News
Up2Stream Pro Launch WiFi&Bluetooth 5.0 Board to Make HiFi Multiroom Audio
Up2stream Pro WiFi&Bluetooth Audio receiver board
Up2Stream Pro, a WiFi and Bluetooth 5.0 HiFi audio receiver board can be used to upgrade your regular audio system WiFi and Bluetooth enabled with multiroom function. On our app, you can stream music from Spotify, Deezer,
Qobuz, Tidal or local files from NAS, etc. 24bit,192kHz decode makes great sound. AirPlay, DLNA, UPnP brings you more possibilities.
Video
Highlights:
  1. Support WiFi&bluetooth 5.0 connected devices
  2. Bluetooth 5.0 receiver distance transmission around 20-30meters.
  3. Adding I2S interface available (DOUT, BCLK, LRCK, GND).
  4. Spotify, Deezer, Tidal, Qobuz, Napster and more available by free update.
  5. Line in, usb music source can be retransmission to other unit and play it in sync.
  6. Add Ethernet interface to connect devices directly to network via the cable.
  7. Replace the power interface with Micro USB.
Up2stream pro
APP Support For All Kinds of System
Any streaming services not available in the app, recommend using Bluetooth to stream that.
UP2Stream Pro WiFi and Bluetooth 5.0 HiFi audio receiver board
UP2Stream Pro, a WiFi and Bluetooth 5.0 HiFi audio receiver board
Control by ios, Android and PC device
Download 4STREAM App
Arylic 4STREAM App
Control music in every room
Play same music in sync or different music in any room with your finger touch.
Czytaj dalej
Deezer, Qobuz, EQ Control Now Available with Updated 4STREAM App
The Resurrection of an Audioengine 5 with Up2Stream Mini
3 komentarze
Arylic
Arylic
Hi KS, the comparison may have a mistake.
All of our system support iOS and Android system.
ozpixmmupj
ozpixmmupj
Muchas gracias. ?Como puedo iniciar sesion?
KS Bawa
KS Bawa
Your comparison sheet above with different models show that UP2Stream PRO is not compatible with Android. Why so !!!!
I ordered 2 pieces as i saw every where that it is compatible with both IOS and Android.
