Nowadays, Bluetooth connectivity has become more popular in our daily lives and affects the way we listen to music(through headphones and speakers). If you want to know how Bluetooth works, you can find the answer by reading this article.
How do Bluetooth speakers work? When we connect Bluetooth speakers to digital audio equipment with Bluetooth function, they will receive digital audio wirelessly over the Bluetooth protocol.
Bluetooth speakers use Bluetooth wireless transmission to accept digital audio. After that, the digital audio will be converted to analog audio and then will be amplified.
In this article, we will discuss Bluetooth speakers, like what is it and how it works.
What is Bluetooth Technology
Bluetooth is known as a wireless communication protocol. With this protocol, we can make devices communicate with each other over short distances using radio waves.
The Bluetooth receiver gets the audio signal and sends it to two important parts before it plays on the speakers. What’s more, Bluetooth sends digital audio and after that, the received signal will be transferred into analog audio.
The digital-to-analog converter (DAC) included in the speaker converts it to analog after it has been encoded in digital format. The analog audio is amplified via a built-in amplifier circuit.
After that, the amplified signal will be delivered to the speaker driver.
In this situation, the stereo and surround code audio streams will be separated. Also, the analog audio signal is converted into sound waves by the speaker drivers, so people will perceive the sound waves.
In terms of Bluetooth speakers, this wireless technology has no significant difference from the common notion. To hear music, we must link two or more Bluetooth speakers that work together and keep them near each other.
What is a Bluetooth Speaker
Bluetooth speakers are audio equipment with a built-in Bluetooth chip that uses Bluetooth to replace traditional wire connections. You can connect Bluetooth speakers to mobile phones, tablet PCs, notebooks, and other Bluetooth playback devices for ease.
Bluetooth speakers integrate Bluetooth technology into traditional digital and multimedia speakers. With this wireless technology, people can remove the annoying cables and wires when using speakers to listen to music.
Bluetooth speakers caught the attention of mobile phones, tablets, and other users because of the progress in intelligent terminals.
Bluetooth technology enables the use of wireless speakers. Many manufacturers provide a variety of "Bluetooth speakers" for music enthusiasts.
How Do Bluetooth Speakers Work
Bluetooth speakers have a similar function to traditional wired speakers, but they have different methods of receiving audio signals.
Hardwired speaker connections send speaker-level audio signals to wires passive speakers. Hardwired active speakers get speaker-level signals through a speaker cable or line, and instrument signals through a thinner audio cable.
And then, the Bluetooth speakers use Bluetooth to transmit audio signals wirelessly. Specifically, the Bluetooth speaker's built-in power amplifier will receive the audio signal wirelessly through Bluetooth.
Bluetooth protocols can easily send normal line-level signals as they are. This signal level needs amplification from a power amp before it can properly drive the loudspeaker, similar to wired setups.
In order to function properly and effectively, Bluetooth speakers must be paired to a Bluetooth audio device wirelessly.
Once the speakers are connected to the digital audio device, they will form a Piconet.
There is a function for the Piconet after it was formed. It will allow the audio device to send its audio signal to the Bluetooth speaker. Smart speakers will also transfer the date back to the audio device via the Piconet.
If the Bluetooth speaker can receive digital audio, it can make the speaker work by going through two important parts.
Because Bluetooth technology sends digital audio, then the received audio signal must be transferred into analog audio. Finally, the built-in digital-to-analog will complete this step.
In the previous explanation, the converted analog audio will route through a power amplifier. Thanks to the low enough impedance and the high enough current on the amplified output signal, it will properly drive the speaker driver.
After the signal has gone through the speaker driver, the driver must generate sound waves that represent the audio signal.
And this is how we can hear audio signals from information via Bluetooth speakers
Benefits and Downsides of Using Bluetooth Speakers
The Benefits:
Bluetooth speakers eliminate the need for bulky cords, delivering a clutter-free and portable music option.
Portability: Most Bluetooth speakers are small and lightweight, making them convenient to transport and use in a variety of settings.
Wide Range Connection: Bluetooth speakers can connect to laptops, smartphones, and tablets due to the common Bluetooth standard.
Simple Setup: Pairing Bluetooth speakers is simple; it usually just takes a few taps or clicks on your device.
Sound Quality: Many Bluetooth speakers have surprisingly good sound quality, with options for various budgets and audiophile requirements.
The Downsides:
Bluetooth has a limited range of generally 30 feet (10 meters), thus you must keep this distance from the speaker. Walls and barriers can further limit this range.
Battery Life: Because portable Bluetooth speakers are powered by internal batteries, their playback length varies. After a few hours of use, you may need to recharge them.
Bluetooth audio can still have compression and latency issues, especially in cheaper models, despite improvements in audio quality.
Bluetooth can cause interference and audio problems in places with many wireless devices due to the crowded radio band it uses.
Pairing Issues: Bluetooth devices might occasionally struggle to pair or maintain a solid connection, causing irritation.
Understanding how Bluetooth speakers function allows you to get the most out of your smartphone and enjoy this incredible technology.
A Bluetooth speaker can easily make your favorite music sound great, whether you like classical, pop, or electronic beats. And, in an ever-changing world, who wouldn't want a soundtrack that moves with them?
So grab your phone, connect your Bluetooth speaker, let the music flow, and upgrade your sound systems.
