AirPlay 2 Amplifier: The Easy Way to Upgrade Your Wireless Hi-Fi System
If you use an iPhone, iPad, or Mac to stream music to other devices, chances are you have already experienced AirPlay—perhaps even without realizing it. Simply tap the casting button on your device, select a speaker, and your music begins playing on another device. It’s that simple.
Apple's follow-up, AirPlay 2, takes things up a notch, refining the experience significantly. It no longer merely transmits audio from one device to another; instead, it transforms the entire home into a system featuring an Apple Music environment.
Whether you plan to set up a comprehensive whole-home audio system or simply wish to enjoy your music with greater ease, using AirPlay 2 to unlock its full range of features will deliver a truly transformative experience.
What is AirPlay 2?
AirPlay 2 is a technology introduced by Apple in 2018. Building upon the original AirPlay standard, it enables you to wirelessly stream audio from Apple devices—such as iPhones, iPads, and Macs—to other systems, including speakers, amplifiers, and televisions, all over a Wi-Fi network.
This technology has since become an indispensable part of the Apple ecosystem. Today, AirPlay 2 can be found across a wide range of products—encompassing devices running iOS, iPadOS, and macOS, as well as numerous third-party audio devices.
From a user's standpoint, AirPlay 2 is a game-changer, freeing you from the mess of wires and delivering a smoother music streaming experience. Plus, it's designed to fit seamlessly into your life. Forget about the hassle of Bluetooth setups. Just make sure your device and audio system are on the same network, and you're good to go.
Why it feels better than Bluetooth
Most people have used Bluetooth audio at some point. It works—but it also comes with a few small annoyances you probably just got used to.
AirPlay 2 takes a different approach, and the difference shows up pretty quickly in daily use.
For one, it runs on Wi-Fi instead of a short-range connection. That means you’re not stuck staying close to your speakers. You can move around your home, leave your phone on the table, or even step into another room, and the music doesn’t suddenly cut out.
It’s also a lot more reliable. With Bluetooth, dropouts and random disconnects aren’t unusual—especially in busy environments. AirPlay 2 feels steadier. Once it starts playing, it just keeps going.
Sound quality is another area where the gap becomes noticeable. Because it doesn’t rely as heavily on compression, music tends to sound fuller and more natural, especially on a proper speaker setup.
And then there’s the way it fits into everyday use. You don’t have to think about “staying connected” anymore. You can open other apps, take a call, scroll through messages—your music keeps playing in the background like it should.
After a while, you stop thinking about the technology altogether. It just becomes part of how you listen.
AirPlay 2 vs Bluetooth
Feature
Connection
Wi-Fi network
Direct pairing
Audio Quality
High / Lossless
Compressed
Range
Whole home
~10m
Multi-room
No
Stability
High
Medium
Control
App / system-level
Device-level
Source
Multiple apps
Single device
Use Case
Home audio systems
Quick playback
What Can AirPlay 2 Do?
The true value of AirPlay 2 becomes apparent when you seek a richer, more feature-rich experience than basic audio playback alone can offer.
Multi-Room Playback, Made Simple
One of AirPlay 2’s most significant upgrades is its support for "multi-room audio."
You can use multiple speakers located in different rooms or zones to play the same song simultaneously, enabling you to achieve perfect audio synchronization. There is absolutely no delay and no echo—creating a cohesive, consistent audio experience throughout your entire space.
This feature excels in a wide variety of scenarios—whether you live in a home with an open-plan layout, are hosting a party, or simply wish to move between rooms without interrupting your listening experience.
Play Different Music in Different Rooms
AirPlay 2 offers capabilities that go far beyond simply streaming a single audio source.
You can simultaneously send different audio content to different rooms. For example:
Music playing in the living room
A podcast playing in the kitchen
The commentary track from a YouTube video playing in the bedroom
All playback controls can be managed directly via your iPhone or iPad, allowing you to switch effortlessly between different zones.
Built-in iOS Controls
AirPlay 2 is deeply integrated into Apple's operating system.
You can control playback directly through the iOS "Control Center"—performing actions like pausing, skipping tracks, adjusting volume, or switching output devices takes just a few seconds. There is no need to open a separate app or navigate through complicated, cumbersome interfaces.
For those who rely on Apple Music, the integration is particularly smooth. But AirPlay 2 isn't limited to just that; it also works with Spotify, YouTube Music, and a host of other applications, giving you a broader range of audio options.
Control Playback with Siri
You can use Siri to control audio playback on your devices.
