SA100 50W x 2 Wireless On-Wall Amplifier
You can install SA100 on any wall in the home or office to unlock versatile sound. Stream online music, online radio, NAS, USB or Bluetooth audio to your traditional passive speakers.
Upgrade your listening experience into more convenient and modern way. Easily control with rotary knob, web, and full functional 4stream app.
Powerful Amplifier
SA100 is the most powerful amplifier of Arylic amplifier series, which can deliver undistorted and 50W x 2 big sound on both 4 ohm or 8ohm passive speakers.
*Unplug the power before switching to prevent damaging the device.
Easy Home Installation
The SA100 is designed with four mounting holes for screws, allowing it to be discretely mounted anywhere in your house.
Install, configure, and control remotely via the 4stream App or Web interface. Perfect suit for home and office installation.
Versatile Playing
Stream from online music, online radio, phone memory, NAS, USB stick, Bluetooth audio, line in audio, digital audio and more to your passive speaker by Airplay, WiFi, Spotify Connect, Bluetooth 5.0, DLNA and UPnP.
Bring Music To Every Room
You control all audio gears that connect to SA100 WiFi and Bluetooth amplifier for wired speakers and Bluetooth in one smart control device.
Like Phone, Tablet, Laptop, Desktop computer. Play different songs in different rooms or sync audio in different rooms.
Tune Like An Expert
Fine tune your listening experience with our exclusive ACPWorkbench tuning tool.
Find the perfect sound for each channel with EQ, Bass Enhancement, Advanced DSP effects, Gain, Pregain and more.
Easy Control
Easy knob control for volume, treble and bass. Full functionally control with 4STREAM app, simple directly control by web without any app.
SA100 WiFi and Bluetooth amp, User Manual, 24V 4.16A DC Power Adapter, External Antennas (Bluetooth & WiFi)
2-2 RCA Cable x2 , Screw Driver, 4 Pin Phoenix Connector (for speakers)
WiFi:
IEEE802.11 b/g/n 2.4G
Bluetooth:
Wired Network:
12V-24V/DC in
Analog
RCA(1.2Vrms)
Digital
Micro USB Input
Optical Input
Analog
RCA(1Vrms)
Sub Out(2Vrms)
Digital
Micro USB Input
Optical Input
STA326
2x50W into 4Ω BTL load at 24V
2x50W into 8Ω BTL load at 24V (Boost)
4-8Ω
20Hz to 20kHz
0.03%, @1kHz 50W+50W 24V-4Ω
Decoding up to 192khz/24bits
Support NAS with DLNA support
Dimensions:
6.25 “ L x 5.75 “ W x 1.6 “H(15.8x14.6x4CM)
Weight:
600g
Working temperature:
Power Supply
Screw Driver
4Pin phoenix connector
External Antenna x2
RCA Cable x2
User Manual
Power Button
Device on:
Long press once: Switch off
Device off:
Short press: Switch on
Volume Knob
Treble Knob
Bass Knob
⚪White-WiFi & network mode:
Solid- WiFi is connected
🔵Blue-Bluetooth mode:
Solid- Bluetooth is connected
🟢Green-Line in mode
🔴Red-USB mode
🟡Yellow-connect to PC
🟣Purple-Optical Input
I have 6 ohm speakers. Can I connect SA100 home audio stereo amplifier to them ?
Yes, you should switch the stereo amplifier to 8 ohms.
How many audio output types of this home audio stereo amplifier?
There are 2 output types, line out and speaker out.
How many audio input types of this home audio stereo amplifier?
There are 7 iutput types , USD audio, Bluetooth 5.0, Wifi, Ethernet RJ45,USD disk, Line in, Optical in.
What amplifier do I need for 100 watt speakers?
A 50-watt per channel amplifier will work fine with speakers rated at 100 watts.
Arylic SA100 is the home audio stereo amplifier which have 2*50W per channer.
How many watts is a good amplifier?
A good audio amplifier should have excellent sound quality and enough power to drive your speakers.
SA100 home audio stereo amplifier has high-quality Bluetooth and power amplifier chip, which can perfectly restore your lossless audio source. The maximum power of 100 watts can fully meet your household needs.
How many speaker can I connect to each SA100 Amp?
That’s all depends on your speakers, The max power of SA100 Amp is 100W.
