Antennas
Important Note
Our DIY Audio Products move to Up2Stream.net, Please buy here.
促销价格$10.00
🚨 Holiday Shipping Notice
Due to the holidays in our area (Oct.1-8):
📦 Orders (Oct.1-8) : Shipping resumes Oct.9 (Delay expected)
🌎 US/CA/EU Orders: Shipped AS USUAL ✔️
现货
Antenna: External Antenna(A pair)
Product
External Antenna
Internal Antenna
Gain
3 dBi
3 dBi
Length
Antenna 11 cm
Internal Cable 15 cm
20 cm
Weight
0.1g
0.05g
Type
Antenna-Female
Internal Cable-Male
RG1.13
Connector Type
RP-SMA
IPEX/Welding
Frequency
2400-2500MHz
V.S.W.R
<= 2.0
Impedance
50Ω
Set Up
FPC Paste
Internal Antenna cable x 2
External Antenna x 2
Nut x 2
Gasket x2
Internal Antenna x 2
Based on 15 reviews
87%
(13)
13%
(2)
B
Barry Needle
Great board.
The board does everything it claims, very well. The only thing I would criticise, is when ordering the IR extension it should tell you that you will need another board as the supplied cable will not plug in directly. I connected it by using spare plugs to the main board to make it work. All in all I would recommend this product and will probably order again for future projects. Now it is fitted inside an old Yamaha AM FM tuner with the addition of 1 multicoloure LED on the front.
N
Norbert Fiebig
One of the best digital Amps
I've never heard a better digital amplifier in this price range. The features are really good, and the performance lives up to the claims. But the best part is the sound. When the components work together, you get really good sound and a lot of fun.
H
Hector Sapien
Good enough for now
Working so far… Reliably sounds good!
D
David Kroeze
Antennas
L
Lex Barton
DIY
Modules work as intended
Ν
ΝΙΚΟΣ ΘΩΜΑΔΗΣ
excelent service
excelent service and help from Coco.AAA++