Simply issue commands such as "Play music in the living room" or "Turn down the volume," and AirPlay 2 transforms into a truly seamlessly integrated core component of your smart home ecosystem.
Stable and Seamless Playback
Once playback begins, AirPlay 2-enabled applications stream audio directly from the internet source. Consequently, your music playback will no longer be easily interrupted—ensuring that the audio remains consistently smooth and uninterrupted, even when you answer a phone call, switch applications, or walk into another room.
Why an AirPlay 2 amplifier is a smarter move
When people think about upgrading their audio setup, wireless speakers are usually the first thing that comes to mind. They’re easy, compact, and quick to set up.
But if you’re thinking a bit longer term—or you already have speakers you actually like—going with an AirPlay 2 amplifier tends to make more sense.
Keep what you already like
There’s no real need to replace a good pair of speakers just to get wireless streaming.
An AirPlay 2 amplifier lets you keep using your existing setup while adding modern features on top. If you’ve already spent time (and money) finding speakers that sound right to you, this approach just feels more practical.
More control over how your system sounds
Compared to most all-in-one wireless speakers, a dedicated amplifier gives you more headroom and better control.
You’ll notice it in small ways at first—cleaner vocals, tighter bass—but over time it adds up to a more balanced and enjoyable listening experience.
Build your system your way
One of the biggest advantages here is flexibility.
You’re not locked into a single box. You can change speakers, add a subwoofer, or slowly expand your setup depending on your space and preferences. A simple 2.0 setup today can easily become a 2.1 system later on.
That kind of freedom is a big part of why many audio enthusiasts prefer this route.
Old-school meets modern streaming
In a way, an AirPlay 2 amplifier sits right between traditional Hi-Fi and today’s streaming habits.
You still get the reliability and sound quality of a wired speaker system, but now it works seamlessly with your phone, your apps, and your daily routine.
That balance is what makes it such a practical upgrade.
Meet the LA50 AirPlay 2 Amplifier
The LA50 is Arylic’s take on this idea—a streaming amplifier designed to bring AirPlay 2 into a real-world setup without making things complicated.
It’s built for people who want modern streaming, but don’t want to give up the flexibility of a proper speaker system.
With 50W per channel, the LA50 works well for desktop listening, bookshelf speakers, and most living room setups.
There’s also a dedicated subwoofer output, so if you want a bit more low-end presence, building a 2.1 system is straightforward.
Not limited to one ecosystem
AirPlay 2 is a big part of the experience, but it’s not the only option.
The LA50 also supports Google Cast, Spotify Connect, TIDAL Connect, and Qobuz Connect. So no matter which platform you tend to use, you’re not boxed into a single way of listening.
Easy to live with
Once it’s set up, it doesn’t ask much from you.
You don’t need to relearn how you listen to music or deal with complicated controls. It just becomes part of your setup—something that works in the background without getting in the way.
Getting started with AirPlay 2
Using AirPlay 2 with the LA50 is about as simple as it gets.
Connect the amp to your Wi-Fi, make sure your iPhone, iPad, or Mac is on the same network, then open Control Center and select the LA50 from the AirPlay menu.
That’s all it takes.
No pairing process, no extra steps—just pick it and start playing.
Once it’s set up, it’ll show up every time you want to use it.
Final thoughts
AirPlay 2 isn’t just another feature you check off on a spec sheet. It changes how your system fits into everyday life.
It makes playback easier, switching between devices quicker, and multi-room setups far less complicated.
If you’re looking for something beyond a basic wireless speaker, an AirPlay 2 amplifier is a solid upgrade path.
And with something like the LA50, you don’t have to overthink it.
You keep the speakers you already enjoy, add the streaming features you actually use, and end up with a system that feels simple, flexible, and built around how you listen.
Easy setup, I use it for Qobuz connect into an avr setup for 2.2 music only. Seamless connection. I bought this second one for some studio monitors. Highly recommend for any music system without network capabilities.
01/29/2026
Antero
Perfect match
"The Arylic S50 Pro+ delivers Hi-Fi sound with ESS Sabre DAC, wireless streaming via WiFi and aptX HD Bluetooth—perfect for upgrading classic systems with full mobile control , like my old Sansui
11/14/2025
Kateryna
Perfect for me
08/01/2025
Gord Rollason
LP10 a great, economical way to get into digital streaming!
