BK501/651 2 Way Bookshelf Speakers
Sale price$569.00
⚡Early Black Friday Sale
20% Off Sidewide
-100W, HiFi sound.
- High-end Heil AMT Tweeter.
- Treble up to 40khz, feel detailed treble clarity and brightness.
- 180° Wide soundstage, enjoy high quality pure vocals and instruments in every corner.
-Innovative design of 5"/6.5" Fiber glass Mid-woofer with outstanding heat dissipation and no distortion.
-FSC Environmental Certification
- 15mm (BK501) - 18mm (BK651) super thick MDF cabinet design.
Speaker: BK501 ( 5 inches/1 Pair)
✔Fast & Free Shipping
Bk651 Bookshelf Speakers
best budget bookshelf speakers
best hifi bookshelf speaker
Your Brilliant HiFi Bookshelf Speakers at Home
BK501/651 is a passive speaker that built for HiFi stereo sound system. You can feel the surprising crystal clear and bright treble, full midrange, fantastic deep bass and dynamic sound.
With our sonically engineering construction design, you can hear every details from the original sound.
Compared to other tweeters, Arylic bookshelf speakers Heil AMT tweeter uses a folded Kapton ribbon diaphragm in addition to a high-grade black diaphragm. Due to the advanced craftsmanship that makes the vibration area is larger, appearance is better and makes the sound clearer and brighter.
Enjoy Pure Sound Of Vocals and Instruments
The treble high-frequency can go up to 40Khz, which delivers clean, detailed, and highly dynamic output.
It also can wider treble soundstage to 180°, makes you listening to high quality music in any corner. Enjoy immersive concert in your rooms.
best hifi bookshelf speakers
Powerful HiFi Mid-Woofer
The 6.5" mid-woofer of BK501/651 bookshelf speaker uses glass fibre cone, S-type paper cone and air permeability design. Which can enhance the sound transmission much longer, lower the attenuation and have better heat dissipation.
Let you enjoy the full and revealing midrange and powerful bass in your home theater system. No longer have to worry about putting too loud bass will have the problem of distortion.
rear speaker
Scientific Speaker Cabinet Design
BK501/651's cabinet is made of thickened15-18mmMDF and scientific inverted phase tube, which is developed by experienced acoustic engineers after more than 900 days of research and development with professional acoustic tools.
Precisely calculated volume and cabinet design can reduce resonance and slant vibration noise, brings you incredible sound enjoyments.
Sonically Engineering Design
Bookshelf Speakers for home
Classic Never Goes Out Of Style
Home audio
Perfect Match In Your Rooms
The compact size and design make it easy to drive and perfect to put in any rooms at your home. Like living room, dining room, bedroom, garage etc.
Focus On Every Details
bookshelf speaker sale
FSC Eco-friendly Certification
Handcrafted eco-friendly wood veneer.
Removable magnetic dust cover
Removable Magnetic Dust Cover
Classic aesthetic look and protective.
Pure copper crystal terminal
Pure Copper Crystal Terminal
Anti-oxidation, easy to install.
Stereo Speaker
Transparent UV paint
Drop-proof, moisture-proof, moth-proof
Strong Protected Package
Bookshelf speakers package
* Subject to technical change.
Model
BK501
BK651
Configuration
2 way
2 way
Nominal/peak power Handling
40/80 Watts
50/100 Watts
Nominal Impedance
4 ohms
4 ohms
Suitable For Amplifiers
4-8 ohms
4-8 ohms
  • 5 stars: 2 (100%)
  • 4 stars: 0 (0%)
  • 3 stars: 0 (0%)
  • 2 stars: 0 (0%)
  • 1 star: 0 (0%)
S
Steve King
BK651 tear down and review
I received a delivery of the new Arylic BK651 loudspeakers, they were very well packaged and would need seriously bad freight handling to damage the contents.
Upon opening and on first inspection I see that the cabinet design is very minimalistic in its approach an in my view I think that speaker's physical dimensions fall toward the larger side of what I'd consider as bookshelf-sized speakers.
The light oak timber veneer finished enclosures appear to be well constructed and the magnetically attached fascia grille is nice.
The two drivers are recessed flush with the veneer, upon removal of these and looking inside the cabinet the only internal stiffening is a small single MDF cross brace. As the Arylic documentation shows the MDF is 18mm thick and there are 20mm thick ‘polyfil’ type synthetic dampening material pads on the side walls of the enclosure.
The woofer/mid driver has a pressed steel chassis, the air motion transformer tweeter has cast alloy frame, the full driver specs are published in the DIY section of the Arylic website. There are no signs of a OEM on either driver.
The crossover is mounted to the base of the enclosure, it’s a basic crossover with air core inductors, wire wound resistor, a ceramic, a polyester film and a bipolar capacitor.
Looking at the rear of the enclosure there are the speaker connectors and a port. The plated brass binding posts are similar to ones that I have used previously with no issues, weird though, the ones in these speakers had steel nuts.
The port is 50mm diameter, it is a cardboard tube with flared moulded plastic ends, I can only assume that the cardboard tube has been trimmed for bass tuning upon assembly. Using a port length calculator it appears that this port is tuned to appropriately 48hz
Listening. After extensively sampling numerous and varied music genres, my impression is that these speakers are enjoyable, but like most fairly compact speakers they have limited bass depth, a somewhat exaggerated midrange and in this particular model, lively, bright and slightly piercing high frequencies. This is my first time listening with this type of air motion transformer tweeters so I can only compare with more conventional units.
They were very easy speakers to drive to loud listening levels with low apparent distortion, the low end frequency appears to drop off a little under about, I’d say around 70hz, so combining with a subwoofer would improve the listening experience.
The listening (or dispersion) area appears to be fairly narrow, although as the speakers are not really suitable for critical listening, I wasn’t overly concerned with this.
As the ports are rear facing, I would suggest that the speakers are placed at least 150mm away from a wall behind them for the ports to function properly extending the bass response.
There are a few giveaways that the speakers have been built to a budget or price point, a cast alloy frame on the woofer/mid range would have been nice and the use of a bipolar cap when a film cap could have been used for very little more.
So, are they considered reference quality? No, but I would recommend them as excellent “everyday speakers” for playing background music on a regular basis and they do offer very good value for the price.
J
Jesus de Luis
Arylic BK501 Bookshelf Speakers Unveiled
The Arylic BK501 bookshelf speakers offer clear, detailed sound at an affordable price. While not the most stylish or powerful, they deliver solid bass through a 5.25-inch woofer and crisp highs from a 1-inch silk dome tweeter. Versatile connectivity options include turntables, CD players, and streaming devices. They come with a remote control for convenient adjustments. Overall, these speakers provide excellent value and sound quality, suitable for budget-conscious buyers seeking quality sound.
