Do you know what is a Bluetooth amplifier and how they work? We will show you a detailed explanation of the Bluetooth amplifier. We will explain the item from those aspects: what they are, how they work, and why you should use them.
Previously, we need to know there are two meanings for the term Bluetooth amplifier. The first type of Bluetooth amplifier is an audio amplifier that works with other devices via Bluetooth technology. Most people will install this kind of amplifier frequently in their home theater system to gain an excellent movie experience. With this setup, the audio received from your TV will be sent to your speakers wirelessly, which can eliminate the need for cables to run between them or through walls.
Bluetooth Amplifier Definition
The term “Bluetooth amplifier” can be perplexing at times.
Generally speaking, it is an audio amplifier to receive and amplify audio from other Bluetooth devices in the vicinity with the help of Bluetooth. Here, for example, you could play any audio on your phone and use the amplifier to boost the sound/base.
It frequently linked this type of amplifier to another device, either wirelessly or wired. The other device is frequently a larger speaker, such as a sound bar or surround sound system.
The second kind of Bluetooth amp focuses on the use of Bluetooth devices like headphones or speakers. You can also use a cable if you need to connect this Bluetooth amp to your phone for better sound quality. What’s more, it essentially amplifies signals received and sent by Bluetooth devices that are connected to it.
The ideal range for a home theater or public address system may be up to 328 feet when you install the Bluetooth amplifier.
You can also check Arylic newly released B50 Bluetooth Amplifier.
How Does A Bluetooth Amplifier Work?
The exact definition of a Bluetooth amp is a device that can receive audio signals from other Bluetooth-enabled devices. And then it will amplify those signals so we can hear them through the amp’s speakers or directly through an output port if using headphones.
All Bluetooth amplifiers come with a range of around 328 feet even though this range will vary according to its power.
Getting better sound quality audio from your phone or speakers without running wires between them may be the major reason that you want to purchase a Bluetooth amp, in this way, you have no need to worry about what speakers are connected to.
Also, when you use some devices without built-in Bluetooth, such as MP players or music systems, the Bluetooth amplifier can also be your first choice. They also work with most home theater systems, which can bring an excellent movie experience.
If you install the home theater setup in your house, and if you need to get the better sound quality with the complex wires between different components of the setup over your room, then you can choose a Bluetooth amplifier for wired speakers.
Benefits of Using a Bluetooth Amplifier
We will show some reasons why you need to use a Bluetooth amplifier in your home theater or audio setup:
1. Improved Audio Quality
A Bluetooth amplifier will provide better sound quality than simply connecting your phone or tablet to speakers. Because it has more power, it can handle higher volume levels without distorting the audio signal. This means it will play music at higher volumes while maintaining clarity and detail.
2. More precise volume control
It's not easy to control the volume when connecting phones or other devices directly to a speaker.
Both of those two devices have their own controls for adjusting volume levels, but you will have more options to adjust volume with a Bluetooth amplifier, you can control how loud or quiet your music is playing (incoming signal and output). This means that even though you’re going out in public places and there aren’t any speakers nearby, you’ll be able to control the volume of your music.
3. Upgraded Clarity and Detail in Music
Bluetooth amplifiers would play music at a louder volume without distorting the audio signal with the help of greater power than other devices. This means it will maintain clarity and detail while playing music at a higher volume.
4. Compatibility with a Wide Range of Devices
Phones, tablets, music players, home theater systems, and other various devices are all compatible with the Bluetooth amplifier. This means you have no need to worry about not being able to find a device that works with your particular setup.
5. No wires!
This is yet another important benefit of adding a Bluetooth amplifier to your music system or home theater setup. There won't be any long cables trailing in every direction, which can be ugly and problematic if they tangle with other neighboring cords.
Bluetooth Amplifier Common Applications
Public Address Systems
More and more public address systems will be equipped with Bluetooth amplifiers, such as those found in schools, churches, farms, and other locations where a large number of people need to hear audio announcements.
Because of the long-range and ability to play audio at high volumes without distorting the signal, Bluetooth amplifier is becoming more popular for public address systems.
Home Theater Equipment
Bluetooth amplifiers are also commonly used in home theater systems because we can get high-quality audio sound and allow for volume control. All speakers will play the same sound, which likes the multiroom amplifier audio mode.
In Cars
If you are a car owner, the Bluetooth amp will also become the first option for your car audio system because it will improve the sound quality. Not only they can get high-quality sound, but also they can be easily connected to their car’s stereo system. The music experience will be also improved with the Bluetooth amp.
DIY
Sometimes, if you want to have a more personalized Bluetooth sound system, you can DIY your own Bluetooth amplifier board or Bluetooth speaker with a DIY Bluetooth speaker kit. You can get some Bluetooth speaker kit in our accessories.
Last Thoughts
Anyone who wants to enhance the audio quality of their audio gadgets without having to deal with long wires going everywhere should consider using Bluetooth amplifiers or Bluetooth preamp.
They are a great option for any home theater or audio setup because they are compatible with a variety of devices and have many applications. If you want the best sound quality without sacrificing convenience, this may be your best option.
