LP20 Music Streamer
- Free shipping.
30-Day Worry Free Guarantee✨
Warranty Made Simple
- Support AirPlay 2, Google Cast, Spotify Connect, Qobuz Connect, and Tidal Connect.
- Support Spotify Lossless, richer detail and clearer sound from lossless streaming.
- AKM AK4490EQ DAC for clearer, more detailed high-resolution sound.
- RCA, Optical, PC DAC, Coax, Sub out and USB input for flexible home audio connections.
- Supports Siri or Google voice assistant.
Better Sound, Instantly Upgraded
Upgrade your existing speakers with wireless streaming and enhanced sound in seconds.
You can stream music directly from your iPhone, iPad, or MacBook, and simultaneously synchronize playback with other AirPlay 2-enabled devices.
The LP20 also supports connecting to a HomePod via the Apple Home app, allowing you to synchronize streamed audio with the HomePod.
You can stream music directly from any Cast-enabled app, with seamless Google Cast support and high-resolution audio playback up to 96 kHz/24-bit.
Spotify Connect enables one-tap streaming directly from the Spotify app, while lossless playback delivers clearer, higher-quality sound.
You can play music directly through the Qobuz and Tidal apps, enjoying your favorite playlists and familiar user interfaces.Tidal Max support 192kHz/24bit
192kHz
24bit
With the LP20, you can easily build a powerful 2.1 audio system with rich stereo sound and deep bass for music, movies, and desktop setups.
Control playback, volume, and audio settings directly from your PC for a more convenient desktop audio experience.
Use the 12V trigger to automatically turn connected audio devices on or off together.
SW out
Connect a subwoofer to add deeper, more powerful bass.
Connect your TV or game console for stable digital sound, perfect for movies and gaming.
12 Trigger out
Let devices power on and off together for a smoother, more automated experience.
Coax out
Provide stable digital audio output for high-quality audio systems.
PC Control
Connect directly to your computer for cleaner, more powerful sound for music, gaming, and movies.
Seamless Music in Every Room
Install an LP20 in each room to enjoy perfectly synchronized music throughout your home with AirPlay 2 or Google Cast, and move freely from space to space while your music follows seamlessly, playing in sync across all your speakers.
Stable WiFi
Dual-band WiFi (2.4GHz & 5GHz) with Ethernet support for flexible connectivity.
Stay connected across rooms with reliable coverage, switch to 5GHz for smoother high-quality streaming, or go wired for consistently stable playback when it matters.
USB Playback
Supports USB drive playback with FAT16, FAT32, and exFAT formats (up to 128GB), plus resume playback.
Just plug in your music and pick up right where you left off — with broad support for formats like MP3, AAC, and FLAC.
Dual Band 802.11ac 2.4GHz/5GHz
LAN
10/100M RJ45
5.0, 15m
Bluetooth Receive
Codec: SBC, AAC, 2x Bluetooth RX, able to connect up to 2 smartphones
Streaming Protocols
WiFi, Google Cast, AirPlay 2, Spotify Connect, Qobuz Connect, TIDAL Connect, DLNA, UPnP
RCA Input x1
2 Vrms
Optical Input x1
PCM only, up to 192kHz/24bit
USB Host x1
USB disk drive playback, support resume playback Storage format: Fat16, Fat32, exFAT, up to 128GB Support codec: mp3, wma, m4a, aac, flac
USB Type C port x1
PC Audio
Local Music
RCA Out x1
Max 2 Vrms output
Optical Out x1
Up to 192kHz/24bit
Coax Out x1
Up to 192kHz/24bit PCM only
Subwoofer Out x1
Max 3 Vrms output, Crossover frequency: 250Hz
Buttons
Rotary Knob
Switch between modes, volume, and power.
Reset Button
Repair WiFi/Bluetooth, restore to factory settings.
APP
GO CONTROL APP
Voice Control
Siri, Google Assistant
Remote Controller
IR
Power Input
USB Type-C Port 5V/2A
Size
148*148*43mm
Weight
500g
Trigger Out x1
12V
LP20 x1
IR Remote Controller x1
Manual x1
5V/2A Power Adapter x1
2-2 RCA Cabke x1
USB Type-C Cable x1
Can LP20 sync with other streaming devices for multiroom audio?
Yes! You can wirelessly sync using AirPlay 2 (for Apple devices) or Google Cast (for Android/Chromebook devices).
Can the LP20 be used with other Arylic products for multi-room audio?
The LP20 supports multi-room playback via AirPlay 2 and Google Cast, enabling it to work seamlessly with devices that support either of these technologies. For Arylic devices that do not support AirPlay 2 or Google Cast, multi-room playback functionality can only be achieved through Arylic's proprietary multi-room system.
Can the LP20 be used with Bose speakers?
Yes, you can connect your Bose speaker using Line Out or Optical Out, depending on the available input interface.
Can the LP20 use AirPlay 2 or Google Cast to transmit signals to speakers?
The LP20 supports synchronized multi-room playback with other AirPlay 2-compatible Apple devices, as well as speakers or streaming players that support Google Cast.
However, it cannot transmit or cast audio signals from external input sources—such as a turntable—to devices like the HomePod. In other words, while the LP20 supports synchronized multi-room playback, it does not possess AirPlay 2 or Google Cast audio transmission capabilities.