I've been into home audio since the 70s with the best gear I could afford JBL spks, Mc amp, Thorens tt, Shure cart. I'm no audiophile and was reluctant to spend the kind of money required to add even basic streaming, until Arylic. I bought an s10 just to try it out. I first tried Amazon then Apple music and it sounded fine but lacked a few features like AirPlay 2 and optical out. The LP 10 has these and more so it was well worth it to upgrade. I would be surprised if I could hear a difference on a more expensive streamer on my system.
07/19/2025
Sjaan Heijnen
Hello i have. Recieved my streamer in good order and i,m very happy with my streamer and the sound guality is very good.I think it is a very good guallity for the price. Sorry for my bad English
07/11/2025
Nunzio
Second purchase!!
I bought a second LP10 connected to the kids' small amp to create a multi-room setup with the first LP10 connected to my vintage hi-fi and the soundbar in the bedroom connected to Google Chromecast. No problems thanks to Google Cast compatibility!! I'm really satisfied, the only thing that needs improvement is the Go Control app.
07/10/2025
Thor Johnson
Love my new LP10 streaming pre-amp
WiFi streaming for any stereo now with this tiny streaming pre-amp. I've moved from Bluetooth streaming for better fidelity and having all speakers in sync.
LP10 works with Google Home and with Spotify as a WiFi speaker alongside other Home-compatibles. Big upgrade for me. Easy. Simple.
07/09/2025
Acragante
Arylic LP10 in action
After testing and trying the Arylic LP10 for several days, I have drawn my conclusions about it.As an audiophile listener, I can only say that this device can be defined with one word.
IMPRESSIVE!!!!
It has fantastic quality in reproduction, very refined in audio.
07/06/2025
Kal Shed
Great streaming device!
This device is great for multiple uses. Using it to power my 2 bookshelf speakers, and was super impressed with the audio output! AirPlay is also a game changer. HIGHLY recommend the A100!
06/30/2025
Q.N.
A Compact, Cast-Ready Streamer
After using the Arylic LP10 for a few weeks, I’ve found it to be a great value streamer with solid performance. The built-in Google Cast works flawlessly, which is perfect for streaming YouTube Music, especially that the Chromecast Audio dongle is discontinued. It was easy to set up, has a compact footprint, remote, and offers connectivity options including Wi-Fi, Bluetooth 5.2, USB, and optical out. The sound is a bit quiet when connected directly to an amp, but pairing it with a DAC like the SMSL SU-1 the output is a lot louder and really brings the music to life with better clarity and punch. While it lacks support for some streaming platforms, at around $99, it’s competitively priced (if you can get a coupon, it makes the buy much sweeter). For myself who is invested in the Google ecosystem and want an affordable, reliable music streamer, the LP10 is a strong pick.
06/26/2025
Rob Durbin
They keep getting better,
I have purchased 4 Arylic amplifiers. The first two were the A50+, the 3rd was the H50 and just very recently the A100. The sound on all of units are very good, but the A100 really creates great sound. I can play the same music on all or different for each Amp. The display on the A100 is awesome, makes changing inputs very simple. Great customer support and quick shipping.
06/25/2025
Nunzio
excellent quality and efficiency of customer service
I had purchased the S10+ preamplifier and was very satisfied with its qualities but I needed it to interact with Chromecast to create a multiroom with my Chromecast audio, so I took advantage of the 30 days free return and started the return, within an only day Arylic refunded me the cost of the S10+ and after a few days its customer service also refunded me the payment for the return shipping, I particularly thank Victoria of their customer service who immediately took action to refund the shipping. So satisfied with its efficiency that I had purchased the new LP10 that works perfectly with Chromecast.
06/16/2025
Marte
Music in my ears.
Almost plug and play. Discovering all possibilities takes time. Also due to the fact that there are 3 different interfaces. One on the amplifier, one on the remote and one in the app. But, everything works fine. Glad I kept my record player (50+ yrs) and 20+ yrs high end speaker set.
06/03/2025
Mikael Rickan
Arylic A100
I found a short review of this amp on internet and was very surprised by its price vs features, had to order one to see if it actually delivers, and wow it does. Finally a all-in-one solution for most cases without taking up alot of space. Sound wise it sounds very similar to my other marantz amp (used in cinema room) , warm and not stressed at all.
Haven't taken any measures yet but will do it at a later point. So far I'm very happy that I stumbled over the A100.
Do I miss anything, can't expect all with this price but it should have been the perfect amp if it had a subwoofer output to be truly amazing. Still there is nothing of this quality at this price range, so I will continue enjoy this amp.
05/13/2025
Vish
Arylic A100 - Feature rich streaming amplifier
Arylic have done very well with this A100 being their first TPA3255.
