LA50 Streaming Amplifier
ARCGoogle Cast
Sale price$287.00
Bulk Discount
  • AirPlay 2, GoogleCast, Spotify Connect, Tidal Connect, Qobuz Connect support.
  • 50W × 2 Drivers Most Speaker with Ease.
  • Add Subwoofer for 2.1 Home Cinema.
  • Auto TV Detection & TV Remote Volume Control.
  • Voice Control with your Siri or Google voice assiatant.
Share and Earn
Guaranteed Latest Batch
30-Day Risk-Free Trial
Live Human Support
1 Year Solid Warranty
Build It Right, Upgrade It Smart
Whether you're starting from scratch or replacing outdated gear, bring stable WiFi streaming and native smart control to the speakers you love.
AirPlay 2 Makes Everything Easier
✔ Certified AirPlay for convenience and stable WiFi streaming.
✔ Play anything from iPhone — Apple Music, YouTube and more.
✔ Control your music hands-free with Siri.
✔ Sync with HomePod, Sonos and other AirPlay 2 speakers.
Hi-Res Audio with Google Cast
✔Chromecast built-in for seamless, stable WiFi streaming.
✔Stream in up to 24-bit / 96kHz high resolution.
✔Cast from YouTube Music, Spotify, TIDAL, Qobuz and more.
✔Control with Google Assistant — hands free.
✔Group with Nest and other Google Cast speakers for multi-room audio.
Spotify Connect Built-In
✔Stream directly from Spotify APP.
✔Music keeps playing even if you take calls.
✔Full-quality streaming over stable WiFi.
Spotify Lossless support coming in a future firmware update (Q2 planned).
Tidal Connect
✔Stream directly from the TIDAL app.
✔High-resolution playback up to 24-bit / 192kHz.
✔Stable, gapless streaming over WiFi.
Qobuz Connect
✔Stream directly from the Qobuz app
✔Enjoy true high-resolution audio up to 24-bit / 192kHz.
✔Stable WiFi streaming without compression.
If It Plays on Your Smart Phone, It Plays Here
Stream everything through AirPlay 2 and Goolge cast.
Play Everywhere, Control with Your Voice
Group with HomePod, Nest, Sonos and other compatible speakers using AirPlay 2 or Chromecast built-in. Play the same music across rooms and control it with Siri or Google Voice Assistant.
Drives Most Speakers with Ease
50W ×2 — more than enough for everyday listening.
Delivers room-filling sound with a single pair of speakers, and supports a second pair for wider coverage when needed.
*For multi-speaker setups, ensure compatible impedance. We recommend connecting up to 4 speakers total.
Build Stereo or 2.1 system
Wider Backgroud Music Coverage
Drag
Transform Your TV into a 2.1 Home Theater
Better sound than built-in TV speakers with automatic TV detection and seamless remote control. Add a subwoofer anytime for deeper, cinematic bass.
Control with Your TV Remote
Adjust volume and power — no extra remote needed.
Build 2.1 Home Theater
Add a sub and transform it into a 2.1 home cinema system.
Upgrade Your TV Sound
More power and clarity than built-in TV speakers.
Compact Design, Big Desktop Upgrade.
Roughly the size of two iPhones, it saves space while delivering powerful audio.
Use it as a USB DAC for your PC and experience a clear upgrade over stock computer sound.
Shake with Bass
Shape the bass, adjust crossover points, and control deep bass in GO CONTROL APP to suit your favorite songs, movies, or games.
APP & Remote Control
Use our intuitive app to manage music, switch sources, and adjust settings — full control wherever you are.
The included remote lets you quickly adjust volume, power, and playback without opening the app — simple, convenient, ready-to-use.
