H400 4-Zone Multiroom Streaming Preamplifier
Sale price$999.00
⚡Early Black Friday Sale
20% Off Sidewide
  • Stream To 4 Zones - Independently, Or in Sync: Add network streaming, AirPlay, and Spotify Connect capability to your existing active wired speakers, amplifiers, preamps and receivers. Stream and control 4 different audio outputs at once, control all music wirelessly via our 4STREAM App.
  • Multiroom Audio System: Mix and match any combination of Arylic Streamers to create a custom multiroom system and play the same music throughout your home, send different sources to each room at the same time, or create your own custom-defined multiroom zones... All controlled via our 4STREAM App.
  • Brilliant Sound Streamed Directly From Your Favorite Providers: Spotify, Amazon Music, Tidal, Qobuz, Napster, TuneIn, Internet Radio, iHeart Radio, QQ Music, QQ FM. The H400 connects directly to your online streaming providers to play high quality audio, avoiding Bluetooth bottlenecks and compression.
  • Stream Any Kind of Audio On One Device: In addition to Direct Streaming from Online Streaming Services, AirPlay, and Spotify Connect, there are multiple digital and analog input and output ports allowing you to connect most of the audio devices in your home.
  • Plug and Play: Power up the device and connect to your WiFi router with the Lan cable and it is ready to use.
Only 1 unit left
✔Fast & Free Shipping
4 zone streamer
The H400 is a networked 4-zone streaming preamplifier that allows you to directly stream up to 4 audio devices at the same time, per H400 unit.
The H400 supports the most popular smart home systems, Fibaro and Elan, and will be integrated with more smart home brands in the future.
Home theater
Stream To 4 Zones - Independently, Or In Sync
Add Direct Streaming, AirPlay 2, and Spotify Connect capability to your existing active wired speakers, amplifiers, preamps and receivers.
Stream and control 4 different audio outputs at once, controlled wirelessly via our 4STREAM App.
4 zone streamer with optical input
In addition to direct streaming from online streaming services, AirPlay 2, and Spotify Connect, there are multiple digital and analog input and output ports allowing you to connect most of the audio devices in your home.
Home stereo system
4 zone audio receiver
The H400 comes with optional mounting brackets for installation in standard 19" racks (1U height).
smart home system
H400 comes ready to integrate with Fibaro and ELAN Smart Home installations, with an RS-232 port to connect to your smart home control unit.
Integrate and control your H400 with your smart home programs.
H400, User Manual, Ethernet Cable, 12V 2A DC Power Adapter, Rack Mount Brackets x2.
Wireless 4 zone preamplifier
Newest Firmware Version
Connectivity
WiFi:
IEEE802.11 b/g/n 2.4G
Bluetooth:
Wired Network:
Ethernet Single 10/100M RJ45 In
Ethernet RJ46 Out
(Output to other device to share the network)
Streaming Protocols
AirPlay 2, DLNA, UPnP, Spotify connect, Qplay
Music Format
FLAC/MP3/AAC/AAC+
ALAC/APE/WAV
Audio Format
Decoding up to 192khz/24bits
  • 5 stars: 2 (100%)
  • 4 stars: 0 (0%)
  • 3 stars: 0 (0%)
  • 2 stars: 0 (0%)
  • 1 star: 0 (0%)
Matthew
So powerful! Arylic H400
Just received my Arylic H400 and successfully tested it today. I’m using it together with a Raspberry Pi and HomePod mini to build a background music system. The H400 works perfectly for synchronized multi-zone playback, and also allows individual zones to play different music and adjust volume independently. Very powerful and promising — can’t wait to build more on this setup!
K
Kurt Simon
Awesome
It was a difficult find. I’m using two RUSSOUND amplifiers to feed in ceiling speakers in my large home. The M400 is the perfect solution to what I was looking for. I am able to stream to 4 zones through the built in Ethernet and everything works perfectly. Use Pandora and you can stream to multiple zones with one single account. The 4STREAM app is awesome as well. Very happy with this purchase. Expensive, but it pays for itself with how easy it is to use
A
Alexey Ivanov
Hello! I need full user manual for M400. Can you send it to me? What about shipping to Russia?
Arylic
Here is the manual: https://cdn.shopify.com/s/files/1/0072/6899/1049/files/M400_User_Manual_En_202104_b434be8a-2b21-48c0-a30e-65876bc68be7.pdf?v=1640161695
Or you can refer to here for all versions: https://www.arylic.com/pages/download
Free Shipping over $90, so you achieve the requirements.
There may be some payment issue of Russia currently, you can contact us at info@arylic.com first if you want the product.
L
Lea Moreau
Does this use the same DAC chipset as the DIY preamp? Does it do Airplay2?
Arylic
The DAC chip is ESS Sabre 9023, same as S50Pro+.
No Airplay 2, it support only Airplay 1, but you can have advanced multiroom with our 4stream app.
C
Customer
Wenn ich den M400 kaufe brauch ich kein zusätzlichen Verstärker? Wieviel Watt pro Ausgang?
Arylic
Der M400 ist ein 4-Zonen-Vorverstärker, so dass Sie möglicherweise den Verstärker für Ihre passiven Lautsprecher benötigen.
C
Customer
Kann man denn M 400 über Http bzw Api ansteuern
Arylic
Ja, Sie können sich hier auf unsere API-Dateien beziehen:<br />https://forum.arylic.com/t/api-files-for-developers/1379
A
Arne Mulder
My compliments for the A50, it is a great little amp. I Just wonder about a thing. I mainly use it for spotify and since today the volume goes from just above a low volume to mute. It seems I miss the in between low volume that could be used before. Is there any quick fix for this? . Thanks in advance!
Arylic
May I know when adjust to what specific value will have the issue?<br />
<div>
<div>And We need more info to figure out the issue, could you help us?</div>
<div> </div>
<div>Please input this URL to your browser to help us get some device info:</div>
<div><a href="http://192.168.0.195/httpapi.asp?command=getStatusEx">http://192.168.0.195/httpapi.asp?command=getStatusEx</a></div>
<div> </div>
<div>Replace 192.168.0.195 to your device IP, you can find device IP in settings&gt;speaker info&gt;device IP</div>
<div> </div>
</div>
<div>Then copy all the data you see in the browser to us.<br /><br />Please send these info to info@arylic.com</div>
<div> </div>
<div>Thanks</div>
A
Anonymous
Why does the M400 cost so much more than comparable 4 individual preamp receivers grouped together?
Arylic
Better chips , different interfaces, smart home integrations, network integration and need higher technical mantainance.<br />The stability will better then you use 4 individual preamp and more other work will add the cost.
You may also like
