Up2Stream Mini - Multiroom Wi-Fi Streamer Board (No Amp)
促銷價$39.00
-WiFi, Airplay, Spotify Connect, Bluetooth 5.0, DLNA, UPnP wireless connectivity support.
有庫存
Features
Wireless Connectivity
Up2stream Mini supports WiFi and Bluetooth 5.0, allowing for easy streaming of music from various sources such as smart phones, tablet, laptop, and computer within your local network. Additionally, the device supports popular protocols such as Airplay, Spotify connect, DLNA, and UPnP, providing seamless wireless music streaming capabilities.
Lossless Audio
The Up2stream Mini is capable of supporting a wide range of lossless audio formats, such as FLAC, MP3, AAC, AAC+, ALAC, APE, and WAV. Additionally, it can decode up to 192kHz/24bits and deliver CD quality audio output of 44.1kHz/16bits.
Music Services Support
Versatile Music Sources
The Up2stream Mini offers versatile streaming options, allowing you to easily stream music from various sources such as music services, NAS, phone storage, SD card, and other 3rd-party apps that support Airplay, DLNA, and UPnP protocols. This provides you with a wide range of choices when it comes to selecting your preferred music source.
Additionally, the device comes with Bluetooth 5.0, enabling you to stream audio from your smart devices seamlessly. This means you can enjoy your favorite music on the go, without the need for any additional cables or devices. With its multiple streaming options, the Up2stream Mini makes it easy to enjoy high-quality sound from a variety of sources.
Multiple Interfaces
The Up2stream Mini comes with a range of ready-to-use interfaces, including a 3.5mm line out, micro USB audio input, and a plug for SPDIF out, IIS out, Line Out, LED Indicator, and ADC-key. Which enables you to create a flexible system according to your specific needs. With these features, you can easily connect your audio devices and enjoy high-quality sound without any complicated setup.
Multiroom/ Multizone
Enhanced Up2stream
The Up2stream Mini offers several optional expansion boards that can be used to enhance its functionality and performance. These expansion boards include the Up2stream SPDIF board, Up2stream button board, Up2stream ESS9023 DAC board, Up2stream IR extension board, and Up2stream volume knob board. Each of these expansion boards provides unique features and capabilities that can be used to customize and improve the performance of your Up2stream Mini device. You can find all the boards in Accessories.
USB Sound Card for PC
Once you connect the Up2stream Mini to your PC, it will be detected as a USB sound card. This allows you to stream audio from your PC directly to other devices connected to the Up2stream Mini. This feature provides a convenient way to extend your audio playback capabilities beyond your PC. Support both Windows & Mac PC.
ACPWorkbench Tuning Tool
The Up2stream Mini offers a range of communication options, including HTTP API, UART, and TCP commands, providing flexibility for users to integrate the device into their existing smart home systems or to develop custom applications. Get API files below in the download portion and check the cases in our forum.
With the 4STREAM app, you can rename your Arylic streaming device's WiFi SSID and Bluetooth name. The changes will stay even after a factory reset, until you change it again.
Optional Remote Control
The optional remote control is a useful addition to the Up2stream Mini, providing an easy and convenient way to control your music playback from a distance. Like play/pause, deep bass, adjust volume, and quick switch preset content from a distance.
*1. Warning: Up2Stream Mini must use 5V-1A DC input, higher voltage power
supply may damage the board.
*2. Up2stream Mini need ACPWorkbench tuning tool to switch the spdif configuration from spdif out to spdif in.
Newest Firmware Version
Wireless Network
Power Input *①
5V-1A 2 pin connector
5V-1A micro USB input
Audio Input
Micro USB Input
Audio Output
Analog:
3.5mm Line Out (1 Vrms)
Digital:
I2S Out,
*②SPDIF Out (44.1KHz)
Not sure which one to choose? We selected all of our music streamer boards. Compare them and choose the best version for your needs.
① Up2stream Mini V3 need ACPWorkbench tuning tool to switch the SPDIF configuration from SPDIF out to SPDIF in.
Music Service
Power Input
5V/1A Micro USB
5V/1A Micro USB
5V/2A Type-C
Analog Audio Input
Aux In(3.5mm Jack & Pin)
Aux In (Pin)
Digital Audio Input
Spdif In (Pin)
Analog Audio Output
Aux Out (3.5mm Jack & Pin)
DAC: Integrated
DAC: Integrated
RCA (RCA & Pin)
DAC: ES9038Q2M
Digital Audio Output
I2S Out(Pin)
Spdif Out(Pin)
I2S Out(Pin)
Spdif Out(Pin)
I2S Out(Pin)
Spdif Out(Opt & Coax)
Audio Format (Up To)
44.1khz/16bits(CD)
44.1khz/16bits(CD)
192khz/24bits (Hi-Res)
USB Playback
ACPWorkbench
Remote
Optional
Optional
Optional
Expansion Boards
*①Spdif In Board
Spdif Out Board
DAC Board
Button Board
Volume Knob Board
IR Sensor Board
*①Spdif In Board
Spdif Out Board
DAC Board
Button Board
Volume Knob Board
IR Sensor Board
*②Spdif In Board
*②Spdif Out Board
*②Button Board
*②Volume Knob Board
*②IR Sensor Board
Display Panel
Suggestion
For single wireless projects
For Multiroom and Multi zone receiver Projects
Build Your Wireless Projects
wireless speaker
Wireless Speaker
Shared by Gary Ingram
diy suitcase speaker
Wireless Suitcase Speaker
Shared by Maarten Hekman
diy amplifier
Upgrade Your Amplifier
Shared by Simon Baynes
diy multiroom audio
DIY Multiroom Audio
Shared by Stefano
Compatible Accessories
促銷價$7.90
ESS9023 DAC boardbutton board
促銷價$10.00
ACPWorkbenchDSP tool
Based on 319 reviews
93%
(296)
7%
(22)
L
Luca Tulipani
Almost perfect
It's a very valid product easy to setup and use. I already have 4 in my house. To be perfect I would love to see an official home assistant integration developed by arylic and also an landscape mode in the android app.
P
Peter Taylor
Simple device for a simple purpose
This up2stream mini was paired with a bookshelf setup that had an integrated amp. Coming from a dying original chromecast audio, switching to this was almost seamless. I was even able to recycle the old chromecast connectors.
If you use major streaming platforms for music like Spotify or Apple Music, you don’t even need to keep the 4share app on your device after setup. I am happy to have one less google thing and also one less app overall on my devices.
The connectivity is instant when going to use it. No lag, no having to redo connections like I was having to do with my chromecast. Bluetooth is there if you need it, but I specifically picked this because of the wifi - no messing with signal due to physical barriers.
The optional acrylic casing is worth it if you intend to have it freestanding and don’t want to mess with measuring and cutting your own.
It’s really cool to have a readymade device with optionality to be built into future applications if I wanted, while also being good at being a pre-amp receiver right out of the box, all for such a low cost.
A
Andrey Smirnov
Up2Stream mini and old radio of 1953
I purchased this card and connected the pickup to the 1953 retro radio without any problems. The sound is amplified through the original tube amplifier. Everything is fine, the sound is great. It is a pity that Russian radio stations are not working.
F
Frederik
Easy setup - haven't got any problems in almost 2 years
I have 2 up2stream mini-modules that I use daily to stream the radio or Spotify.
D
Denise Riediger
tutto ok da provare All ok works great advice seller
Michael Johnson
You May Also like
