to the speakers. If the power is too little, the speakers will underperform. Too little power is more likely to damage speakers than too much power.
It is better to choose a receiver for your outdoor speakers. Sometimes, most people want to upgrade or increase the number of speakers in their home audio setup. Thus a receiver is more convenient for you.
Another factor you need to consider is if you want to run long wire runs. Maybe this is not an essential factor for most people, but on a wire run longer than 200 feet, the power that eventually reaches a speaker will have begun to drop by about 5%.
Third Consideration: Features
What function do you want your amplifier/ receiver to come with? Maybe you want to control the music while you're outside, so wireless compatibility is essential. The last one is remote, or ideally Bluetooth compatibility, so you can control it directly from your source.
Important Truth About Buying Audio Equipment
Prices may be the most significant factor when you are choosing an amplifier/receiver for your outdoor speaker.
But how can we know what amplifier/receiver suits your outdoor speakers? Check the following information.
The first one is the basic amplifier on Arylic Website, the A30+ Mini Stereo Amplifier.
For this amplifier, you can drive a pair of stereo speakers with 30W. Maybe this is not enough for some outdoor speakers if you need to hold a party in a large garden or a swimming pool.
But when you want to install your stereo speakers on the balcony or want to listen to music in your courtyard, this is enough.
The second is the A50+ wireless stereo amplifier. For this one, you can use this to hold a swimming pool party or a birthday party in your garden. It is enough to drive your speakers and your friend also can control the amplifier. So they can choose the music they like.
The third one is the newly released amplifier, B50 Bluetooth Amplifier. This Bluetooth amplifier not only can connect passive speakers, but it can also connect to two Bluetooth devices. Comes with receiver and transmitter functions, so it will take more fun for you and your families.
Final Thoughts
It is not necessary to choose the most expensive amplifier/receiver for your outdoor speakers, but you need to learn more information about the amplifier/receiver and your outdoor speakers’ information. Then pick the one that suits your outdoor speakers most.
