S10 WiFi Music Streamer
20% OFF NOW
促銷價$55.20 原價$69.00
已售完
Connect S10 WiFi music streamer to your traditional audio gear to stream online music, internet radio, NAS, USB Stick, phone storage, line in audio and more from all your favorites.
✔Fast & Free Shipping
S10 muisc streamer review
Music streamer
Entry-level WiFi Music Streamer
Easily Stream Your Audio Wireless
The S10 is a great WiFi music streamer for new wireless audio players to get started on budget.
The S10 wireless audio receiver allows you to stream audio to your home audio system wirelessly via WiFi, AirPlay, Bluetooth 5.0 and Spotify Connect.
You can also add other Arylic wireless streaming devices to build a multiroom system, manage and control all your wireless audio devices in one app (4STREAM)!
Multiroom Audio System
Mix and match any combination of Arylic streaming devices to create a custom multiroom system and play the same music throughout your home, send different sources to each room at the same time, or create your own custom-defined multiroom zones...
All are controlled via our 4stream App.
multiroom streaming
Kitchen
Wireless ceiling speaker for kitchen.
Bedroom
Wireless music streamer for desktop system.
Balcony
wireless ceiling speaker or on wall amplifier for your balcony or gardan.
Bathroom
Wireless music streamer for bathroom.
Living room
Spotify Connect
ACPWorkbench tuning tool
Tune Like An Expert
Fine tune your listening experience with our exclusive ACPWorkbench tuning tool.
Find the perfect sound for each channel with EQ, Bass Enhancement, Advanced DSP effects, Gain, Pregain and more.
Control In Any Way
4stream app
Take full functionally control via our 4STREAM app with network, streaming your favorite sounds, multiroom control and other personalize settings.
Airplay
AirPlay
Stream any audio directly from your iOS system.
Bluetooth 5.0
Play any sound from your smart devices and paired with our streaming devices.
web control
Quick web control without app, enjoy your preset content and personal radios in a sec.
remote
Remote Control
local remote control without network.
*optional (check if the package includes or purchase in accessories)
Newest Firmware Version
Wifi
Ethernet
Streaming Protocols
Based on 329 reviews
81%
(266)
17%
(55)
2%
(6)
1%
(2)
I
Iason giraud
s10+
I received the streamer, and it works great! Some key issues than need to be taken into account on the next firmware update.
it needs to include TIDAL Connect asap, since it is very inconvenient to use the app to link to tidal. I use it with an external dac.
also note that the optical outputs 44.1khz audio quality that is the high setting in tidal, which is more than ok for the 90% stereo systems out there.
very happy overall, it needs a firmware updata ASAP for Tidal Connect.
4 starts for not including tidal connect, which should be a firmware and not hardware issue.
Miguel López Díaz
muy buenos productos
sollo una duda con el lp10 no me pude conectar al nas de hechos es un disco duro externo de 1giga de musica que lo conecte en un router con usb
W
Wes Kelley
No AirPlay 2 but still good
Easy install works as advertised. Hopefully Airplay 2 will come in an update.
A
Andriy UA
S10+
The C10+ is a very high quality and convenient product. There is nothing superfluous. I listen to it through an external HiFi amplifier and am very pleased with the sound quality. Especially HiRes.
s
stevolingam
S10 streamer
Nice unit, sounds great on internet radio
Miklos Nedenyi
S10+ WiFi Music Streamer
