Up2Cast Amp with Auracast Bluetooth Broadcasting Amplifier Board
促銷價$69.00
  • Build your own Auracast/LE Audio Bluetooth broadcasting amplifier or speaker.
  • Maximum output of 50W x 2, with a jump switch to select L Mono, R Mono, or Stereo modes.
  • Capable of broadcasting all inputs, including Bluetooth, Line In, Optical In, USB stick, and USB DAC.
  • Compatible with other Auracast-enabled devices.
  • Supports aptX, aptX HD, aptX LL, aptX AD, and LE Audio for superior sound quality.
Bundle: One Unit
The First
AURACAST Amplifier Board
New Audio Experience
Bluetooth Sync
Up2Cast AMP is a Bluetooth amplifier board that supports LE Audio and the Auracast broadcast function. It allows you to send audio from one master Auracast device to multiple slave Auracast devices simultaneously via Bluetooth.
As long as you remain within the Bluetooth broadcasting range, there is no limit to the number of slave Auracast devices you can broadcast to.
What is Auracast?
SBC, AAC, aptX, aptX HD, aptX LL, aptX AD, LE Audio
Bluetooth Distance
30M
Bluetooth Broadcast
Auracast
Bluetooth Broadcast Distance
10M
Power Input
12V – 24V
Included in the box
up2cast amp
Up2Cast AMP
antenna
Antenna
phoenix connector
4Pin Analog Connector
Screw Driver
Screw Driver
manual
User’s Manual
auracast speaker
Add Auracast To Your Sound System
Add Up2Cast to each sound system or DIY audio project, and your system will become an Auracast-enabled device. It can then broadcast audio or receive broadcasts, allowing you to create a series of wirelessly grouped speakers.
Broadcast Any Sound
You can Auracast any audio source supported by Up2Cast to another Up2Cast or Auracast-enabled device. For example, play music from your phone via Bluetooth and broadcast it to other Auracast-enabled devices.
Group with Auracast Devices
You can broadcast to multiple Auracast-enabled devices simultaneously, such as Auracast speakers, earbuds, headphones, and hearing aids.
New Bluetooth Technology for Superior Sound Quality
LE Audio
LE Audio
Up2Cast AMP supports LE Audio, a new Bluetooth audio standard that offers multiple benefits, such as enhanced audio quality through the LC3 codec.
It delivers superior sound at lower bitrates compared to older codecs. Additionally, LE Audio supports multiple audio streams and improved device pairing, providing a more seamless experience across various Bluetooth devices.
aptX Adaptive
aptX AD
Up2Cast AMP supports aptX, aptX HD, aptX LL, and aptX Adaptive, allowing you to build high-quality Bluetooth amplifiers or speakers for music or gaming.
Enjoy superior audio with your aptX-enabled devices.
More Efficient and Stable
Auracast offers a highly reliable connection, enhancing the experience with our audio products and minimizing interference in crowded wireless environments.
Group For More Power
Up2Cast Amp delivers 50W per channel when connected to a pair of stereo passive speakers. If you need more power for your sound system, you can activate the Mono L/R jumper and connect additional speakers, providing 100W per channel.
100W amplifier board
Total 100W
200W amplifier board
Total 200W
拖曳
Easy Broadcasting with GO CONTROL APP
The free iOS & Android GO CONTROL app allows you to easily control both broadcasting and receiving broadcasted audio.
audio amplifier with DSP
Fine Tune Your EQ
Quick get your favorite music style like pop, jazz, rock or customize yourself in the APP. You also can adjust crossover frequency and L/R balance in the APP.
USB Player
Play Your Favorite Playlist
GO CONTROL APP support browse and play the songs in your USB flash drive.
Fine Tune Your EQ
audio amplifier with DSPUSB Player
Tune Like Expert
Up2Cast supports the advanced ACPWorkbench tuning tool, allowing you to customize specific EQ settings for each channel.
Compatible Accessories
ESS9023 DAC boardbutton board
促銷價$10.00
oled displayoled screen
remote controlremote control for DIY boards
促銷價$10.00
ACPWorkbenchDSP tool
Based on 3 reviews
100%
(3)
D
Doron Strikovski
R
Roman
Arylic Up2Cast amp with Auracast review
Up2cast amp review(eng) 👉:
Judge.me YouTube video placeholder
R
Roman
Видео обзор платы Up2Cast amp
Всем привет,плата работает отлично,очень много входов,можно раздавать аудио сигнал по Auracast на другие устройства,есть приложение,подключил три платы в режим три-ампинга,но об этом подробнее в видео 👉:
