BP50 Bluetooth Preamplifier With ESS ES9023P DAC
Sale price$99.00
  • ESS ES9023P DAC 192kHz/24bits.
  • Bluetooth 5.2, aptX HD, aptX LL, aptX Adaptive, AAC, SBC.
  • Transmit and receive music with aptX HD.
  • Transmit to 2 Bluetooth headphones simultaneously.
  • HDMI ARC in, Phono in, Optical in, RCA in, Sub out, Optical Out, Coax Out, RCA Out and more.
  • Free APP and Remote Control
    Plug Type: EU
    ✔Fast & Free Shipping
    Upgrade Your TV Experience
    Heading
    BP50 is a preamplifier with HDMI ARC and CEC features. It can decode up to 192kHz/24-bit TV Audio with PCM format.
    *CEC supports TV and the BP50 sync power on/off and volume control.
    ESS ES9023P DAC
    ESS Sabre ES9023P DAC
    The BP50 utilizes the ESS Sabre ES9023P DAC, the DAC supports decoding up to 192kHz/24bits, and offers a dynamic range of 112db.
    By high resolution and high dynamics, the BP50 can reproduce more music details and bring better sound performance with your audio gears.
    Wireless Convenience without   Compromising Sound
    Upgrade Your Sound System to Wireless
    You can use your phone to connect the BP50 wirelessly and play music through it to speakers.
    You only need to use your phone to control it and get a wireless home audio system.
    Smoothly and Stable Listening Experience
    Supported by Bluetooth 5.2, and low latency when you are playing music, audiobooks, and radio stations.
    Within a 10-meter range, you can connect to the BP50 preamplifier via Bluetooth easily and enjoy music.
    HD Bluetooth Audio
    Built-in ESS ES9023P DAC and QCC3040 Bluetooth chip, BP50 supports aptx HD, aptX LL, aptX Adaptive, and AAC high-quality Bluetooth codec.
    You can use the BP50 to transmit and receive HD music audio with your audio gears.
    Transmit to 2 Bluetooth Headphones Simultaneously
    You can switch the BP50 to Bluetooth transmitter mode, and connect 2 sets of Bluetooth headphones at the same time.
    After that, both of them will play the same sound from TV, Turntable, and other input sources Simultaneously.
    Enjoy high-quality movies, music, and gaming sessions without disturbing your family's peace.
    All-in-one Preamplifier
    BP50 has various interfaces with Bluetooth transmitter and receiver features.
    5 inputs and 4 outputs: HDMI ARC Input, Phono Input, RCA Input, Optical Input, USB input, Sub Output, Type-c DAC Output, Optical Output, Coax Output.
    GO CONTROL APP
    Convenient wireless control and custom settings
    Tune Your Own Sound
    Customized EQ with ACPWorkbench
    BP50 is compatible with the ACPWorkbench software, and you can adjust the EQ settings.
    You can adjust the frequency of each channel, balanced sound, and more configurations.
    With this ACPWorkbench tunning tool, you can adjust different EQ details and meet your music listening habits.
    Small, But Handles All Your Needs
    Bluetooth Standard
    5.2, 15m
    Bluetooth Transmit
    Bluetooth Receiver
    Bluetooth Codec
    Newest Firmware Version
    0051-ba37596b
    Which Wireless Preamp Are Made For You ?
    Not sure which one to choose? We selected our most popular wireless stereo receiver. Compare them and choose the best version for your needs.
    Bluetooth 5.2 aptX HD, aptX, aptX LL, aptX AD, AAC, SBC
    Bluetooth 5.2 aptX HD, aptX, aptX LL, aptX AD, AAC, SBC,Bluetooth transmitter and receiver
    WiFi, AirPlay, Bluetooth 5.2 aptX HD, aptX AD, AAC, SBC
    Analog Input
    Phono in
    Phono in
    Analog Output
    RCA Out
    Sub out
    Sub out
    RCA Out
    Digital Input
    USB Type - C
    USB Type - C
    Digital Output
    Coaxial Out
    Optical Out
    Coaxial Out
    Optical Out
    You may also like
